Tire pressures?
Discussion in 'Motorcycle Technical Discussion' started by Paul Harris, May 1, 2005.
  1. Paul Harris
    Paul Harris Guest
    I hate to start a thread on this, as there are probably as many answers
    as people riding, and I know there's not really a "right" answer.
    But here goes.
    I just put new tires on my bike (Kawasaki Voyager, tires are
    Continentals). They're rated for maximum 42 psi front and 49 psi rear.
    The manual recommends 32 psi front, and 36-40 psi rear, depending on
    how much weight you're carrying.
    I'm heavy (250 lbs), I mostly ride alone, but often with a lot of gear
    stowed away, I do a lot of riding in the mountains, fairly aggresive
    riding, within the context of what the Voyager is capable of.
    I've been running around 36 front and 41 rear in the OEM Dunlop 404s.
    What do you think I should run in the new tires? Any opinions
    appreciated. Do I go with the manual, the maximum rating of the tires,
    or something in between?
    Thanks for ideas.
    Paul Harris
  2. message
    What year of Voyager? That being said MOST tires
    available are BETTER than the ones that were
    available on any bike older than 5 years. IMO that
    being said go with what the TIRE MAKER recommends
    and stick to it as your base line setting. You
    "MIGHT" drop a pound or so to see how it affects
    the ride but sticking with the tire maker is the
    best bet as it helps prevent tire over heating and
    premature wear.
    I ride a 1979 GL1000 with Metzler ME880 Marathon
    up front and a Bridgestone BT-45V in the rear. I
    run the manufacturers recommended pressures...I
    don't memorize the pressure, instead I READ the
    placard on the tire before checking the pressure.
    Keith Schiffner
    RCOS #7
    Assistant to the Assistant Undersecretary of the
    Ministry of Silly Walks.
    "terrorist organization" is a redundancy
    Keith Schiffner, May 1, 2005
  3. Paul Harris
    John Johnson Guest
    You might consider contacting the manufacturer directly and explain your
    situation to them. Another potential resource would be a Voyager
    owner/enthusiast group, whether online or 'real-world'. It's also
    possible (though unlikely, AFAICT) that Kawasaki has some information on
    the subject. HTH
    John Johnson, May 1, 2005
  4. Paul Harris
    LJ Guest
    I'm not sure that I agree with Keith. I'd tend to pay more creedence to the
    bike manufacturer's rating than the tire's as long as you don't exceed the
    tire max rating. If the bike manufacturer's rating exceeds the tire's
    (which won't happen often) get some different tires.
    LJ, May 2, 2005
  5. Paul Harris
    TaskMule Guest
    The tire only has the maximum pressure, you need to go by the manual
    recommendations.
    TaskMule, May 2, 2005
  6. Just guessing, maybe 38 front, 42 rear. It's a *starting point*, there
    are no hard and fast numbers, just recommendations that you start with,
    and can adjust your pressure from...
    But I like to play with my calculator and with formulas to come up with
    my own numbers...
    I looked at my owner's manual on one bike and saw that it recommended
    raising the pressure for carrying double, and figured that I weighed
    enough to use the maximum inflation pressure recommended for two-up
    riding. The manual said to use about 36 front, 36 rear, for solo
    operation carrying a light passenger and to raise the pressure about 2
    pounds for carrying double. That was an easy one...
    I looked at the maximum gross vehicle weight on the data plate on the
    steering head, that's the maximum gross vehicle weight for the *stock*
    tires and compared it to the maximum allowable weight on my premium
    aftermarket tires. You could divide one number by the other number and
    get an inflation factor to multiply times the recommended inflation
    pressure...
    I looked at the static weight distribution (without rider, passenger,
    or luggage) given in road tests and tried to guess how my weight was
    distributed. I figured that most of my weight was probably over the
    rear tire, that the front weight remained about the same with me on the
    bike...
