Turning The TW200 Into A Street Bike (Mostly)
Discussion in 'Motorcycle Technical Discussion' started by Bill Miller., Aug 9, 2008.
  1. Bill Miller.
    NickNoxx Guest
    My sons, age 19 and 15 were just discussing the length of something and
    one asked me "How many inches are there in a metre?"
    NickNoxx, Aug 14, 2008
  2. Bill Miller.
    SaladDodger Guest
    In what universe?
    SaladDodger, Aug 14, 2008
  3. Bill Miller.
    Eddie Guest
    (25.4 mm/in) / (7.62 mm) = 3.33333333/in
    You might want to try that the other way up.
    Eddie, Aug 14, 2008
  4. Bill Miller.
    . Guest
    Actually, The Older Gasbag is hoping that some desperate talent scout
    will discover him on Usenet and hire him to do a standup comedy
    routine...
    ., Aug 14, 2008
  5. Bill Miller.
    bobharvey Guest
    Hello Mr Becker, Hello Mr Toil. Did you bring some biscuits?
    bobharvey, Aug 14, 2008
  6. Bill Miller.
    Well of course my hidden question related to MV's!
    Out of interest. I have a set of 996 forks revalved by K-Tech with
    radial bottoms/calipers fitted. Thing is the top/bottom yoke diameters
    are different to my ST4S. Top yoke 3mm smaller, bottom 1mm bigger. I'm
    rather bemused at how to go about mating the bike to the forks, short of
    a complete custom yoke set which i assume would be tres expensive.
    Ideas?
    Hog, Aug 14, 2008
  7. <Waves HobNobs packet>
    The Older Gentleman, Aug 14, 2008
  8. Bill Miller.
    Alex Ferrier Guest
    Ah. That would be the same dylsexic universe where
    one performs a 360° turn and ends up travelling in
    the opposite direction.
    Alex Ferrier, Aug 14, 2008
  9. Bill Miller.
    YT*T*C
    _______
    Ace, Aug 14, 2008
  10. Bill Miller.
    bobharvey Guest
    Right, the kettle's on. It has boiled already but I was busy reading
    old favourites in the faqs, and got distracted and ended up at
    http://www.jasperfforde.com/phorum/read.php?1,4809 reading the
    liffings. I'll light the gas again.
  11. Bill Miller.
    SD Guest
    I can't believe what I'm reading.
    Is this something to do with your 180 degree circles, or a new
    mathematical insight?
    SD, Aug 14, 2008
  12. I need a cuppa. This thread went OT from one on reeky, where some nutter
    decided that he'd quote a dictionary definition to make his point, and
    was silly enough simply to make it up himself and get caught at it.
    Wonderfully sad, but left me with a dry throat.
    <Sips>
    Better now, thanks.
  13. Bill Miller.
    . Guest
    Try hemlock. It's very soothing to the nerves, yannow.
    ., Aug 14, 2008
  14. Bill Miller.
    bobharvey Guest
    Worral-thompson? Is that you hiding behind a full stop?
  15. Bill Miller.
    geoff Guest
    In message
    and the inch is a "Zoll"
    geoff, Aug 14, 2008
  16. Bill Miller.
    Bernard Peek Guest
    Ooooh. This one's a keeper.
    Bernard Peek, Aug 14, 2008
  17. Bill Miller.
    . Guest
    ., Aug 14, 2008
  18. Bill Miller.
    steve Guest
    TOG@Toil wrote:>
    At 49 years old, anything, really. I worked with both metric and
    imperial measures in school but then worked solely in metric when I went
    to Tech College to do engineering in 1975 when the metric system really
    started to kick off.
    I work in Bar with tyres, litres with fuel and oil, kW for engine power,
    and am quite happy working with miles or km for distance and mpg or
    litres per 100 km for fuel consumption. Height \ weight I now work in
    metric - that was the last "bastion" of the old system for me.
    The real benefit is being able to compare like for like.
    A bike engine is rated in kw like an electric motor, like a
    refrigeration system, like a power generation plant so it is easy to
    work out energy in \ out figures and make comparisons.
    Fuel energy is in joules, power is joules over a period of time and so
    on. A seamless system that saves a lot of messing about, and potential
    mistakes, when working stuff out.
    Bar is a kg\cm pressure that converts easily into force of Newtons per
    sq mm so you can easily work out fluid pressures and involves little
    more than moving the decimal point in the correct direction.
    I get the impression that, over time, the imperial system will die, as
    more young people use it. The EU won't have to legislate.
    Even the Americans will have to come round eventually like the rest of
    the industry does.... and maybe stop planes falling out the sky when the
    pilot does the sums wrong when he orders his fuel in litres but works
    out the comsumption in gallons (or even US gallons ffs)....
    Like working in foreign languages, if insist you have to convert, you
    are making life difficult, just use the system "as is"
    Steve
    steve, Aug 15, 2008
  19. Bill Miller.
    Eddie Guest
    Less^W Fewer, surely?
    Eddie, Aug 15, 2008
  20. Bill Miller.
    crn Guest
    Errrm - Airliners load fuel in tonnes (metric ton = 1000kg) which are
    almost the same size as imperial tons.
    crn, Aug 15, 2008
