Turbos
Discussion in 'UK Motorcycles' started by WavyDavy\(Mobile\), Sep 7, 2006.
  1. I'm not exactly a mechanical numpty (well not on the theory side, anyhoo)
    but, as befits someone of my calibre (i.e. someone who does **** all each
    day and occasionally lets their mind wander onto totally pointless stuff in
    oder to take up a bit of the day), I was thinking about turbos today (obv
    wasn't too clever to let the mind wander too much when the subject popped
    into my head as i was driving my turbo (allegedly) diesel car and I was in
    too high a gear and **** all happened when i stood on the 'go' pedal..).
    I know how they work.
    I understand the physics and mechanics of their operation *when_running*.
    But I got thinking that I relly don't know how/why turbos start up at
    certain rpm.
    Is it a friction thing? I.e. does there need to be enough gas pressure to
    start up the exhaust side?
    Or is it an electronics thing? I.e. the gases are routed away from the
    turbo until a certain rpm?
    Or is it something else that prevents a turbo from acting like a
    supercharger and providing a bit of boost at all rpm?
    Just curious.
  2. WavyDavy\(Mobile\)
    Steve Parry Guest
    I'm probably wrong, but my understanding is they're actually an obstruction
    in the airflow until they reach a critical mass point at which point they
    then function as intended forcing the charge in.
    Steve Parry, Sep 7, 2006
  3. It's because they're bugger all use under a certain rpm and act more
    like a restricter than a booster. It's in the nature of the beast, being
    a centrifugal impeller for light weight and fast spin-up, but until
    there's a decent quantity of zorst gas banging past the blades, the
    effect on the input is negligible.
    Grimly Curmudgeon, Sep 7, 2006
  4. WavyDavy\(Mobile\)
    WavyDavy Guest
    Ta,
    I (sort of) had guessed that bit - otherwise they *would* be used all the
    time.
    But I still want/need to know - what stops one from working below the
    optimum start-up revs/gas-flow etc? *That* is the big question.
    WavyDavy, Sep 7, 2006
  5. WavyDavy\(Mobile\)
    Bod43 Guest
    It's just like jumping off the kerb - and then jumping off
    portland bill.
    When you jump of the kerb there is not
    enough energy to do you any harm when you
    reach the road 6" below.
    When you jump off Portland Bill on the other hand
    there is more energy available when you reach the bottom.
    At low speed there is not enough exgaust in the turbine
    to make it do much. Of course as the power builds up
    there is more gas which makes more power which makes
    more gas which makes more power until .....
    The engine melts.
    Which is why 'big' turbo installations need a waste gate.
    If the turbo is little compared with the size of the engine
    then maybe the waste gate is not necessary.
    I think:
    One way to think of a turbocharged piston engine
    is that it is really a Gas Turbine with some pistons
    getting in the way as opposed to the usual model
    which is of a gas turbine helping out a piston
    engine a bit.
    Bod43, Sep 7, 2006
  6. WavyDavy\(Mobile\)
    WavyDavy Guest
    As per my other response. OK, so they aren't blanked off or anything. But
    what stops the gas flow from the exhaust at, say, 3000rpm on a bike turbo
    turning the exhaust side, thus (supposedly) improving airflow on the inlet
    side (is it better for the blades to be completely still at low revs or
    turning slightly on the inlet side?) when the pressure from a TDi car starts
    the boost at as low as 1500 rpm (and possibly lower as I see FIAT make a
    1300TDi that produces max torque at 1500rpm, so I guess the turbo starts up
    earlier....)
  7. WavyDavy\(Mobile\)
    Pete Fisher Guest
    Same thing as stops me working sometimes - inertia.
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Sep 7, 2006
  8. WavyDavy\(Mobile\)
    As has been said, they get more efficient the faster they spin. They
    can be tuned to a limited extent by varying the relative proportions
    of the "snail shell" and the impeller and turbine. I can't remember
    the details (I read it somewhere) but they can be tuned for faster
    response at lowr revs or higher boost at high revs, but not both.
