Tools
Discussion in 'UK Motorcycles' started by Nigel Eaton, Jun 5, 2004.
  1. Nigel Eaton
    Nigel Eaton Guest
    Let me tell you about my evening.
    I was busy making some wheel spacers for a well-known bunch of endurance
    racers when I noticed that the carriage lock on my trusty lathe wasn't.
    Locking, that is. Bugger. I've obviously been a tad ham-fisted and
    stripped the thread. Ho hum.
    Lathe manual out, exploded diagram studied, and the realisation dawns
    that I'm going to need a "special tool(tm)[1]" to get to the offending
    part.
    Fire up PC, draw tool, run G-code processor, bung lump of steel in CNC
    mill, drink beer. Shortly thereafter, a "special tool(tm)" is awaiting
    my inspection.
    Remove lathe carriage. Find stripped thread. Consider helicoil. Realise
    that a nut strategically welded will do nicely.
    Break out bumper fun box of odd sized nuts. Find suitable nut.
    Temporarily wire it in place, ready for welding.
    Realise that (a) it's 11:30 and (b) the MIG's buried under "stuff" and
    decide it can wait until tomorrow.
    God, I *LOVE* having tools. :^)
    [1] Actually just a funny-sized spanner-wivva-hook-onnit.
  2. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Klaatu
    No. But I *do* have a CNC mill at home. :^)
    Like a "C" spanner, but a bit of an awkward shape to get into a
    restricted space behind a shaft. My chucks change with a standard chuck
    key (D1-3 fitting, y'see).
    Nigel Eaton, Jun 6, 2004
  3. Nigel Eaton
    Klaatu Guest
    Are you saying: you have a CNC capable lathe at home ?
    Or is this a work related incident ?
    "C" spanner ?, what most latheistsi need to change chucks ?
    Klaatu, Jun 6, 2004
  4. Nigel Eaton
    Slider Guest
    Klaatu wrote:
    [snip]
    For Cnuts.
    Slider, Jun 6, 2004
  5. Nigel Eaton
    Petel Guest
    Petel, Jun 6, 2004
  6. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    And your point would be? My high point here was making a tool to make a
    tool to make a "thing".
  7. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Petel
    Oh nothing at all. I've got lots of those too. :^)
  8. Nigel Eaton
    Porl Guest
    That's what he said.
    Porl, Jun 6, 2004
  9. Nigel Eaton
    Klaatu Guest
    Bridgeport ?
    (I'm sure we've done milling machines before)
    Klaatu, Jun 6, 2004
  10. Nigel Eaton
    Nigel Eaton Guest
    No, my Bridgeport's a manual one. The CNC is a little Taig mill (cue
    darsy).
    I think we have.
  11. Nigel Eaton
    Nigel Eaton Guest
    That's the feller.
    Dunno! :^)
    Mine can hit a thou-or-so without any particular effort. Half a thou is
    probably do-able with care. It doesn't use ballscrews, so some farting
    about setting the backlash, or careful planning of toolpaths would
    probably be needed...
  12. Nigel Eaton
    Klaatu Guest
    One of these buggers: http://www.taigtools.com/cmill.html ?
    I notice in the tech spec "Step resolution of 0.000125 inches" and
    a "mechanical ¬resolution o: 0.0005 inches"
    Does that mean that machining to a tolerence of half a thou' is possible ?
    Klaatu, Jun 6, 2004
