Turning The TW200 Into A Street Bike (Mostly)
Discussion in 'Motorcycle Technical Discussion' started by Bill Miller., Aug 9, 2008.
  1. Bill Miller.
    paul c Guest
    steve wrote:
    First, being a Canuck, I have to say that many here feel the same way
    about the USA as the Swiss feel about Germany, so I'm not being pro-Yank
    when I say that at least one of those incidents, the Gimli Manitoba one,
    might have had just as much to do with Air Canada and Transport Canada
    bureaucratic bungling as the nationality of the plane that made the
    remarkable landing. In bureaucratic bungling, I'd say Canada takes a
    back seat to no one, including the USA, so there.
    paul c, Aug 15, 2008
  2. Bill Miller.
    snip>
    Buy a set made to order.
    You could bore out the top but I wouldn't imagine 996 yolks have a
    lot of extra meat on them to allow you to open them out by 3mm so you
    could potentially weaken them and 1mm is a bit small to sleeve though
    you could theoretically get a band of HCP put on them to take this up.
    Andy Bonwick, Aug 15, 2008
  3. You really need to check the x-posts.
    The Older Gentleman, Aug 15, 2008
  4. coo, ta. Just the think for dunking in me coffee.
    Austin Shackles, Aug 15, 2008
  5. Bill Miller.
    Sn!pe Guest
    I liked this one:-
    "Sixpenny Handley; n.; a very short time with a prostitute."
    Sn!pe, Aug 15, 2008
  6. In here, we'd say "Cloff!" at this point.
    which, for them as are not regulars of the outbuilding is shorthand for
    "Would you mind passing me that cloth, so that I can wipe the coffee and
    biscuits that an burst of mirth caused me to involuntarily expel onto it"?
    OWTTE.
  7. Bleddy hell! I first handled L1A2 ammo back in the '60s but I
    never made that connection. I knew it was as close as dammit is to swearing
    to 0.303" but never realised it was exactly 0.3".
    Dr Ivan D. Reid, Aug 15, 2008
  8. Bill Miller.
    Wouldn't it just be easier to buy a set of yokes designed for the forks
    and fit the whole lot to the ST4S
    Lozzo, Aug 15, 2008
  9. Bill Miller.
    bobharvey Guest
    Kg/cm^2 surely?
    bobharvey, Aug 15, 2008
  10. Bill Miller.
    Yeah Ducati John and myself thought it was a lot to take out.
    I may get a set from eBay to try but TBF the whole ignition
    lock/immobiliser/steering lock thing is complicated. They may also have
    a different trail.
    Any good sources for getting yokes made to order? replicating the ST
    yokes with a different staunchion ID.
    Hog, Aug 15, 2008
  11. Bill Miller.
    In French it's a thumb.
    _______
    Ace, Aug 15, 2008
  12. Bill Miller.
    Bill Miller. Guest
    On Aug 13, 11:07 pm, (The Older
    Gentleman) wrote:
    <the usual goofy slobber from TOG> snipped
    Bill Miller., Aug 15, 2008
  13. Bill Miller.
    Bill Miller. Guest
    <yawn, double yawn, triple yawn> snipped
  14. Bill Miller.
    Bill Miller. Guest
    <nothing of interest or value> snipped
  15. Bill Miller.
    ogden, Aug 15, 2008
  16. Bill Miller.
    Switters Guest
    And this is news to whom exactly?
    Switters, Aug 15, 2008
  17. Bill Miller.
    Bill Miller. Guest
    On Aug 14, 11:15 pm, (The Older
    Gentleman) wrote:
    ferniessss are passsssing out cyberbiscuitsssss and boassssting of
    their endowmentsss...
  18. Bill Miller.
    Sn!pe Guest
    Coo, there's po-faced for you.
    Sn!pe, Aug 15, 2008
  19. Bill Miller.
    Bill Miller. Guest
    On Aug 14, 12:00 pm, (The Older
    Gentleman) wrote: ........but left me with a dry throat.
    So why don't you head for a mens restroom and quench your thirst?
  20. Bill Miller.
    God knows. I just get the impression that if if the shedde were a
    physical entity, there'd be a sign over the door saying "You don't have
    to be mad to work here..."
    ogden, Aug 15, 2008
