[URL]http://www.trailtech.net/computer.htm[/URL] Fully Functional Motorcycle Computer: a.. Current Speed b.. Average Speed c.. Maximum Speed d.. Distance e.. Odometer (track total miles) f.. Riding Time g.. Trip Time - stop watch h.. Accumulated riding time (track total hours) i.. Clock j.. Lubrication reminder k.. Maintenance reminder l.. Incrementing and decrementing ( for Enduros or Dual Sport rides) Dimensions: 3.54" x 1.79" x 0.59" / 52 grams Durable: a.. Rugged design withstands harsh racing and trail riding conditions. b.. Water, dust, and mud tight. c.. 6 month warranty from TrailTech. Custom fit for your motorcycle: a.. Sensor/Cable assembly precision designed for exact model fit. b.. Computer mounting options to fit your needs. Mounts to Crossbar, Pro-Taper and Magura type handlebars. Included adapter plate allows for direct mounting to stock odometer plate or any other flat surface c.. Included plug protects the stock odometer drive once the stock odometer cable is removed. More Computer Features: a.. Accepts wheels with a circumference of 1 mm to 3999 mm or a diameter of 0.5 mm to 127 cm (50 inches). b.. Auto start/stop feature automatically starts and stops the ride time stopwatch when you start or stop riding. Auto start/stop assures accuracy for elapsed time and average speed functions. c.. Two wheel size settings allow you to switch the computer between two bikes. Extra mounting brackets are available for most motorcycles. d.. Two odometers record up to 99,999 miles each. e.. Speed readings up to 199 miles per hour or 299 kilometers per hour. f.. Graphical pace arrow lets you know if you are above or below your average speed. g.. Programmable lubrication and maintenance reminders with visual prompts for bike 1 and bike 2. h.. Easy to reset odometer and accumulated riding time can be set to any distance and time after changing the battery. i.. Back lit screen for night time riding. Light stays on for 5 seconds to conserve battery.
