Today's Riding Tips
Discussion in 'UK Motorcycles' started by Nigel Eaton, Jun 13, 2004.
  1. Nigel Eaton
    Nigel Eaton Guest
    Things I learned on the ride back from Champ Towers earlier.
    1) I have a *shite* memory for roads.
    2) It is a bad idea to get TWA unless you're fairly sure there isn't a
    sharp bend just after the hump-backed bridge (see 1).
    3) Disk brakes don't work whilst TWA.
    4) ZZR11 brakes work surprisingly well when the user is properly
    motivated.
  2. Nigel Eaton
    Porl Guest
    What TWA mean?
    Porl, Jun 13, 2004
  3. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Porl
    Two Wheels Airborne. It's accompanied by the sounds of an engine revving
    and me screaming.
    Actually, I can't be sure I actually took off. But the revs did rise,
    and the whole thing got *very* squirrely.
    A definite trouser moment.
  4. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    Just your side of Aynho, IIRC.
    Nigel Eaton, Jun 14, 2004
  5. Nigel Eaton
    <thinks>
    Oh, yes, that one. Over the canal. I can see how that would cause
    some intestinal commotion.
    Champ, Jun 14, 2004
  6. Nigel Eaton
    Nigel Eaton says...
    How the **** could you forget that bridge, it's monstrous and very
    clearly marked on the approach from both directions.
    Lozzo, Jun 14, 2004
  7. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    I'm fairly stupid.
    HTH.
