To all the clever bored people.
Discussion in 'UK Motorcycles' started by Krusty, Jan 6, 2010.
  1. Krusty
    I fancy a little vehicle project to break up the DIY sessions, & top of
    the list is a manual sequential gear shifter for the Jeep. Just because.
    The (automatic) box is controlled by two solenoids, as follows:
    Gear Solenoid #1 Solenoid #2
    1 On Off
    2 On On
    3 Off On
    4 Off Off
    Now I know zilch about electronics, but I'm sure this must be possible
    with a digital joystick (moment switch) & a bunch of latching relays.
    I.e. flick the joystick up once & sol1 is switched on. Flick it again &
    sol2 is switched on. Flick again & sol1 is switched off etc. However I
    have no idea how to wire this up, or how it would 'know' what gear it's
    in & therefore which relays to fire & in which direction when going up
    & down the box. Sooo...
    [1] Is it possible?
    [2] Any tips on wiring diagrams?
    Krusty, Jan 6, 2010
  2. Krusty
    Catman Guest
    No ;)
    It should be pretty simple using some basic logic gates to make this happen.
    But, how will you select neutral?
    www.cuore-sportivo.co.uk
    Catman, Jan 6, 2010
  3. Krusty
    That's a good start.
    I'll use the main lever for neutral, reverse, park etc. The sequential
    shifter will just be switched on & used in Drive when I'm in the mood,
    or want to hold a particular gear off-road or going up/down steep hills.
    Krusty, Jan 6, 2010
  4. Krusty
    Simon Wilson Guest
    It's probably possible using relay logic, but I wouldn't know how.
    I've done stuff like that before using an eprom to build a finite state
    machine, but these days it would probably be more fun with a little
    microcontroller and then you could sense other stuff like rpm and road
    speed and build in some intelligence.
    Probably with the original control IWHT.
    Simon Wilson, Jan 6, 2010
  5. Krusty
    Catman Guest
    OK. You need a counter from 0 to 3, or 1 to 4 and some drivers to move
    the solenoids. It's been *so* long since I've done any of this, there
    may be other ways to do it.
    I'd use a couple of switches, that you may be able to adapt from some
    kind of joystick. I'd set it so that pressing up set the output high,
    momentarily, and pressing down set it low.
    You *probably* need to debounce that and feed it to your counter. That
    would then make each of 4 pins high as you increment or decrement the
    counter.
    Each one of those pins on the counter will then trigger some kind of
    logic gate to drive your relays / solenoids.
    The last bit is *probably* easier to accomplish using some kind of PIC
    these days, but they are a bit new fangled for me.
    If I *could* give more help, I would, the best I can say is it is
    certainly doable.
    No doubt someone will be along soon to explain exactly how and then
    someone else will be able to make it break light speed while doing a
    rolling stoppy and proving the existence of the Higgs-Boson ;)
    Catman, Jan 6, 2010
  6. Krusty
    Simon Wilson Guest
    Blimey. This
    http://www.electro-tech-online.com/...riggered-2-bit-binary-counter-trannyschem-jpg
    is the kind of thing I was thinking of.
    I'd be nervous of power glitches etc. making impromptu shifts from 4th
    to 1st though.
  7. Krusty
    Krusty, Jan 6, 2010
  8. Krusty
    Krusty, Jan 6, 2010
  9. Krusty
    bod43 Guest
    Have a look at the controller Lego make.
    Years since I looked but sounds like the sort of thing
    it could do. Easy enough to program for children:)
    http://en.wikipedia.org/wiki/Lego_Mindstorms
    bod43, Jan 6, 2010
  10. Krusty
    Paul - xxx Guest
    Good man, crack on ... ;)
    ISTR someone in the difflock (I think) forum doing something similar
    last year or the year before, sorry can't be more specific as I'm going
    on memory, but might be worth a look or a question, they're pretty
    knowledgable people. Homepage here ...
    http://forum.difflock.com/
    Paul - xxx, Jan 6, 2010
  11. What you have there is a two-bit Gray code. This is designed
    so that only one of the bits changes on any transition, avoiding any
    momentary change to an undesirable state if two bits _don't_ change in
    perfect synchronism (e.g. in a rotary position encoder).
    http://en.wikipedia.org/wiki/Gray_code -- see code at top of page.
