topend fell off
Discussion in 'Australian Motorcycles' started by daniel m, Dec 30, 2006.
  1. daniel m
    sharkey Guest
    Ummm ... you do know that the actual problem was almost certainly just
    an electrickery doohickey somewhere, most likely the rec/reg?
    I'm assuming you wanted to pull the head off anyway for some other
    reason, but the engine looks reasonable to me. Was it down on
    compression?
    Oh, and do what BT says and go buy some proper sockets. No, it's not
    worth only buying two good ones, every time you go to do anything you'll
    discover the one you're missing.
    valve lapping & new valve guides is a pretty cheap job, may as well do
    it since you're about to pay for a new head gasket anyway.
    Oh, cast-in cylinders. Put it all back together and ride the damned thing
    till it explodes, it's just not worth the hassle.
    -----sharks
    sharkey, Jan 1, 2007
  2. daniel m
    daniel m Guest
    Could it be needle leaking onto my cylinder overnite and contaminating the
    oil with fuel?
    I pulled the needles out of each carby and 2 of them seem to have a point at
    which the needle tapers about a cm from the end, can just feel this when you
    rub your fingers up and down it
    http://i146.photobucket.com/albums/r261/donked/needles.jpg
    cylinder1 & 4 have small taper, needle 2 included for comparison feels
    smooth along the entire length (needle 3 smooth too).
    Cheers
    Daniel (crossing fingers this might end up cheap)
    daniel m, Jan 2, 2007
  3. daniel m
    atec 77 Guest
    Depends if the fuel system required vaccum to open the tank petcock..
    if it does then you didn't find the answer you needed . no motor
    running no fuel ( unless it leaks)
    atec 77, Jan 2, 2007
  4. daniel m
    daniel m Guest
    Hmm Im not sure if it needs a vacuum or not (its a 01 r6) Im sorry for all
    these dumb questions - but since its dumb question week I will throw another
    into the arena as I've just noticed somthing funny about my airbox. If you
    look here http://i146.photobucket.com/albums/r261/donked/airboxoverflow.jpg
    You will notice the airbox has a drain tube thats been blocked. Shouldnt
    this be plumbed to the hose joiner below which runs to a small oil
    container?
    At the moment, any excess oil in the airbox seems to have been draining
    straight into carby 1 (since Ive had the bike at least so nearly 2years?)
    Cheers
    Daniel (will get my valves lapped too I guess)
    daniel m, Jan 4, 2007
  5. daniel m
    daniel m Guest
  6. daniel m
    J5 Guest
    J5, Jan 4, 2007
  7. daniel m
    atec 77 Guest
    atec 77, Jan 4, 2007
  8. daniel m
    atec 77 Guest
    If it were me it would be seal it with the tig
    put it together and dump it..
    but thats just a nasty thought
  9. daniel m
    Resounding "YES".
    How the blithering-**** did you manage to crack a liner?!!?
    Knobdoodle, Jan 4, 2007
  10. daniel m
    Boxer Guest
    Boxer, Jan 4, 2007
  11. Peter Cremasco, Jan 4, 2007
  12. daniel m
    daniel m Guest
    Im trying to find more info, but Im led to believe my bike may use a
    "revolutionary way of doing away with liners and plating direct to bore" (at
    least in the 03 models trying to find info on my 01) anybody know what a
    engines worth roughly? less than $4 k would be good
    Cheers
    daniel - life sux without my baby
  13. daniel m
    atec 77 Guest
    No idea about the cost . best you ring some wreckers and there should be
    some way on the nett of getting quoted from further away ( there is for
    car parts)
    It would be possible to sleeve the cylinder but the cost maybe prohibitive.
  14. daniel m
    J5 Guest
    now this is where you park the bike in the shed and keep watching ebay
    or more specifically
    www.motorcycledisposals.com.au
    www.fowles.com.au
    www.pickles.com.au
    and you wait till a bike comes along
    friend did the same with a F4i after a rod exited stage left
    picked up a bike from the disposals $1900
    most of the bike had dibs on the parts before she got it home
    you could easily offload the parts through forums, ebay or
    www.formula-xtreme.com.au
    dunno wether its worth an email to yamaha with pics just an enquiry of why
    is it so ?
    J5, Jan 4, 2007
  15. daniel m
    Boxer Guest
    Agreed, contact Yamaha first, they may come to the party for some of the
    cost.
    Boxer
    Boxer, Jan 4, 2007
  16. daniel m
    sharkey Guest
    It's a pretty weird one, yeah. Anyway, it'll give you something to do
    while you look for a new engine ...
    -----sharks
    sharkey, Jan 5, 2007
  17. daniel m
    daniel m Guest
    Cheers for everybodys help, guess I better start keeping a eye on ebay and
    those auctions as suggested (once I have the $$ anyway) I priced a engine
    down at "metropolotin motorcycle spares" in sydney and its about $3800
    standalone engine or $3200 if I give em mine as a exchange.
    Regards and best wishes
    Daniel
    daniel m, Jan 5, 2007
  18. daniel m
    atec 77 Guest
    I would be watching for write off's from the insurance guys .
    maybe ebay but don't be holding breath.
    atec 77, Jan 5, 2007
  19. daniel m
    Boxer Guest
    So my guess of $4,000 was close (add oil and filter and an air filter and a
    slab or 2 and $4,000 was spot on).
    Boxer
    Boxer, Jan 5, 2007
  20. daniel m
    Damien Guest
    On a positive note, you can feel pretty good about not having wasted
    time stripping the engine chasing nothing! Dunno if that helps much
    tho...
    On a better positive note, think about how much more you know about
    engine internals than a week ago. As much as it might piss you off
    dealing with the problems caused, that sort of experience is priceless
    for us non-mechanical types. :)
    Damien
    GPX250 -> CBR600 -> F650/R1200GS (when the $$$ are there!)
    Damien, Jan 5, 2007
