TRX850 indicator
Discussion in 'Australian Motorcycles' started by Fat Crack Ho, Feb 8, 2004.
  1. Fat Crack  Ho
    Fat Crack Ho Guest
    I've got a problem with my left front indicator. When the left is turned on,
    the rear flashes faster that it should. I've checked the bulb and it's fine.
    The indicator signal isn't making it to the front left bulb The right side
    indicators work properly. How is the indicator wired up? The relay I found
    only had two wires going into it.
    thanks.
  2. | I've got a problem with my left front indicator. When the left is turned
    on,
    fine.
    side
    found
    | thanks.
    Hi Ho,
    I would try swapping the rear lamps with other, and see what happens.
    If you are just looking at the filament that can be a trap.
    A relay would need 4 connections to be a relay, less depending on internal
    bridging arrangements. 3 if the coil return and 1 switch contact are both
    connected to one battery polarity connected to the frame earth, and the
    metal relay case or terminal is bonded to the frame's metal surface.
    This diagram is not a working indicator circuit, just a 2 terminal relay.
    + pos--- lamp ---- ----/ ---|-------coil----- + pos from indicator
    sw
    relay sw |
    |- ve to frame
    Rob
    Getting Slower & Slower !, Feb 8, 2004
  3. Fat Crack  Ho
    Eh?
    Obviously your FRONT left bulb is blown. (or the wire is dicky).
    The rear is working as it should.
    Knobdoodle, Feb 8, 2004
  4. Fat Crack  Ho
    John Littler Guest
    Yer bulbs blown on the front, change it.
    JL
    John Littler, Feb 8, 2004
  5. I'm sure someone will point out that you have a blown globe. Maybe Manning?
    Hammo
    Hamish Alker-Jones, Feb 9, 2004
  6. He deserved it!!
    (or are you just pissed off cos I didn't show up to be tricked by your
    novelty door bell)?
    Hammo
    Hamish Alker-Jones, Feb 11, 2004
  7. He's already been tricked into crossposting to aus.cars once... if anything,
    he's got a transgression_credit._
    And I programmed it with the dance version of Coldplay's "Clocks" 'n' all...
    Intact Kneeslider, Feb 11, 2004
