TV Coverage in the USA
Discussion in 'Motorcycle Racing' started by Julian Bond, Jan 28, 2009.
  1. Julian Bond
    Julian Bond Guest
    With all the messing around from Dorna, WSB and DGM will there be some
    half way reasonable TV coverage in the USA this year? Or are you all
    expecting to watch it on the web?
    We've been screwed over in the UK by the French and German national TV
    companies. In order for Dorna to get a contract in those regions for
    free to air TV, they demanded that MotoGP is not shown on Eurosport (Sat
    and Cable). So we're left with the BBC showing less coverage with poorer
    commentators and some of the coverage on the digital button side
    channels where you can't record it. When all that was done, the French
    then reached an agreement to allow Eurosport France to go ahead anyway.
    The good side of all that should be increased coverage of WSB and BSB on
    Eurosport.
  2. Julian Bond
    Switters Guest
    That's not true. I've recorded stuff on the interactive channels no
    problem. The issue is that the EPG that's broadcast doesn't always
    contain the correct timings, so it can be hit and miss when setting up the
    recording in advance.
    That doesn't suprise me at all.
    Let's hope so.
    Actually I'm hoping that Whitam/Burnicle will do BSB (like they did last
    year), and Moody/Rhyder will do WSB instead of that annoying stand-in pair
    they had last year - but full time as well. I suspect Mamola will stick
    to the MotoGP paddock somehow. Maybe working for TVE?
    Switters, Jan 28, 2009
  3. Julian Bond
    Julian Bond Guest
    There's a rumour that Freeview 301 and 302 carry the BBC Red button
    channels. But that you never know which one. I was talking about Sky+
    and Virgin+ customers; the people who bought sat or cable so they could
    get Eurosport. And they can't record programs on the red button. I
    believe (but I'm not sure) that even if you hook a recorder up to Sky
    and Virgin (the non PVR versions) you still can't record it.
  4. Julian Bond
    Switters Guest
    Not a rumour. It's fact.
    That depends on the EPG that's pushed out, but it was about 25% success
    rate when I tried it at the end of last season. The commentary team are
    also different, and better (than the "normal" BBC lot).
    Sure, it's a degredation in service compared to what we're used to.
    Question is, what are you going to do about it?
    I've the standard (non-PVR) service from Virgin, and I can record from the
    red button if I happen to be there, switch to interactive, then hit record
    on whatever device. Obviously that limits the usefullness greatly.
    In my case though I'm often in at 8-9am Sunday mornings so I can set up
    the recording, then go out to play. I generally watch the races in the
    evenings.
    Surely for sure, I'm really pissed off at Dorna et al for dropping
    Eurosport. However, I've spent time looking at how I can work around the
    issues. In my case, I didn't want to get a new TV with freeview built in,
    so I went and bought a PVR.
