Turbo Update
Discussion in 'Classic Motorbikes' started by mike. buckley, May 18, 2006.
  1. Pictures of the bike I bought:
    http://www.toastyhamster.plus.com/turbo1.JPG
    http://www.toastyhamster.plus.com/turbo2.JPG
    http://www.toastyhamster.plus.com/turbo3.JPG
    http://www.toastyhamster.plus.com/turbo4.JPG
    and after:
    http://www.toastyhamster.plus.com/myturbo1.JPG
    http://www.toastyhamster.plus.com/myturbo2.JPG
    Jobs done include tank/mudguard spraying, lots of engine case painting,
    530 chain conversion.
    Jobs to do include sorting front brakes (need a front master cylinder),
    sorting oil leak from clutch case, valve clearances and throttle
    balancing. Oh and fitting the new plate I have.
    Runs ok - just doesn't stop.
  2. mike. buckley
    Gyp Guest
    Can we get all the Kawa 750s together and find out which one accelerates
    fastest down hill?
    Gyp, May 18, 2006
  3. I can foresee a report of a Richter 5.0 disturbance....
    The Older Gentleman, May 18, 2006
  4. mike. buckley
    Gyp Guest
    In message
    Down hill the Turbos will be off-boost and moving like slugs.
    If it was an up hill race there would indeed be a risk of tsunami.
    Gyp, May 19, 2006
  5. The digicam flatters it, but it's getting there.
    The guy I bought it off had a full set including the link pipe - so I
    snapped them up. There were also a set on ebay a week or so ago - they
    went for 50 quid plus postage.... I think you can still buy them new,
    I've not checked but I've heard they're 1200 a side!
    The C+S were pretty knackered, and the 630 stuff was more expensive and
    harder to find, so I went for the 530. ZX9R front sprocket and B+C had a
    rear in stock. Interestingly modern 530 chain has a higher tensile
    strength than the stock 1980s 630, plus it's a lot lighter and cheaper,
    so no reason to stick with the 630.
    I originally tried Smoothrite but got really fucking fed up with it
    reacting, so stripped it off and used cheapo Halfords grey primer and
    black gloss, has come up pretty well - have to see how it wears. Still
    have the offside covers to paint. Fitting stainless fasteners as I go.
    Damn fine idea.
    mike. buckley, May 19, 2006
  6. mike. buckley
    Avebury?
    sweller, May 19, 2006
  7. Halford aerosols, but they're not fuggin cheap - fiver a can I think.
    As for masking - hah - well the rotor cover and the front sprocket cover
    come off easily enough, so I stripped them off the bike. The right hand
    side is trickier, especially as I have what looks like a glued on piece
    of crankcase on the front cover. That's on my to-do list as well. The
    clutch cover looks do-able with masking it up - but mines leaking so
    I've got a new gasket for it, think it was about a tenner (for a gasket
    ffs!) so will do it while it's off. I also need to check the clutch, the
    clutch lever is very stiff, so it could be on stock clutch with heavy
    duty springs which means it's been slipping at one point.
    Avebury sounds do-able, have spent hardly any time on a bike in last
    couple of years, so any excuse for a trip :)
    You have mail btw.
  8. mike. buckley
    I think he might have been referring to a _steep_ hill. A _very_ steep
    hill.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, May 19, 2006
  9. mike. buckley
    Mike Buckley Guest
    Nah, came from a guy in Brum, and he bought it off someone that was
    selling 2, 1 in good nick but US spec.
    Mike Buckley, May 20, 2006
