Triple headlamps
Discussion in 'UK Motorcycles' started by Catman, Nov 18, 2006.
  1. Catman
    Catman Guest
    Are shite, or at lease mine are. I've had to start riding some
    stretches of A414 with beam on. I don't *think* this is going to dazzle
    anyone as I can see the beam pattern and it really doesn't stretch that far.
    I'm intending to nudge the nacelle up a smidge, see if that helps, but I
    was wondering if
    a) Anyone can remember the 'trick' to get both dipped and beam from both
    lights?
    b) If any of these 'high brightness' bulbs are actually any good?
    TIA
    www.cuore-sportivo.co.uk
  2. Catman
    Mark Guest
    I went with Osram and I THINK it was these.......
    http://www.osram.com/products/automotive/upgrade/silverstar.html
    Certainly improved the blackbird. Or yoo could go the HID route?
    Mark
    Mark, Nov 18, 2006
  3. Catman
    May need adjustment in the upward direction, then. In fact, if you
    can get away with main beam when there are other road users about,
    adjustment is definitely called for.
    Mind you - it struck me the other evening when I went out into a
    squally, soggy world full of whirling leaves and handfuls of hard rain
    that dirty nights like that always seem darker somehow, that lights
    are less effective as their output seems to be swallowed up. Winter
    nights in darker than Summer nights non-shocker, I guess.
    There's a wirey thingy, isn't there? A slipping of a relay into a
    socket, perhaps.
    I used to advocate the fitting of 80/100W bulbs, until I melted the
    wiring on the RF. These days I use Osram Silverstar bulbs, which
    claim 50% more light from a 55/60W H4, which IME seems to be
    justified, and at a tenner a pair are cheap enough to experiment with.
    The guys at my local motor factors advocate the Osram over the
    comparable Philips product and they sell lots of bulbs.
    Is your one of the switchless Triumphs, with dip beam on all the time?
    If so, your dip beam bulb may have had enough anyway and you'll
    benefit just from a new direct replacement - but I'd stick Silverstars
    in there anyway.
    Pip, Nov 18, 2006
  4. Catman
    Tosspot Guest
    I switched to high brightness bulbs a while back, and while they are a
    bit brighter, if the headlamps are naff I don't think it'll make much
    difference. Get 'em both on.
    Tosspot, Nov 18, 2006
  5. Catman
    deadmail Guest
    Well, judging from the performance of the PIAA spots I've got I'd have
    faith in their (expensive) bulbs.
    I'd consider adding spots and wiring them to come on with the full beam.
    It's fucking great, I've got an HID dip which makes people sometimes
    flash lights at me (I've adjusted carefully so it doesn't dazzle and
    points to the kerb- these people are just fuckwits).
    When people flash their lights at me, I briefly flash back. When people
    stick their lights on full beam then I put the two 55W PIAA spots on;
    they are really fucking blinding, I'm sure the cunts regret it
    immediately; **** them.
    It's great, I'm riding around with my finger over the fullbeam switch
    saying "make my day" and laughing like a maniac when someone does.
    deadmail, Nov 18, 2006
  6. In uk.rec.motorcycles, belched forth and ejected the following:
    I do the same with trucks that have proper air horns. The first time I
    discovered them was almost the most fun I'd ever had.
    Whinging Courier, Nov 18, 2006
  7. Catman
    Catman says...
    I haven't tried any brighter bulbs on my bike, but I hear there's a
    wiiring fix that can be used, similar to the Aussie mod for Ducati 916s.
    Have you asked on T595.net? If they don't know then no-one does.
    Lozzo
    GSF600SW (broked)
    'I do not object to people looking at their watches when I am speaking.
    But I strongly object when they start shaking them to make certain they
    are still going.' William Norman Birkett, 1st Baron Birkett, Oct 1960.
    Lozzo, Nov 18, 2006
  8. Catman
    james Guest
    You will need:
    1 x 8mm ring spanner
    2 x relays (Hella 01RA001 / 4RA 940 010-71)
    Remove back seat
    Remove front seat (use spanner)
    Fit relays into empty relay sockets beneath RHS plastic
    Ylbmessasid (the reverse of disassembly)
    It is said the Hella relays contain a diode or some such and fitting
    generic 30A single pole 12v ones can cause battery drain. Your
    Triumph dealer and Halfords stock the right part.
    Apparently the main beam lens - can't remember which but looks like the RH
    lamp to me - is not configured to "lens" the dipped beam in the same way
    as the other one, so you might find the beam pattern on dip is not as
    tight as your MOT tester might like. I don't get flashed though. Also
    there are often pre-whenever left hand switch clusters on ebay, they plug
    straight into the loom and allow you to turn it all off. It is probably
    possible to do it without removing the petrol tank if you are nimble
    fingered.
