Trikes
Discussion in 'Motorbike Technical Discussion' started by Ted Taylor, Aug 17, 2006.
  1. Ted Taylor
    Ted Taylor Guest
    Hi
    I am getting a trike at the weekend & would like to no how to lighten
    the front end. It is powered by a
    Kwak 1100 engine. Had thought of putting a big box over the rear axle
    with some weight in. I would
    be very grateful for any ideas.
  2. Ted Taylor
    B-12 Guest
    Why? Is the steering feel too heavy? If that's the reason you want to
    reduce the weight on the front end, the best approach is to install
    custom triple clamps that reduce the trail. A set of leading axle forks
    would also do that.
    Also, if the fork is raked out at ridiculous angle, the steering will
    fell too heavy as the front tire pushes everytime you go around a
    corner.
    B-12, Aug 18, 2006
  3. Helium in the front tyre?
    The Older Gentleman, Aug 18, 2006
  4. Ted Taylor
    B-12 Guest
    How about a 300-gallon tank of Berryman's B-12 Chemtool Choke and
    Carburetor Cleaner behind the rear axle?
    B-12, Aug 18, 2006
  5. <VVBG>
    chateau.murray, Aug 18, 2006
  6. Ted Taylor
    SAMMM Guest
    i think you want the rear to slide before the front.
    my motor-trike did.
    it was quite controllable.
    sammm
    SAMMM, Aug 18, 2006
  7. Ted Taylor
    Ted Taylor Guest
    I have got the trike, unfortunately I did no notice that the front tyre
    was low in air pressure. I did pump it up but it only lasted over night
    before it was low again. help.
    Ted Taylor, Aug 23, 2006
