Truckers
Discussion in 'UK Motorcycles' started by frag, Jul 6, 2005.
  1. frag
    You silly **** :)
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jul 6, 2005
  2. frag
    zymurgy Guest
    <VBG>
    Mate of mine called his Italian landlord and said he could hear "beef
    fat" in his radiators.
    He'd looked up 'dripping' in his dictionary :)
    ... Cue one very confused Italian bloke !
    P.
    zymurgy, Jul 6, 2005
  3. frag
    Cab Guest
    Normally one would say "espèce de connard" which literally means
    "species of wanker/bastard"
    However, I misheard this the first time. So the first time I got cut
    up, I called the bloke a "species of duck" which raised an eyebrow.
    Cab, Jul 6, 2005
  4. frag
    Cab Guest
    Heh. Ah dearie me. Read the post again, YTC.
    Cab, Jul 6, 2005
  5. Oi!
    Oh, OK, point taken.
    How far from the narrows?
    Look, they're trying to get away from 'oop norf' as quickly as
    possible and don't need you getting in the way.
    OK, so a long way from the narrows.
    They're cunts and a disgrace to the profession.
    FWIW, if a car indicates, and if its safe, I'll let them in / out or
    whatever.
    If they don't indicate, especially coming off a slip road to the
    motorway (and many don't), they don't stand a chance of getting let
    in.
    Most have no idea what happens if they hit the loud pedal, i.e. the
    car accelerates in to the gap. Most panic and hit the brakes. Which
    leaves me shouting "Wrong pedal, Fuckwit!"
    I'm certain that 90% of car drivers do not realise that trucks are
    physically limited to 90kmh.
    So if they don't want to be hasseled by trucks, they should drive
    faster.
    ColonelTupperware,
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/ UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Jul 6, 2005
  6. frag
    PeterT@Home Guest
    Cab proposed
    Pretty much what I noticed when driving around the Peripherique
    recently. Another thing I wondered about is why do bikes seem to travel
    in packs? Is it that they get caught behind the bike filtering slowest,
    or is it some (sub)conscious safety in numbers thing?
    PeterT@Home, Jul 6, 2005
  7. frag
    Monz Guest
    I suspect you are omitting the bit about zipping past all the 1 mile,
    800yrd, 600yrd, 400... etc markers where all these trucking bastards have
    been patiently queuing to get through the lane restriction and then
    expecting them all to be jolly nice and let all the "clever" drivers back
    into the flow of traffic [1]
    [1] ICBW but it seems to be the norm for most car drivers
    If I am wrong please accept my apologies :eek:)
    Monz, Jul 6, 2005
  8. It's worked fine up to present date ;o)
    Dnc
    ZZR1100 - tagline being developed
    B1200 - +30bhp ~|~ VS800 - borked
    TS150 - squatting ~|~ V2300 - flat cap and rug
    Doesnotcompute, Jul 6, 2005
  9. frag
    frag Guest
    muddycat scribbled:
    He called me a yuppie! Woohoo! :)
    frag, Jul 7, 2005
  10. frag
    frag Guest
    Colonel Tupperware scribbled:
    I first clocked the signs at about a mile and misread them, thinking
    they said lane 1 closed, so moved into lane 3. Realised at about 800
    yards when I saw another sign.
    As if me doing 120 or so is going to hold them up for long. Point taken
    though.
    Yup. 99% of them are polite and have good road manners.
    I suppose it was a matter of luck that I'd come across about 6 bad
    tempered ones in a row all at once.
    Not as if it was busy either, light traffic, 1am-ish.
    Sounds fair. I wish a shed load more drivers knew what the orange bulbs
    on each corner were for.
    Really? I suppose the continental/irish trucks hammering along at 90
    kinda confuse them.
    frag, Jul 7, 2005
  11. frag
    frag Guest
    Monz scribbled:
    Accepted.
    Moved into lane 2 at 800 yds, indicated at maybe 700 yds and got
    blocked upto <200 yds.
    frag, Jul 7, 2005
  12. frag
    frag Guest
    K Olley scribbled:
    He says having a Volvo in his sig...
    frag, Jul 7, 2005
  13. frag
    frag Guest
    Petel scribbled:
    <shrug>
    See gap that I could fit in, just.
    Indicate left, wait for vehicle at back of gap to give me some more
    room so I can pull in safely.
    Not what I'd call aggressively cutting anyone up?
    frag, Jul 7, 2005
  14. frag
    K Olley Guest
    Yep, but mine has got more than 4 wheels:)
    Kevin - Basildon
    XV535
    VOLVO FH12
    GPZ305 (her's)
    BOTAFOT#67 BOTAFOF#23
    OSOS#29
    K Olley, Jul 7, 2005
  15. frag
    K Olley Guest
    All over the place.
    Some pull in way too early which slows the inner lane, others then push
    past and try to jam their way in way too late which also slows the total
    flow of traffic.
    If all lanes hold the same speed and just gently merge in the last 300 or
    400 yards then the total traffic speed remains faster, unfortunately this
    does not happen very often.
    The best example of this you will see is when a couple of trucks hold back
    the queue jumpers and the traffic flow increases until they merge and the
    queue jumpers start again.
    Kevin - Basildon
    XV535
    VOLVO FH12
    GPZ305 (her's)
    OSOS#29
  16. frag
    K Olley Guest
    Forgot to mention It has also got a 30 tonne capacity "boot".
    Kevin - Basildon
    XV535
    VOLVO FH12
    GPZ305 (her's)
    OSOS#29
  17. frag
    Ahh, I see where you're going wrong. Jude has the same problem. The simple
    solution is: If the gap's big enough, you move into it. Whether the car
    behind wants to give you _more_ of a gap, or not, has to be a secondary
    consideration.
    Wherein lies your problem. A little more 'positive' driving is what Sir
    requires.
    One man's 'positive' is another woman's 'aggressive'.
    _______
    Ace, Jul 7, 2005
  18. frag
    Cab Guest
    At least you didn't compliment her chatte. :)
    One of my friends couldn't figure out, for ages, why people would say
    'In winter' when leaving. I'll leave you lot to figure it out.
    Cab, Jul 7, 2005
  19. frag
    Cab Guest
    The first reason applies. It's always because there's some numpty at
    the head of the queue that can't/won't move in to let other bikes
    overtake.
    Though I think you're right in the safety thing though. Other bikes
    behind the 'leader' will tend to be in a better saftey position. It's
    not (IME) a subconcious thing though.
    Cab, Jul 7, 2005
  20. frag
    <thinks>
    heh.
    Champ, Jul 7, 2005
