Twenty hours to go
Discussion in 'UK Motorcycles' started by TOG@Toil, Apr 2, 2009.
  1. TOG@Toil
    yeah, 'cos doing so the day after heavy snow makes so much more sense.
    darsy, Apr 3, 2009
  2. TOG@Toil
    Simon Wilson Guest
    TOG@Toil wrote:
    Ho Yuss. It's even better wivv a Micron, some more revs, and no baffle.
    Simon Wilson, Apr 3, 2009
  3. TOG@Toil
    Simon Wilson Guest
    Does anyone believe http://www.mototuneusa.com/break_in_secrets.htm this
    stuff?
    I've had mates who swear that thrashing the tits off it from day one
    results in an engine that's smoother and burns less oil.
    I think the new 675 has a bigger sump, but don't forget to check the
    level regularly, they can use a fair old bit.
  4. TOG@Toil
    TOG@Toil Guest
    TOG@Toil, Apr 3, 2009
  5. TOG@Toil
    TOG@Toil Guest
    Dunno, but it has its little recommended running-in rev sticker on the
    tank, and what Trumf say, I'll do, on the basis that they know best.
    Yes, I will, ta.
  6. TOG@Toil
    TOG@Toil Guest
    Yeah, IKWYM. I've got a little flyscreen on mine - keeps the wind off
    your chest, but no more than that. Earplugs, yes, deffo.
  7. TOG@Toil
    And when you've done that and want to remove said sticker, don't use a
    hairdryer to warm it up and peel it off, because then you might have to
    get the ChipsAway man to come and reinstate the paint on the top of the
    tank of your nearly new motorcycle at a cost of 90 quid or so.
    DAMHIK,IJD,OK?
    CT, Apr 3, 2009
  8. TOG@Toil
    Catman Guest
    And they have identical engines with which to do back to back
    comparisons? ;)
    www.cuore-sportivo.co.uk
    Catman, Apr 3, 2009
  9. TOG@Toil
    TOG@Toil Guest
    Cor, thanks for that, because that was *exactly* what I was going to
    do. Erm, what's the recommended removal procedure, then. And *don't*
    say 'angle grinder'.
  10. TOG@Toil
    Having done the above with the hairdryer I think netx time I'd try warm
    water just to try to soften up the glue a bit. If that didn't work,
    I'd revert to the hairdryer but being *very* careful I didn't get the
    actual paint on the tank too hot. Again.
    CT, Apr 3, 2009
  11. TOG@Toil
    Adie Guest
    leave it on and cover it with a baglux tank cover :)
    Adie
    UKRM FAQ: http://www.ukrm.info/faq/
    YZF-R1 : FZ1 : GPz 750 turbo
    keeper of the FAQ for my sins
    Adie, Apr 3, 2009
  12. TOG@Toil
    Catman Guest
    I just left mine on. On both mine, the paint on the tank has been
    ludicrously soft. Really didn't seem worth it.
    Catman, Apr 3, 2009
  13. TOG@Toil
    I'm a great believer in being nice for the first 100 miles just in
    case there's a manufacturing fault in there just waiting to nip the
    engine and throw me over the bars but after that I build the revs up
    gradually but give it plenty every so often rather than just plodding
    along at constant revs.
    Andy Bonwick, Apr 3, 2009
  14. TOG@Toil
    TOG@Toil Guest
    Oh, yeah, I do that too. It's the only thing that enlivens Life At
    Five Thousand Revs: drop it down to 40 or so and then give it a few
    beans just to listen to that exhaust note.
  15. TOG@Toil
    A.Lee Guest
    There may be some truth in that. When Fast Bikes was a good mag, they
    did a comparison with a pair of Fireblades, one was mollycoddled by its
    owner, run in 'properly' etc. The other was thrashed from day 1.
    The thrashed one gave around 5bhp more iirc, along with a slightly
    higher top speed.
    Obviously not scientific proof, but the theory was that engines are so
    well put together now, that the 'running-in' process is no longer needed
    - all components are a good fit to each other, whereas older engines
    suffered from slack tolerances, so componenets needed to bed in to get
    them running well.
    Alan.
    A.Lee, Apr 3, 2009
  16. TOG@Toil
    TOG@Toil Guest
    On 3 Apr, 16:56, a...@darkroom.+.com (A.Lee) wrote:
    Ahem. Tight tolerances, not slack.
  17. TOG@Toil
    SD Guest
    Yeah, right.
    SD, Apr 3, 2009
  18. TOG@Toil
    SD Guest
    Sixty? I thought it was supposed to be some kind of big, powerful,
    motorbike.
    SD, Apr 3, 2009
  19. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    In fairness, depicting fucking great farmers hanging out in ASCII art
    was always going to be a challenge.
    It's probably best left to the imagination of the reader.
    Wicked Uncle Nigel, Apr 3, 2009
  20. TOG@Toil
    boots Guest
    Or not, as the case maybe.
    boots, Apr 3, 2009