    Dr Ivan D. Reid, Jan 6, 2010
  12. If you encode it into a 2-bit number AB (0=Off=0 V, 1=On=12 V) like this:
    then you can see that Solenoid #1 is NOT A, and Solenoid #2 is A XOR B.
    So... If you have a 2-bit up-down counter AB=00<->01<->10<->11,
    #1 can be driven directly from 12 V off the NO contact of a relay whose
    coil is connected to A and ground and #2 can be implemented in another
    relay by the cunning trick that a relay coil is polarity-independent.
    You wire the coil up to A and B and the NC contact only opens to 12 V when
    A and B are in opposite states.
    First, find your 2-bit up-down counter... But there are two other
    difficulties: You have to have the state machine enter a known state when
    you enter the paddle-driven condition (you have to bypass Drive so it's
    still usable, and you can't have it entering whichever gear it was last in
    in case that was inappropriate; otherwise you have to be able also to read
    the current state of the solenoids) and you need extra logic to make sure
    that count-down can't happen when AB=00 and count-up can't happen when AB=11.
    This could get expensive...
  13. Krusty
    So buying a kit for $170 might not be a bad idea then?
    Krusty, Jan 6, 2010
  14. Krusty
    Rudy Lacchin Guest
    I can't help you with the electronics but I have a couple of Dupar digital
    joysticks which you're welcome to if you decide to have a go at this
    project:-
    http://www.rula.pwp.blueyonder.co.uk/images/joysticks.jpg
    Total height 130mm, face plate 65mm square. Each one has four on/off
    switches (err... obviously). I'm told they fell out of some sort of control
    panel at Dowty's. They're currently sitting on my desk in Gloucester.
    Rudy Lacchin, Jan 6, 2010
  15. Krusty
    frag Guest
    Yup.
    But as others have pointed out it will be easy to do (£20 or so for the bits)
    easily. To do it safely will need more, as you really *really* don't want it
    to suddenly change down to 1st from 4th.
    That's where the complication comes in.
    frag, Jan 6, 2010
  16. Krusty
    crn Guest
    When I were a lad I had a sidevalve Hillman Minx with a 3 speed column
    change. It was rather too easy to change down from top into reverse, it
    actually went in rather easily but when I let the clutch up my
    overtaking manoeuvers became very interesting rather quickly.
    It did not take long for motor manufacturers to put the gear lever back
    down on the floor where it belongs and front bench seats became history.
    crn, Jan 7, 2010
  17. Krusty
    Wow. You had a mkI, made in 1932/3? The post 1934 mkII had a 4 speed
    box.
    Really. Funny how Vuaxhall were still making bench seat cars 30 years
    later. We had one of these for a while when I was a kid
    http://en.wikipedia.org/wiki/Vauxhall_Cresta#Cresta_PB
    Well done. No drop in your standards for 2010.
    wessie, Jan 7, 2010
  18. Krusty
    boots Guest
    Not the cresta, my father had a victor 101 with a bench seat and
    column change. Not exactly sure when but I guess it was c 1971, didn't
    last too long suffering terminal tin rot and was replaced by a triumph
    PI, another piece of unreliable automotive junk.
    Heh
    boots, Jan 7, 2010
  19. Krusty
    Ooh yes please, reckon they'd be perfect if I replaced the knobs with
    something a bit less 1950s. Would you be willing to post them if I
    covered the cost? Or failing that, are you anywhere near Gyp?
    Krusty, Jan 7, 2010
  20. Krusty
    Lovely, consider yourself hired! Sounds like a good excuse to finally
    check out that village pub.
    Krusty, Jan 7, 2010
