Tonight in the garage
Discussion in 'UK Motorcycles' started by Pip Luscher, Apr 27, 2005.
  1. Pip Luscher
    I was mostly trying to figure out exactly why the YZ's forks are so
    stiff. It's always suffered from a bit of stiction, though it was
    alleviated a bit when I had them rebuilt.
    However, since I cartwheeled it last year it's got a whole lot worse.
    It all *looks* straight-ish, but improves if I slacken off the
    steering nut and the top yoke pinch bolts. Do them up, particularly
    the RHS ones, and the stiction reappears.
    Tomorrow I will mostly be trying to figure out whether it's the fork
    tubes or the yoke itself that's bent.
    I see many more bits on the garage floor...
  2. Pip Luscher
    JB Guest
    Incorrect location of the front wheel spindle in the fork leg at the
    non-threaded end can cause this. Check that the forks are not being
    'squeezed together' when you tighten the spindle nut.
    JB
    JB, Apr 27, 2005
  3. Pip Luscher
    BORG Guest
    wheel spacers in wrong or twisted bottom yoke.
    BORG, Apr 27, 2005
  4. Pip Luscher
    Pip Luscher says...
    "I see dead bikes"
    Lozzo, Apr 27, 2005
  5. Pip Luscher
    A good trick for checking the stanchions are lined up straight in the yokes
    is to lay a piece of plate glass flat across them. It should, in an
    anti-Blaney-esque stylee, not rock.
    platypus, Apr 27, 2005
  6. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "platypus"
    Surely, these days, a whizzy laser tool could be found to do that? Plate
    glass just seems so... low tech.
    We'll be using string and planks to align wheels next.
    Grimly Curmudgeon, Apr 28, 2005
  7. Pip Luscher
    You're going to shine a laser on your nice, shiny stanchion?
    Mmm. Cheap, too. Use an old bit of mirror.
    Plenty of planks round here. Although I'd use a collapsible aluminium
    ladder instead.
    platypus, Apr 28, 2005
  8. Pip Luscher
    Raise the front of the bike off the ground, loosen axle and mudguard
    then loosen the pinch bolts on one fork. Rotate the fork in the yoke, if
    the bottom of the fork leg moves in and out... it's bent. Do the same
    with the other leg, first remembering to tighten up the yoke pinch bolts
    of the one you just loosened.
    Muck, Apr 28, 2005
  9. Pip Luscher
    Good idea about turning the tubes & sliders: runout was no more than
    about half a mm, measured at the bottom of the fork sliders (these are
    USD forks).
    At present it's got the wheel off, spindle loose, spindle pinch bolts
    loose, dampers disconnected.
    So I tightened it all back up (not the dampers), albeit without
    checking the torques: no problem. Retightened the wheel spindle (wheel
    still off) and its pinch bolts: no problem.
    Retightened the stem nut fairly tight: no problem.
    Slackened the pinch bolts off, turned the fork tubes back to their
    original orientation, retightened: very slight stiction but nothing
    like before.
    I've been through this all a few times in the past with nothing to
    show for it. It appears to have magically fixed itself
    I is sore confused.
    Pip Luscher, Apr 29, 2005
  10. Pip Luscher
    The spindle on the YZ isn't like a bolt with a head: it screws into
    the LH leg and is clamped in the RH leg, so the spacers only serve to
    to locate the wheel itself; they have no effect on the fork width.
  11. Pip Luscher
    Maybe it was the mud guard that was holding the fork legs apart
    slightly... This is why I always do the mud guard up last[1]. Who knows,
    maybe something was twisted and you sorted it by loosening / doing up
    again.
    [1]Unlike the bike shop that rebuilt the front end on my Bandit with a
    4mm gap between the spacer and the fork leg, due to them doing the mud
    guard up first... duh..
    Muck, Apr 29, 2005
  12. Pip Luscher
    Uh, a YZ is a motocrosser; the mudguard is mounted on the bottom
    yoke.
    Pip Luscher, Apr 30, 2005
  13. Pip Luscher
    Right you are, I missed that small point.
    Muck, Apr 30, 2005
