triumph t 140 fuel type
Discussion in 'Classic Motorbikes' started by Ian Brown, Oct 14, 2004.
  1. Ian Brown
    Ian Brown Guest
    I am considering getting a Triumph T140 E, 1980 can anyone tell me if it
    will run on unleaded petrol. Also what should I need to look for when
    purchasing, IE smoke noise ETC.
  2. Not really, no. Use an additive.
    Gawd. Just about everything. Not a Trumf expert, me, but SWK will be
    along in a moment.
    The Older Gentleman, Oct 14, 2004
  3. Triumph switched to hardened valve seats in production year 1972 - 73
    so AFAIK all 750 should be ok on unleaded. IIRC The valve guides are
    likely to wear so they maybe more susceptible to non leaded fuel[1]
    They will tend to smoke a bit when on the side stand, top end noise
    isn't generally a problem these are after all pushrod engines. IMO a
    loose tappet is better than a tight one. Check that with the engine
    running that oil is returning to the tank (OIF model so under the
    seat). Check for play in the primary chain, all bolts are present and
    correct (rocker cover bolts tend to go missing). There's a bit in the
    UKRM FAQ on buying SH bikes have a look at that.
    One problem is that because the Triumph twin engine is so simple every
    bugger thinks they can strip and rebuild one so there will be a lot of
    horrors out there. If you really don't know what to check for I'd
    suggest you either walk away or take along someone with a clue
    [1]Leaded is still available in some places see
    http://www.leadedpetrol.co.uk/leadedpetrol.pdf
    Boots Blakeley, Oct 15, 2004
  4. They did? Blimey. OK, I stand corrected. I never knew that.
    The Older Gentleman, Oct 15, 2004
  5. Ian Brown
    (The Older Gentleman) struggled
    to ejaculate:
    <swoon>
    My idol has feet of lead.
    Pip, Oct 15, 2004
  6. Ian Brown
    It's a brit, innit. Ask him something about some crap Jap twin from
    1979.
    Champ, Oct 15, 2004
  7. Ian Brown
    Timo @ work Guest
    Probably didn't last long enough to exhibit problems with unleaded...
    Timo @ work, Oct 15, 2004
  8. *Drool*
  9. Ian Brown
    to ejaculate:
    My idol appears to be wearing wellingtons. That appears to be rather
    useful as he is standing in a glutinous puddle.
    Pip, Oct 15, 2004
  10. Ian Brown
    Andy Clews Guest
    Thus spake Timo @ work unto the assembled multitudes:
    That's right. The valve seats probably stayed in pristine condition while
    the rest of the sorry heap fell to bits around them. It certainly happened
    to me (1973 Tiger 650) and I swore I'd never buy another Triumph. Ahem...
    <contemplates ceiling, whistling tunelessly>
    Andy Clews, Oct 15, 2004
  11. Ian Brown
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    Oh, you DUH-ty old man.
    "Ichi-fanni and Hari-fanni are 25 year old twins from Yokohama. Their
    hobbies include origami and shagging ageing journalists."
    Nigel Eaton, Oct 15, 2004
  12. Ian Brown
    Mike Fleming Guest
    I think there was a crap batch of valve guides. Both my Bonnies wore
    their valve guides out in under 10k miles. One was a blockade Bonnie,
    the other was an innediately post-blockade Bonnie. Should be OK after
    P reg.
    Mike Fleming, Oct 19, 2004
  13. Ian Brown
    Andy Clews Guest
    Thus spake Mike Fleming unto the assembled multitudes:
    I can't remember how many miles my 1973 Tiger 650 had done, but it was an
    exhaust valve guide failing spectacularly which hastened its departure from
    my ownership.
    Andy Clews, Oct 19, 2004
