Toolkit/Multitool recommendations
Discussion in 'UK Motorcycles' started by Kiran, Apr 5, 2005.
  1. Kiran
    sweller says...
    Taking the plugs out is a major total 'strip down the whole bike' job
    on most race reps nowadays, and not one you're likely to need to do at
    the roadside. I'd save the space taken up by a plug spanner for
    something more useful, like drugs.
    Lozzo, Apr 5, 2005
  2. Kiran
    Champ says...
    ****! There's my problem, I keep telling myself to do the wrong things
    when bleeding brakes alone.
    Lozzo, Apr 5, 2005
  3. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "TOG@toil
    <waves>
    Went to change down for a rdbt and fuckme, no gear lever. The small
    moleys in the toolkit served the purpose for the rest of the run and the
    return trip.
    The **** at the destination tried to moan at me for being late, but I
    just glared at him till he shut up.
    Grimly Curmudgeon, Apr 5, 2005
  4. Kiran
    Kiran Guest
    heh, £24 with 4 days to go. And I'm surprised you didn't know what one of
    those bar things is - even I've used one of them.
    Kiran, Apr 5, 2005
  5. Ivan said something similar. It just never occurred to me.
    The Older Gentleman, Apr 5, 2005
  6. Kiran
    mups says...
    Wrong, wrong, wrong!
    It's a GSX750F shed.
    Step 1. Angle grind a hole in side of the fairing
    Step 2. Reach through recently made hole with plug spanner
    etc etc
    Lozzo, Apr 5, 2005
  7. Kiran
    mups Guest
    Lozzo says...
    Not just race reps. Changing the plugs on a GSX750F
    step one: Remove the mirrors....
    FFS
    mups, Apr 5, 2005
  8. Kiran
    mups Guest
    Lozzo says...
    Heh, if did that I have a sneaky suspicion the mystery of where
    those tubes which attach to a blokes bollocks go to would be solved
    fairly rapidly.
    mups, Apr 5, 2005
  9. Kiran
    Christofire Guest
    "Right, that's the front brakes done, I'll squeeze the other handle to
    do the back brake now"
    Christofire, Apr 5, 2005
  10. Kiran
    fluffycat Guest
    fluffycat, Apr 5, 2005
  11. Kiran
    Lozzo, Apr 6, 2005
  12. Kiran
    'Hog Guest
    'Hog, Apr 6, 2005
  13. Kiran
    dwb Guest
    It's a GSX-R - the only seat that comes off with the key is the pillion. To
    get at the battery/main fuse you need to take off the main seat, and that
    requires an allen key.
    dwb, Apr 6, 2005
  14. Kiran
    Verdigris says...
    I'm expecting these pads I have to last about 1,000,000 miles with the
    calipers in their current state
    Lozzo, Apr 6, 2005
  15. Kiran
    Lady Nina Guest
    When are you doing the master cylinder thing?
    Lady Nina, Apr 7, 2005
  16. Kiran
    'Hog Guest
    Hold on there a cotton pickin' minute partner. EBC HH are excellent, if hard
    and aggressive and transform many a bike.
    The AP Racing setup on my Gixxer now have EBC race pads and it's an eye
    popping combination.
    That said some of the normal EBC grades have been disappointing but nothing
    has ever compared to the "Ferodo Platinum" I dropped into the K1100 one day.
    I had them back out in less than a 100 miles and got a refund.
    'Hog, Apr 7, 2005
  17. Kiran
    <cheers up>
    I've just worked out I'm only getting ~5000 miles from a pair of OE
    Brembo pads in the 4 pots on my Guzzi.
    <not so cheery>
    It's still outrageous.
    sweller, Apr 7, 2005
  18. Kiran
    Lady Nina says...
    I did it last night and it made no great difference. I did discover
    that 2 pistons are sticking again, so it's calipers out and rip them
    apart for 2 new fluid seals[1] and even more cleaning up.
    [1] I only fitted the dust seals last time as the fluid seals didn't
    appear to be at all distorted by corrosion behind them.
    Lozzo, Apr 7, 2005
  19. Kiran
    Bear says...
    Why? I was always told that if they aint broke then don't try to fix
    them. At the time all the pistons went in with minimal pressure
    required, but now they don't.
    Lozzo, Apr 7, 2005
  20. Kiran
    Champ says...
    OK. But only if you can get some muppet to bleed my brakes, because it
    would appear that I am crap at it, even with my Mityvac.
    Lozzo, Apr 7, 2005
