tuneup question
Discussion in 'Motorcycle Technical Discussion' started by Larry Blanchard, Sep 2, 2006.
  1. I'm looking at an older bike that's been sitting for two years. Current owner
    says it runs fine, except that it wants to die when downshifted. Ran fine
    all the time before the two years in storage.
    I'll admit to not being much of a mechanic, but why only then? If the carbs
    were gummed up I'd expect trouble all the way around.
    BTW, I've heard that automotive carb cleaners shouldn't be used on
    motorcycles. Is this true? If so, is there a product that does work or do I
    have to disassemble and do a manual cleaning?
    Thanks for any help. I'm going to see the bike Monday or Tuesday and if the
    downshift problem is an indicator of something serious it's be nice to know
    before then :).
  2. Larry Blanchard
    B-12 Guest
    Consider the development of the motorcycle carburetor. During the
    1920's through the 1960's, it was a crude plumbing device that barely
    mixed air and the gasoline into digestible droplets that the ignition
    system could light off.
    In the mid-1960's, Mikuni and Keihin began building carburetors that
    pre-mixed air and gasoline by means of tiny air holes cross-drilled in
    the tiny idle jets and the main jet holders.
    The result was a carburetor that was very responsive to small throttle
    openings, unlike the cruder Amal carburetors that would either suck too
    little or too much fuel into the cylinders when the throttle slide
    lifted.
    And then along came the Environmental Protection Agency, with their
    clean air obsession. Though motorcycles only constitute about 5% of all
    registered vehicles, and only a fraction of a percent of all
    motorcycles are in daily use, the EPA mandated that motorcycle
    carburetors have their idle mixture screws set so the idle mixture was
    too lean for easy starting, quick warm up and good throttle response.
    Then the idle mixture screws were sealed behind anti-tamper plugs so
    the owner couldn't adjust the idle mixture screws. The result was a
    carburetor that is intolerant of the slightest amount of gum and
    varnish in the tiny idle jets and idle mixture passages.
    And, the modern constant vacuum carburetor equipped motorcycle is
    ridden at about 1/8th to 1/4th throttle 95% of the time, so it has to
    run on the idle jets and needs clean passages.
    Try adding 4 ounces of Berryman's B-12 Choke and Carburetor Cleaner to
    a full tank of gasoline and go for a slow ride to make the engine suck
    the B-12 through the gummed up passages.
    I've been using B-12 for 30 years now on all my motorcycle carburetors.
    It costs less than $3.00 for a 15 ounce can of the liquid form or the
    aerosol form, which is handy for cleaning disasembled carbs.
    You'll know that the B-12 is working when the idle RPM increases when
    you slow down to stop.
    It's just dirty carburetors, Larry. You'd be amazed at how fast
    carburetors gum up here in the San Joaquin valley, where the
    temperature gets up to 100 degrees everyday in the summer.
    B-12, Sep 2, 2006
  3. My lawnmower was built in 1969 and has no tamper plugs but it
    still gets gummed up every winter if I leave the gas in it, the idea that
    the anti-tamper plugs are somehow causing gas to varnish up
    carbs is preposterous. If you let gas set for 2 years in an unsealed
    container - which is what a carb bowl is - it's going to varnish it up,
    tamper plugs or not.
    Try adding a 3rd to a half of a bottle into about a gallon of gas in the
    tank, then run the bike until the tank is empty, then refill with the gallon
    of gas your carrying with you in a gas can and ride to a gas station and
    fill up.
    Ted
    Ted Mittelstaedt, Sep 2, 2006
  4. Larry Blanchard
    monk Guest
    I think that what B-12 is getting at here is that you're more likely to
    notice crap in your carb becuase you will always be running off the pilot
    jet and needle jet which are smaller and more finnicky than the main jet.
    monk, Sep 2, 2006
  5. Larry Blanchard
    B-12 Guest
    The idea couldn't be TOO preposterous, you thought it, didn't you?
    No, the point is that modern motorcycle carburetors have tiny jets and
    idle mixture passages, and the adjustment screws are hidden behind
    anti-tamper plugs.
    If the screws weren't hidden, amateur mechanics could adjust the screws
    to allow just a tad more gasoline to flow through the outlet ports and
    the carbs would tend clean themselves out as the machine was ridden.
    B-12, Sep 2, 2006
  6. Thanks to you all. I can now make an offer on the bike without worrying about
    the "dying on downshift" problem.
    BTW, the reason I'm looking is that my current ride, an old Yamaha SR500, has
    developed a carb overflow problem that nobody can find. Someday when I've
    got time, I'll list all the things that have been tried :).
  7. Larry Blanchard
    B-12 Guest
    I found that the float bowl overflow problem on my KLR600 was caused by
    a tiny bit of
    gum on the float valve seat. I had to use a magnifying glass to see it,
    and I cleaned the seat with a bit of emery cloth on the end of a
    stick...
    B-12, Sep 2, 2006
  8. Larry Blanchard
    checkers Guest
    I have been trying to get a good setting on my 85 VT1100. According to the Honda
    shop manual the initial setting is 3 turns out. I did this after removing the
    anti-tamper plugs. I followed the instructions in the manual regarding proper
    adjustment from the initial setting. I used a tach and set the left carb first
    and the right carb second per the instructions. I am still having problems with
    hesitation even after using the B-12. I've had several bikes in the past and
    none of them caused me this sort of grief. I had an 81 Yamaha 650 Special, an 82
    GL500 Interstate and two 83 V-45 Magnas. I bought an 85 VT700 two years ago and
    it had the same problem although not quite as bad. I was eventually able to get
    it running good. I sold it and bought the 1100 last fall. I like the 1100's ride
    but the hesitation is very annoying. I've asked several owners of 85 1100's if
    they have experienced the same thing and no one else has admitted to
    experiencing this problem. Anyone have any suggestion? TIA
    checkers, Sep 4, 2006
  9. Larry Blanchard
    B-12 Guest
    Assuming that the carburetors are cleaned out sufficiently, I recommend
    raising the fuel level in the float bowl by 1 millimeter. That would
    cost nothing except your labor.
    Since float levels are adjusted with the carburetor upside down on the
    bench, if the specified float level was, say, 14 mm plus or minus 1 mm
    from the bottom of the float (which is on top when the carbs are upside
    down) to the carburetor body gasket surface
    (that's the aluminum surface of the carb, not the gasket), then you
    would set the float level at 13 mm instead of 14 mm.
    If that doesn't work, you might try installing idle jets that are one
    or two size larger, assuming that they are available for your carbs.
    They would cost about $5.00 each.
    I haven't looked up the jet size information on bikebandit.com or
    partsfish.com, but the shop manual recommendation of 3.0 turns out
    would make the stock idle jet size about
    # 35 or # 37, so you might try a # 40 or # 42 if they are larger.
    Mikuni and Keihin jets for constant vacuum carburetors have holes that
    are based upon
    a # 100 round jet being 1.0 mm in diameter, so a # 40 idle jet has a
    hole that is 0.40 mm in diameter.
    You can see that the area of the hole would vary as to the square of
    the radius of the orifice hole, like the area formula you learned in
    high school algebra class, and the holes become so much larger so fast
    the correct setting for the idle mixture screw rapidly becomes less and
    less to the point where a carburetor with a # 45 idle jet requires the
    idle mixture screws to be open only about 1/4 of a turn maximum.
    B-12, Sep 4, 2006