    The reason that they lag is because at lower revs there simply isn't
    the drive from the turbine to overcome the rotor's inertia. Remember
    it has to vary by tens of thousands or RPM in order to keep up with
    the engine.
    Back in the days of turbo'd F1 cars, they apparently had a cunning
    scheme to keep the turbo revs up.
    I'm not totally sure, but I *think* a bypass could be opened when the
    car slowed for corners; at the same time surplus fuel was injected
    (somewhere) so that it sort of ran like a gas turbine, thus keeping
    the revs up ready for accelerating out of the corner.
    Pip Luscher, Sep 7, 2006
  9. WavyDavy\(Mobile\)
    Pete Fisher Guest
    In communiqué <>, Pip Luscher
    Bad form etc. but see:
    http://www.rallycars.com/Cars/bangbang.html
  10. WavyDavy\(Mobile\)
    Chris Dugan Guest
    And recently VW have released a 1.4 engined car with both a supercharger and
    turbocharger... the supercharger gives the car a boot at low revs and then
    the turbo takes over at higher revs. Supposed to produce about 160bhp, not
    bad for a modern car especially as they're putting it into a Golf chassis!
    Chris
    Chris Dugan, Sep 7, 2006
  11. WavyDavy\(Mobile\)
    Dr Zoidberg Guest
    Between 140 and 170 depending on tune.
    And it'll be in the next generation Polo/Fabia/Ibiza
    Dr Zoidberg, Sep 7, 2006
  12. WavyDavy\(Mobile\)
    Pete Fisher Guest
    All this talk of turbos made me remember the 500 Morini turbo prototype.
    On that a 'distributor' allowed a single carb to feed the motor directly
    below 2000 rpm and featured the only intercooler on a motorcycle turbo
    setup of that era. Interesting article here:
    http://www.motomoriniclub.nl/turbo.html
    70 BHP from a 500 V twin in 1981 and 140 from a fuel injected 1200 V
    twin in 2006 - 25 years of Lambertini logic.
  13. WavyDavy\(Mobile\)
    SteveH Guest
    And it's a right **** if you stall the turbo, as the lag effect seems to
    last forever.
    SteveH, Sep 7, 2006
  14. That's what I wated to know.
    They spin, but are shit below whatever revs they're designed to operate
    at...
    Ta
  15. Why are you replying to me? I know all about leaping off pavements.
    And snip sigs, ffs.
    Grimly Curmudgeon, Sep 8, 2006
  16. Exactly, and if you want useful air flow at lower speed you need a
    bigger turbine [1]- then you run into problems of severe lag with it
    having much more mass to spin up. Like so much else, it's a compromise.
    [1] Yonks back I experimented with a 6" centrifugal blower run by an
    electric motor and plumbed into an A-series lump with a pressurised
    carb. Shit, it was - but it would probably have worked ok on a
    stationary engine at a set speed.
  17. WavyDavy\(Mobile\)
    Eiron Guest
    It probably worked better than the Austin Metro Turbo.
    That had no noticable lag but only because the turbo had no noticable effect.
    Eiron, Sep 8, 2006
  18. WavyDavy\(Mobile\)
    Pete Fisher Guest
    Yes - if you are talking about improving all round performance and
    reducing lag by using sequential turbos.
    Pete Fisher, Sep 8, 2006
  19. WavyDavy\(Mobile\)
    At this point, I find myself I wondering why anyone'd bother with a
    turbo when they could use a supercharger.
    ogden, Sep 8, 2006
  20. WavyDavy\(Mobile\)
    Eiron Guest
    It's supposed to be more efficient. A supercharger takes power from the
    crankshaft. A turbocharger takes power from the exhaust gas, which would
    otherwise be wasted.
    Eiron, Sep 8, 2006
Similar Threads
Loading...
