tommorrow I am mostly Flying
Discussion in 'UK Motorcycles' started by jsp, Sep 12, 2003.
  1. jsp
    jsp Guest
    Flying.
    whilst you all bugger off to the eosm, I have a morning flight arranged
    in a four seater. What a month! Within two weeks I will have been
    gliding and flying in a powered plane - both firsts [1]
    uh-ho at thios rate, I might end up parachuting after all....
    [1] excluding airliners
    John
    SV650
    Black it is
    and naked
    jsp, Sep 12, 2003
  2. jsp
    Martian Guest
    Ye, Lucky bastard ye.
    Ask if you can do a loop (plane equivalent of a wheelie) ;-D
    Martian, Sep 12, 2003
  3. Engine failure is such a bitch.
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Sep 12, 2003
  4. jsp
    Platypus Guest
    Inverted spin (plane equivalent of licking smack off a monkey's eyeball)
    Platypus
    VN800 Drifter, R80RT
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Sep 12, 2003
  5. jsp
    jsp Guest
    Heh, too true..
    John
    SV650
    Black it is
    and naked
    jsp, Sep 13, 2003
  6. jsp
    Martian Guest
    [snip]
    Not many bikes are trick rated, but it is fun trying.
    I have heard, somewhere, that it is possible to barrel roll passenger
    aircraft so long as positive G is maintained on the wing.
    Martian, Sep 13, 2003
  7. jsp
    jsp Guest
    You are quite right, the plane was not aerobatic rated. However, at
    Sywell, where we flew from, there was an aerobatic competition in
    progress. f*ck me! I didn't know planes could *do* that!
    John
    SV650
    Black it is
    and naked
    jsp, Sep 13, 2003
  8. jsp
    Greybeard Guest
    If a wheel comes off or buckles, you prolly won't die. If the wing folds, or
    breaks....
    Still great fun having a little play though ;o)
    Most light planes can be barrel rolled reasonably safely. you should be able
    to keep it at less than 1.5 g! The 2 main reasons for keeping pos G is that,
    again, most light planes, even some that are cleared for aero's, don't have
    an inverted fuel system. thus the fuel goes neg G in the carb and the engine
    quits PDQ! The other reason, and prolly the most sensible to avoid neg G
    for, is that the wings are stressed for pos G, and not neg.
    Helicopter rotor blades are the same. When positioning the rotors they
    should always be pushed up, on not pulled down.
    Greybeard, Sep 14, 2003
