Triumph to buy Norton!
Discussion in 'Classic Motorbikes' started by umgweb, Apr 25, 2006.
  1. umgweb
    umgweb Guest
    Looks like Norton America have run out of dosh and won't be doing the
    new Commando; surely one of the Asia motorcycle co's will buy the
    design - the latest rumour to hit our editorial desk, Triumph are going
    to buy the Norton name and do some sporting twins!
    http://umgweb.com
  2. umgweb
    TOG Guest
    You mean, that tarted-up warmed-over design that dates back to 1949?
    Why??? "Latest rumour" my arse.
    TOG, Apr 26, 2006
  3. umgweb
    A.Clews Guest
    Thus spake () unto the assembled multitudes:
    Oh goody, perhaps we'll be able to buy a Nemesis after all.
    A.Clews, Apr 26, 2006
  4. umgweb
    Tim Guest
    Someone took Rover, so it seems fitting.
    Tim, Apr 26, 2006
  5. Grimly Curmudgeon, Apr 26, 2006
  6. In uk.rec.motorcycles.classic, Grimly Curmudgeon belched forth and
    ejected the following:
    That's been wiped by a thousand arses.
    Whinging Courier, Apr 26, 2006
  7. umgweb
    Anton Gijsen said...
    There'll be a good reason why the Japanese never put a copy into
    production too.
    Lozzo, Apr 27, 2006
  8. umgweb
    Paul - xxx Guest
    Anton Gijsen came up with the following;:
    You think you'd be able to make it run longer than, what was it?, maybe 30
    minutes?
    Paul - xxx, Apr 27, 2006
  9. umgweb
    TOG Guest
    Didn't Ford mess with the concept for years? ISTR the Orbital engine
    that never saw production was a stepped-piston two-stroke....
    TOG, Apr 27, 2006
  10. umgweb
    Anton Gijsen Guest
    It's not as though the Japs are particuarly adventurous when it comes to
    weird n' wonderful engine configurations.
    Anton Gijsen, Apr 27, 2006
  11. umgweb
    Bob Scott Guest
    Do what?
    Singles - vertical, horizontal, sloping.
    Twins - flat, V, parallel, tandem & vertical.
    Triples - V & inline
    fours - flat, square, inline & V
    fives - V
    sixes - flat & inline
    rotary.
    So what weird 'n' wonderful configuration have they missed? Radial? The
    Brits did a wonderful example of that :)
    The Italians have done V6 & V8 bikes and the Germans did a flat triple
    but I can't, offhand, think of any engine configuration[1] used by the
    Brits that wasn't also used by the Japs.
    Bob
    [1] except for that bonkers radial & the distinctly bizarre Wooller
    twins & fours.
    Bob Scott, Apr 27, 2006
  12. You *what*?
    You've got to be trolling, surely?
    The Older Gentleman, Apr 27, 2006
  13. umgweb
    Tim Guest
    In message
    I think he must be.
    Tim, Apr 27, 2006
  14. umgweb
    Roger Hunt Guest
    (snip)
    (vague, probably erroneous recollection)
    Didn't Honda make a six cylinder 50cc racer in the Sixties sometime,
    that revved to something ridiculous, possessed ten gears, and had a
    power band of about 50 revs?
    Roger Hunt, Apr 27, 2006
  15. umgweb
    SD Guest
    SD, Apr 27, 2006
  16. umgweb
    SD Guest
    No. Suzuki made a 3 cylinder 50, but never raced it in GPs (the rules
    changed) - 19bhp, apparently. 14 speeds. RK67, iirc.
    Honda had an inline 5 cylinder 125. Yamaha a v-four.
    SD, Apr 27, 2006
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    You think?
    It has occurred to me that this wanker showed up shortly after the last
    troll (whose name I now realise escapes me) submerged. You know, the one
    who said he'd show up at BOSM... That one.
    *Anyway*, I reckon it's him. Again.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer
    Wicked Uncle Nigel, Apr 28, 2006
  18. umgweb
    Wicked Uncle Nigel said...
    It's an arsewipe, whatever it is
    Lozzo, Apr 28, 2006
  19. umgweb
    Roger Hunt Guest
    Assuming it had a drum selector, just imagine the stop falling off and
    going from 14th gear to first ...
    Ah thanks. I knew I was sort of on the right track with the idea of
    outrageous small Jap multis ...
    These other machines you mentioned must have been hair-raising, and
    I think I'll spend a while trawling the web for more details.
    Roger Hunt, Apr 28, 2006
  20. umgweb
    Jeremy Guest
    I was given a book recently - words as well as pictures - it talks of a
    Suzuki RS67 - watercooled 125, 2-stroke, v-4, 42 bhp @ 16,500 rpm with a
    12-speed gearbox. First race in 1967.
    jeremy
    '01 Triumph Sprint ST in green
    jeremy0505 at gmail.com
    Jeremy, Apr 28, 2006
