Tire removal?
Discussion in 'Motorbike Technical Discussion' started by elkie, May 12, 2004.
  1. elkie
    elkie Guest
    Hi all,
    Just wondering if you guys has any good/easy ways to get the rear tire
    rubber off the rim? My intertube is ripped/shot/dead. And the local shop
    here wants $45 to replace the tube(since i'm not getting new tires,got bike
    with 5 month old tires on them).
    I have the rubber moving freely from the rim, i can spin the rim in the
    tire, but cant get any of the edges out of the rim.
    thanks for the help!!!
    elkie, May 12, 2004
  2. http://www.cycoactive.com/mc/trail_tips/ctiw.html
    Lots of soapy water and a couple of tire levers.
    Be real careful not to bend or bang up your brake disk(s)
    or you'll screw up your braking.
    Remove the bead on one side only, slip in the tube, put
    a little air into the tube so the folds don't get caught
    by the bead or levers when you put the tire back on.
    With enough soapy water, you can almost do this without levers.
    Just be sure that the tire bead 180 degrees away from where
    you're working on it is sitting in the hollow between the rims.
    Make really sure that the tube's out of the way when you put
    the tire back on or you'll pinch it and have to redo the whole
    job.
    Rob Kleinschmidt, May 12, 2004
  3. http://www.cycoactive.com/mc/trail_tips/ctiw.html
    job.
  4. elkie
    Charlie Gary Guest
    Rob Kleinschmidt wrote:
    <<snip>>
    What happens to the soapy residue between the tire and rim when you ride in
    the rain? I've never tried it myself, but some greybeards have warned me
    about it in the past.
    Windex works wonders, though with my luck it leaves just as much residue.
    Later,
    Charlie
    Fix the e-mail address and it will get to me
    There are about 100 different sorts of insects in Mexico that some people
    eat on purpose.
    Charlie Gary, May 12, 2004
  5. elkie
    elkie Guest
    Thanks for all the help !!
    got the tire off the rim, or at least one side, now any secrets to get
    the intertube and tire back on?
    anything I should look out for while putting tire back on, so not to
    damage the new intertube?
    elkie, May 13, 2004
  6. elkie
    Charlie Gary Guest
    Kaybearjr wrote:
    <<Snip>>
    I remember the night I looked at my bloody finger and thought about how next
    time I was going to use a rag to wipe the inside of the tire. :)
    Later,
    Charlie
    eat on purpose.
    Charlie Gary, May 13, 2004
