TRE mod?
Discussion in 'UK Motorcycles' started by Average Heli Person, Apr 5, 2005.
  1. I've read a bit about a device known as the "TRE" (Timing Retard
    Eliminator). It's an aftermarket module that inhibits the function of
    retardation of the ignition on most current Suzukis (including the SV1000s
    which I own). The effect is clamed to be better torque and "less
    snatchyness of throttle" at low rpm (<4k). So basically, 2 questions....
    1. Is it worth it (on an SV1000s)?
    2. Given the above answer is "yes", is £24.99 a good price for a fancy one
    that stops retarding in neutral (not the "resistor in a box" jobbie)?
    TIA
  2. Average Heli Person
    Kiran Guest
    Well, in the 160 miles you've ridden the bike, do you find the throttle
    snatchy? And as for torque, perhaps you should let it run in first.
    Kiran, Apr 5, 2005
  3. Man, you're on the ball.
    OK, I see where you're comming from. I am not a newbie. I am just
    wondering if I can make MORE miles on my new bike even better for as little
    as £24.99.
    Thanks
  4. Average Heli Person
    Christofire Guest
    IIRC, Gower did this on her bike (gsxr 1000) for a fraction of the
    cost. If you google-groups for it you might find some information.
    Christofire, Apr 5, 2005
  5. Average Heli Person
    Kiran Guest
    I'm guessing: 10 - 15mph faster everywhere?
    Kiran, Apr 5, 2005
  6. Average Heli Person
    Christofire Guest
    You are!
    No, wait..
  7. Average Heli Person
    Made a handy difference to my Bandit 12, mind. Fucking hoot, that was
    - but it was only a matter of pulling a connection apart, so it was
    free. 25 quid? Depends what 25 quid means to you, really.
    Pip, Apr 6, 2005
  8. Average Heli Person
    Ben Guest
    I've thoughjt about it, and decided it's pointless. The thing is
    smooth enough anyway.
    Ben, Apr 6, 2005
  9. Average Heli Person
    Good point - on bikes like the Bandit, and prolly the SV, it prolly
    *is* worth having. On a gixxer thou, it'll flip you off the back in
    1st and 2nd anyway, if you want it too, so I don't really see the
    point.
    Quite so.
    Champ, Apr 6, 2005
  10. It only affects the first two gears [1] (not neutral, ytc!).
    ytc? Ahem, let me explain.
    The gear position sensor which connects to the ECU DOES have a signal for
    neutral. On an unmodified bike, the ECU retards the ignition in neutral and
    in gears 1-4 (not 5 & 6). There are different ways of doing the TRE mod.
    The simplest method is to fool the ECU into "thinking" that it is in 5th
    gear all the time by disconnecting the gear position sensor and bridging the
    appropriate wires to the ECU with a resistor. The downside is that the
    tickover becomes unreliable as a result (needs retardation for reliable
    tickover). Some people fit a switch to enable/ disable but to me that's a
    PITA - I don't want to have to fiddle with switches every time I go into
    neutral. The units which cost £25 connect between the GPS and the ECU and
    electronically switch the TRE off in neutral.
    ytc!
    Average Heli Person, Apr 6, 2005
  11. Average Heli Person
    Well, I stand corrected. I can't really understand why the ignition
    needs to be retarded to get a reasonable tickover, but I'll take your
    word for it.
    Champ, Apr 6, 2005
  12. Well, I stand corrected. I can't really understand why the ignition
    ...or why a bike manufacturer comprimises the ride by retarding the
    performance in the lower gears (ok I see the point with yer gixxer thou but
    not a bleedin' SV!) It's not just the low down torque that's comprimised
    but the smoothness. I don't think the 4 cyl bikes are as affected but with
    a lumpy big twin, the effect is added lumpyness which makes smooth
    throttling in town traffic a bit of a chore.
  13. Average Heli Person
    Kiran Guest
    Emissions may be part of it.
    Kiran
    Kiran, Apr 6, 2005
  14. Average Heli Person
    John Banks Guest
    Good point.
    John Banks, Apr 6, 2005
  15. Average Heli Person
    Monkey Guest
    Gearbox protection as well - reduces their warranty from people repeatedly
    dumping the clutch in 1st and 2nd. Worth considering the effect on longivety
    if you do make the mod.
    Monkey, Apr 6, 2005
  16. Average Heli Person
    Salad Dodger Guest
    <drums fingers, in an expectant manner>
    | ___ Salad Dodger
    |_\_____/_| ..73850../..18203.../..3184./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 5 Pts: 90 Miles: 455
    Salad Dodger, Apr 6, 2005
  17. Average Heli Person
    Eddie Guest
    <fx: nudges Champ>
    Go on, say it. Or he'll be doing that all night.
    Eddie, Apr 6, 2005
  18. Average Heli Person
    Salad Dodger Guest
    In the man, yes.
    | ___ Salad Dodger
  19. Average Heli Person
    Salad Dodger Guest
    I think I'm on the turn.
    Still, I'm just happy I got through the whole day without beating our
    data services manager in a bloody pulp.
    Do things like this happen elsewhere?
    Meeting with DSM bloke; he expresses concerns over deviations from SOP
    over this new project. I point out that said project has been "live"
    for 2 days, and that he was invited to provide resource to do the job
    I ended up doing. I suggest I'll note his concerns, convey them to the
    project, and convene a meeting to discuss same.
    Walk in this morning to the mother of all shit-storms.
    He's emailed all and sundry thanking me for a: taking his concerns on
    board and b: agreeing to change procedure changes (both ours, and the
    client's) to fit in with his wishes.
    Apparently, there was "no need for that kind of language".
    Situation well on way to resolution.
    | ___ Salad Dodger
    Salad Dodger, Apr 7, 2005
  20. Average Heli Person
    I'm currently going with the supposition that I don't actually have to do
    /anything/. Any time I've moved away from this position, I've picked up
    jobs[1] and aggro. So I'm spending my days holding back from involving
    myself in even interesting-looking work, because I know what'll happen.
    I'd quite like a proper job now, please.
    [1]Not useful jobs, just stupid, arseing-around, bullshit stuff that gets me
    into meetings, workshops and 3-hour conference calls.
    platypus, Apr 7, 2005