    I would like to know about this also. I am thinking about auxiliaries or
    just bigger bulbs - how much drain can the charging system take?
    james, Nov 18, 2006
  9. Catman
    Catman Guest
    Yeah, not too convinced about splashing £350 on a set of lights, but
    your point is well made.
    C
  10. Catman
    Catman Guest
    Thought so, ta. Odd thing is I'm sure they never used to be that bad,
    but nothing has happened to change them AFAIK
    I was thinking about this last night. The other thing that seems to
    **** everything up is the crud that builds up on the visor. Even if
    it's clean when you start after about 20 mins of spray, I find it pretty
    murky under there.
    That's what I recall, but I was hoping someone could point me at which
    socket, and even where said socket may be located :)
    Ahh, I wonder. It is switchless, and that may account for my comment
    about it never used to be that bad. OTOH the pattern is still pretty
    defined and that seems to be the issue as well IYSWIM. Certainly at
    that price it's worth a punt.
  11. Catman
    Catman Guest
    Cheers
  12. Catman
    Catman Guest
    LOL. Sounds like fun.
  13. Catman
    Catman Guest
    <fx:fires up browser>
    Cheers
  14. Catman
    Catman Guest
    Superb. Thanks.
    I think I'm going to like my MOT tester, We've already talked about the
    can when he did the service. Swears blind he can't see 'not for road
    use' on it anywhere, but 'It sounds lovely, sir'
    Hmm, interesting. I shall have to consider how much time I'm going to
    spend on all this if it is to become a 'toy' IYSWIM
    Ahh, so first you help, now you want me to trash *my* charing system?
    Thanks for the instructions.
  15. Catman
    Tim Guest
    I put the high brightness ones in the Daytona and it was much better.
    Tim, Nov 18, 2006
  16. Catman
    Catman Guest
    Cheers
  17. Catman
    Jan Wysocki Guest
    I've used them on my Duc' - still not bright enough for serious nighttime
    ridding, even in summer. 100/80s are a tad brighter (checked with a light meter)
    and about as far as I'm prepared to stretch Italian specced wiring..
    Hmm, I havent done that since I fitted spotlights on an R80/7. A 130/90
    bulb is a big improvement on my K75RT kommuter. It hasn't fried the
    alternator in 600 miles, but I have to admit it was still hard to see
    last Friday evening (big rain). I'm tempted by a HID - how much brighter
    are they really?
    Jan Wysocki, Nov 21, 2006
  18. Catman
    Catman Guest
    I'd like to suggest that removing plastics makes this *much* easier.
    The relays are held in place with rubber bands. Trying to plug in the
    relays without being able to hold the relay was proving impossible. In
    all other respects your instructions are impeccable, my thanks :)
    I'll find out tomorrow I spose. Currently there are a couple of old
    relays I had lying around in there. I tried wandering down to Halfrauds
    for a new H4 and relays. Would have got the bulb, but really couldn't
    arsed having been told that they couldn't give me a relay without
    vehicle model and year, and then being told they didn't stock them (I
    used the 156 for the computer) I know the kid (literally) behind the
    counter wasn't really to blame, but FFS this is a totally standard
    automotive relay that's been in cars since (at least) 1979....
    I *would* have gone to the A1 place round the corner, but he's not open
    on Sundays.
    If it comes to that, I'll pull the relay next MOT time.
    I have the Phillips blue one in one side. It's better than standard,
    but that could be because the bulb has been on for three years.
    Catman, Dec 31, 2006
  19. Catman
    frag Guest
    Jan Wysocki scribbled:
    Report in this weeks motoring mag, they bought some aftermarket HID
    lights for a car and tested it in an MOT station.
    The kit included the HID bulbs and transformers/ballasts to power them.
    What it didn't include was the special lenses, headlight cleaning jets
    or self levelling gear thats a requirement.
    Anyway, due to no lenses, the light scatter was all over the place,
    dazzling oncoming motorists, and they actually threw less light where
    it should be going than standard bulbs did.
    End result is definite MOT failure, less light on the roads, and
    blinding every vehicle coming towards you.
    frag, Jan 4, 2007
  20. Catman
    frag Guest
    scribbled:
    Properly adjusted HID lights dazzle less than normal halogen ones.
    They're also got to be self levelling.
    If people are flashing you the self levellings fucked or they're
    aftermarket crap jobbies that are blinding people.
    Yeah right, they're flashing you cause your lights are correctly
    adjusted and not dazzling anyone.
    Get a clue and get them sorted.
    frag, Jan 4, 2007
