Turnpike and Win7
Discussion in 'UK Motorcycles' started by geoff, Feb 1, 2010.
  1. geoff
    geoff Guest
    I've been using turnpike for years without problem
    worked with every win OS so far - including Win7 RC
    So I've gone out and spent real money on Win7 home - does it work with
    that? Does it buggery
    So it looks like I'm going to have to try and run XP as a virtual
    machine, so I'll need an XP key to run it
    Anyone got migrated to Win7 and got one going spare ?
    geoff, Feb 1, 2010
  2. geoff
    Adie Guest
    I gave up after trying to get it to work wit vista.
    Adie
    UKRM FAQ: http://www.ukrm.info/faq/
    YZF-R1 : FZ1N : RD350LC
    (anyone would think I was partial to Yamahas)
    keeper of the FAQ for my sins
    MRO#11 BOTAFOF#7 BOTAFOT#130 DIAABTCOD#17 MIB#24 YTC#16
    BOB#15 ex-UKRMMA#22 BOMB#11
    Adie, Feb 1, 2010
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, Adie
    It works very well with Vista.
    Geoff, have you checked out demon.ip.support.tunrpike?
    Wicked Uncle Nigel, Feb 1, 2010
  4. geoff
    Ian White Guest
    Try running the install and/or running the program for the first time as
    administrator (Right-click "run as administrator").
    That's worked for me with legacy programs that "won't run on Win7". My
    guess is they need to write to the registry and Win7 won't let them.
    Ian White, Feb 1, 2010
  5. geoff
    geoff Guest
    Yup - seems there is an incompatibility there between win7 64 bit and
    turnpike
    Which was a surprise as it worked well with win7 RC
    The best recommendation I've come across seems to be to run XP as a
    virtual machine - not supported by win7 home
    I don't see why I should have to buy pro just to get over what has to be
    a relatively small problem
    geoff, Feb 1, 2010
  6. geoff
    geoff Guest
    Hmm, worth a try, thanks
    geoff, Feb 1, 2010
  7. geoff
    Mike Buckley Guest
    I'm running it on Vista - just. Every now and again totally randomly it
    stops updating the news spool files in the install directory and only
    updates them in the virtual store. Only fix is to reinstall, changing
    paths in the various config files makes no difference.
    Mike Buckley, Feb 2, 2010
  8. geoff
    'Hog Guest
    Is this home or business. For the former all the installations and keys you
    need are on Rapidshare.....
    'Hog, Feb 2, 2010
  9. geoff
    Or just leave Turnpike behind.
    What is this, 1995?
    ogden, Feb 2, 2010
  10. geoff
    Tim Guest
    VMWare?
    Tim, Feb 2, 2010
  11. geoff
    geoff Guest
    Home - I'll take a look, cheers
    Microsoft's reply fairly predictable and useless
    "Thank you for the system information, this morning I had a chat session
    with the Turnpike Technical Agent and I asked them whether Turnpike
    email client is compatible with windows 7 or not and they said Turnpike
    is not compatible with windows 7. "
    geoff, Feb 2, 2010
  12. geoff
    prawn Guest
    Srsly: What Ogden said. I don't say this lightly as Turnpike users seem
    to be the most loyal users ever - but if it's getting this bad now, it
    will only get worse later.
    prawn, Feb 2, 2010
  13. Apparently it has problems with 64 bit versions. the latest Turnpike
    (6.06) works fine with 32 bit versions so I'm told.
    One reason I've stuck with WinXP is that I'm rather taken with my TP and
    would like to keep it; I've yet to find anything that will touch it for
    the way I use it as I have a server running connect and I log into TP
    from other machines as I see fit and it all just works.
    I've not had anything I need to do that means I have to upgrade - no
    doubt the day will come.
    Steve Fitzgerald, Feb 17, 2010
  14. geoff
    Greybeard Guest
    I've got some at work that I collect from scrapped machines.
    If you can wait, I'll try and remeber to bring some home and email tomorrow
    evening.
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy 2!)
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Feb 17, 2010
  15. geoff
    geoff Guest
    At the moment, I'm using the win7 machine to look at another one using
    remote desktop
    Not ideal, but it works for the moment
    So no great rush as plan B is working
    email is valid
    geoff, Feb 17, 2010
  16. geoff
    geoff Guest
    I just didn't anticipate a problem, as the RC worked fine
    geoff, Feb 17, 2010
  17. geoff
    I'm glad[1] I read the whole thread before replying to the OP.
    [1] well, not "glad" exactly.
    darsy, Feb 18, 2010
  18. geoff
    davethedave Guest
    Anon! Is that you?
    davethedave, Feb 18, 2010
  19. geoff
    Ar you that bored that you're re-reading threads from two weeks ago
    then?
    Ace, Feb 18, 2010
  20. geoff
    I blame Steve Fitzgerald.
    darsy, Feb 18, 2010
