Triumph Rocket III reviewette part 1
Discussion in 'UK Motorcycles' started by Monz, Jul 26, 2005.
  1. Monz
    Monz Guest
    Disclaimer... Norvern Monkey so don't expect correct spelling, grammar or
    witty prose.
    Picked it up from local Triumph dealer (old mate) with zero miles on the
    clock and listened to the riot act about running in revs.. yada yada yada.
    First impressions from walk around the beast:
    Not as cruiser-ish as the pics led me to believe, more of a custom look,
    lots of chrome bits though :(. Engine block/gearbox looks awesome just like
    someone has machined it out of a solid lump of something very heavy. Back
    end of bike is the sweetest part of it, teardrop rear light and the widest
    tyre I've ever seen on a bike, 240! Strange exhaust config but not
    unpleasant.
    First ride:
    At a standstill this thing is really heavy although with the weight being so
    low down it doesn't feel like it wants to topple. Once on the move the
    weight all but disappears, the next strange thing is remembering to put your
    feet forward to the footrests which I repeatedly forgot to do!
    The throttle response is immediate though not too brutal until you get it
    past the 1000rpm mark and then it goes mental up to about 3700, after that
    the torque curve feels as if it's flattened out a little although its still
    pulling like a train. The engine has got the same feel as an old straight
    six beemer, almost turbine like and that smooth exhaust note that only
    multiples of three cylinders seem to produce. The brakes are awesomely
    powerful and had no problems hauling the bikes and my not insignificant bulk
    to a halt in pretty short order with surprisingly little dive on the forks,
    even under heavy braking. It all felt very composed which is quite
    comforting on something that accelerates this quickly.
    Cornering, now that is something I wasn't prepared for, I suppose it is a
    trait of the custom/cruiser to totally ignore the input from the rider and
    follow its own line round a bend, this was unnerving for me initially
    especially as I had just ridden to the dealers on a gixxer. Actually, once
    you are prepared for the experience it's not all bad and as long as you
    don't try to force it round corners it's quite smooth and enjoyable.
    Pros
    Accelerates nearly as quick as the gixxer if you've got the bottle and don't
    mind smoking the 240 on the back
    Very comfortable
    35mpg
    Kudos associated with riding a 2.3l bike
    Cons
    12 grand (no matter how many times I looked at it, I couldn't see 12 grand)
    On a hot day your right calf cooks next to the exhaust manifold (painfully
    hot even through leathers)
    Gearbox is very agricultural (letting the revs die off before kicking next
    gear in helped a lot)
    I will be taking it out again to finish running it in as I promised I would
    but I doubt if I will be tempted to trade the gixxer in.
    Monz, Jul 26, 2005
  2. Monz
    gomez Guest
    What's the mileage on a tyre. A friend is suggested touring Assen,
    the Nuremberg Ring and the Mosel Valley next spring, him on his
    Rocket and me on my TA. I foresee that we won't see much of each
    other between stops.
    gomez, Jul 26, 2005
  3. Monz
    Monz Guest
    As it was a test ride and only couple of hundred miles I couldn't tell you
    but I would say it will probably square off pretty sharp if he gasses it a
    lot from the lights :eek:)
    Monz, Jul 26, 2005
  4. Monz
    dwb Guest
    Did you get your knee down?
    dwb, Jul 26, 2005
  5. Monz
    RT Guest
    Puff!
    RT, Jul 26, 2005
  6. Monz
    Biffa @ Work Guest
    Grrrr..... the Nurburgring, which is no where near Nuremberg.
    Biffa @ Work, Jul 26, 2005
  7. Monz
    gomez Guest
    I know, I know. I blinked when using the Spull-Chukka.
    gomez, Jul 26, 2005
  8. Monz
    Eiron Guest
    Give the guy a break.
    The Nuremberg ring road may not be your choice of holiday location
    but some people like it.
    Eiron, Jul 26, 2005
  9. Monz
    Steve Parry Guest
    Whilst lifting the front wheel?
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Jul 26, 2005
  10. Monz
    gomez Guest
    At least I wouldn't have to keep a look out in my mirrors for a fast
    bint in a bus.
    gomez, Jul 26, 2005
  11. Monz
    Most people regard it as something of a trial, tho they used to hold
    some rallies there years ago.
    Champ, Jul 26, 2005
  12. Monz
    dwb Guest
    You shouldn't type so fast.
    dwb, Jul 26, 2005
  13. Monz
    Wik Guest
    [snip]
    Not good...
    I'd got the impression that Triumph had fixed their gearbox clunkiness
    but then again, this ain't exactly a standard box, is it?
    Nice write-up, thanks.
    | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Aug 6, 2005
  14. Monz
    Chris Guest
    I'm going for a test ride on one soon .
    I recently had the chance to ride a second hand Honda Valk F6C .
    My passengers loved it .
    I sort of liked the fun of it .
    Gas mileage was dreadful though .
    And my VStrom has more bottom end and midrange punch .
    Yes , the Honda would pull from 1000 rpm , but not with much strength .
    Revved , the Honda was plenty quick for such a huge lump .
    OTOH ... what's the point ?
    So much weight that I'm sure a 600 Bandit would kill it in the twisties .
    Round town posing was cool .
    Girls who usually ignore me were curious ....
    Meanwhile , pricing .
    Hinckley have got to be joking at 12,000 UKPounds .
    They're cute enough to sell it for way less than that in the US market .
    The castings are OK , but rather crude compared with ,for example , the
    Honda Hornet or my VStrom .
    With it's all steel frame etc ... the bike should be quite cheap .
    A fair UK price would be around 7,000 ---- 8,000 UKP .
    If they can't make a profit , at that price , on such a relatively simple
    and cheap design , they should call in some accountants .
    Meanwhile I recently tested a Honda VTX 1300 ... stodge on wheels .
    Almost as bad as Yamaha's dreadfully overpriced and rather dull to ride
    MTO1 .
    Has been rather a slow seller at my dealer's AFAICS .
    Surprisingly loads of fun on the road is Yamaha's BT1100 Bulldog .
    Superb brakes and excellent handling give very low A to B times .
    'Whistles' through S bends etc ...
    Still pick the Strom though .
    Very fast , very comfortable ,excellent passenger space , steers real well ,
    keenly priced , super TL1000-ish classic motor , awesome midrange thrust
    Chris
    Chris, Aug 16, 2005
  15. Monz
    ogden, Aug 16, 2005
