To grease or not to grease - banjo bolts?
Discussion in 'UK Motorcycles' started by Mark, Nov 30, 2004.
  1. Mark
    Mark Guest
    OK I've bled brakes enough times but never actually changed the
    lines... but all that's going to change thanks to e-bay and Mr
    Goodridge. So do I need to grease the copper crush washers / banjo
    bolts, or just leave them dry? And if I should grease them - copper
    grease or "normal"?
    Thanks in advance.
    Cheers
    Mark, Nov 30, 2004
  2. Mark
    I've always left them very clean and dry, as I don't think copper grease
    has any home inside the hydraulics of a brake system.
    Muck, Nov 30, 2004
  3. Mark
    Muck says...
    Wot the comedy-haired one said
    Lozzo, Nov 30, 2004
  4. Mark
    DannyBoy Guest
    Why not use the grease they give you in the piston overhaul kit?
    DannyBoy, Nov 30, 2004
  5. Mark
    (DannyBoy) struggled to ejaculate:
    Why the **** would you want to?
    If you can come up with a little sachet of banjo grease, I'll grant
    you that you may employ that, but otherwise - no grease on the copper
    washers. You really don't want a little nodule of grease sitting on
    the sealing face, waiting for the first time that you really haul the
    anchors on to make a break for freedom - followed instantly by all the
    pressure you'd just built up and a squirt of brake fluid ... now do
    you?
    Pip, Nov 30, 2004
  6. Mark
    Why do you presume he's using such a kit? And even if he was, it might
    come with grease for the cylinder/pad interface, but he's asking about
    the banjo bolts, which are an entirely different kettle of worms.
    Ace, Nov 30, 2004
  7. Pip wrote
    All a banjo needs is natural human lanolin and a wipe with a lint free
    cloff.
    steve auvache, Nov 30, 2004
  8. Mark
    Mark Guest
    Pip / Muck
    Thanks for the clear thinking - once I'd thought it through after
    reading your posts it became *very fxxking* clear that I shouldn't be
    contaminating the brake fluid with anything!
    Thanks!
    Mark, Nov 30, 2004
  9. Mark
    DannyBoy Guest
    True but he'd be a bit of a dick to go to all the effort of replacing
    the fluid and hoses and bleeding his brakes without investing an extra
    35 minutes in an overhaul.
    Anyway just becuase he hasn't got a grease sachet doesn't mean he
    can't find the same grease and use that if he so wishes. (Although he
    seems to have chnaged his mind now.)
  10. Mark
    DannyBoy Guest
    I don't. The OP did.
    I think you're being a little over dramatic here. Anyway what the hell
    kind of grease are you talking abuot thats still in situ after you've
    crushed a copper washer!!!
    Grease comes with brake ovehaul kits. So it can't do any harm. Whether
    or not it does any good isn't what the OP asked.
  11. Mark
    JP Guest
    Dont add anything to them - just make sure they are *very* clean. A
    lot of greases etc will **** the brake fluid if it gets in contact in
    any way
    JP
    JP, Nov 30, 2004
  12. Mark
    DannyBoy wrote:
    Grease on a banjo will get squashed around both sides of the washer, one
    side just happens to be the hydraulic side, the other side, atmosphere.
    Any fluid not designed to be in a hydraulic circuit is not going to be
    any good there is it? Just coz the grease comes with the kit, it doesn't
    mean you have to put it everywhere.
    About copper washers, they're meant to deform and follow the surface
    imperfections in the two surfaces they have to provide a hydraulic seal
    with. Grease is at best going to get squashed out, at worst it's going
    to form a lubrication layer that could hide in imperfections in any of
    the metal surfaces, this becomes a bad thing at the high pressures a
    brake hydraulic seal has to handle. This is more likely to happen if you
    re-use the washers.
    Also, the torque of the banjo bolts is specified with the threads dry.
    Lubricating these threads will alter the friction between the banjo bolt
    and the caliper meaning that you could over torque the bolt and over
    stretch the soft alloy in the caliper. This could lead to a hydraulic
    leak, which is going to put a crimp on your day.
    This is why you don't grease banjo bolts.
    Muck, Nov 30, 2004
  13. Mark
    Make the fluid *dirty*, you mean?
    Heaven forfend.
    Pip, Dec 1, 2004
  14. Mark
    You appear to have omitted a "you fucking fuckwit" above.
    Here, have one for free, to use as you wish - simply tear off, cut and
    paste and distribute as you see fit:
    _____________________________________________________________________
    You fucking fuckwit
    Pip, Dec 1, 2004
  15. Mark
    Thank you - I knew I'd forgotten something.
    Lovely. I'll save it for later.
    Seeing as you're online, can I nag you and her Ellyness for a response
    to my email re 11th Dec?
    Champ, Dec 1, 2004
  16. Mark
    DannyBoy Guest
    Since you're putting it on your pistons we can assume the grease they
    give you does no harm at all. Even less so on the Banjo bolts IWHT.
    No, I don't grease Banjo Bolts because I don't see the point. THe OP
    is the one thinking of greasing Banjo bolts. I merely suggested to the
    OP that the offcial grease that presumably is designed not to **** up
    brake fluid is the one to use if he does grease is Banjo bolts.
    So **** off.
    DannyBoy, Dec 1, 2004
  17. Mark
    Have you ever actually stripped and rebuilt a brake caliper? It's
    quite clear that you haven't the faintest idea about the subject in
    question[1].
    Snappy comeback, oh master of wit and repartee.
    [1] Should fit in just fine here then.
    Ace, Dec 1, 2004
  18. Mark
    DannyBoy Guest
    He's gotta go out and buy fluid, he's got to bleed them which is
    always a pain in the arse. He'll be cleaning the pistons anyway while
    hes covered in brake fluid and shit. Just simple things like putting
    on old clothes and washing up take time too.
    If you're gonna set aside two hours to change hoses you might as well
    set aside an extra chunk and do the overhaul.
    ....but I don't really give a toss either way. Free choice innit.
  19. Mark
    Heh.. no _you_ **** off.
    Muck, Dec 1, 2004
  20. Mark
    Didn't get it :-( Not the original, anyway.
    Best sort out alternative email addy for me, I think.
    Have replied anyway, in the affirmative.
    Pip, Dec 1, 2004