    If you have a heavy duty scale that you can actually run your wheels up
    onto it one at a time, with you on the bike and maybe somebody to
    steady you, you can gather actual data for the weight on the two tires
    and have an excellent idea of what percentage of the maximum inflation
    pressure molded onto the side of the tire you should use by dividing
    actual laden weight by the maximum gross weight allowable and
    multiplying that figure by the maximum pressure molded onto the side of
    the tire...
    Diddling around with all this, I came up with an inflation pressure
    that was within about 1 pound of the manual's recommended inflation
    pressure for the kind of riding I was doing...
    Then I went out riding on a hot day and noticed that I was getting what
    seemed to be an excessive amount of pressure rise in both front and
    rear tires. Like, the rear tire pressure went up from 38 pounds to 44
    pounds, and the front tire pressure went up from 36 pounds to 40 pounds
    on a day when the road temperature was probably around 120 to 130
    degrees. The air temperature was 95 to 100 degrees...
    I concluded from the large pressure rise that my pencil type tire gauge
    might be reading a bit low. Pencil gauges only cost a few $, they have
    a sliding seal, a calibrated stick, and a spring inside, that's all.
    Over the years, a pencil gauge's seal will wear, allowing some of your
    air sample to escape, and the spring might change its tension, so the
    gauge might become inaccurate...
    So I bought a Camel digital tire gauge, and two Camel pencil type
    gauges.
    I took a reading with all three gauges and threw away the pencil gauge
    that disagreed with the other two gauges...
    And we've discussed pressure rise a number of times on various NG's and
    lists. The conventional wisdom used to be that if you started out with
    some nominal pressure and that pressure rose up 10% when the tire was
    hot, then the cold pressure you started with was the optimal
    pressure...
    Then somebody posted that they'd talked to a Dunlop rep and that guy
    said there was no hard and fast 10% pressure rise rule anymore. OTOH,
    if you started at some relative high maximum pressure and you didn't
    get any pressure rise at all, then you'd started with *too much
    pressure*, the
    the tire wasn't flexing, the contact patch was probably crowned too
    much, it was too small, and the rider should notice that the bike feels
    very "skittery" and the ride jiggles the eyeballs if the front tire has
    too much pressure and that you feel butt burn very early if the rear
    tire had too much pressure...
    And then I started noticing that if I set my tire pressure to the
    recommended pressure in the manual (or the pressure that I had
    calculated)
    just before I went riding at noontime, and then I checked my tire
    pressure
    early in the morning before inflating my tires to what I wanted, the
    tire pressure was *always* down a pound or two. And I wondered what the
    heck was happening, did I have a slow leak, or what? It seems like the
    pressure
    would be reduced one pound for every so many degrees the temperature
    was below the usual daily temperature. Cold temperatures reduce tire
    pressure just like hot temperature increases tire pressure...
    Is that enough complication for you? Wait, there's more!
    When you ride in a sporting manner, and start leaning the bike more and
    more, the recommended air pressures may not be enough, though they are
    OK for straight up riding where the load of the bike on the tires is
    the actual weight of the bike on the tires...
    Suppose you like to lean the bike to a 30 degree angle from the
    vertical often. Sport touring riders will be doing this. A lot of your
    cornering comes from camber thrust, and the load factor on the tires is
    1.15, so you need 15% more inflation pressure in the tire. That's not
    too bad, a tire that is normally supposed to be inflated to 36 psi cold
    would need 41.4 pounds of pressure in it, and that's within the maximum
    pressure molded onto the side of the tire.
    Running at the maximum pressure would help reduce the strange front
    tire wear called "cupping", by providing more pneumatic support for the
    tire...
    Suppose you are a really frisky rider and you like to lean the bike a
    whole lot, and you do that often. You regularly lean the bike over to
    45 degrees and scrape your footpegs and drag your knees like a Ricky
    Racer...
    The load factor on the tires is 1.41, but I won't recommend that you
    inflate the tires with 41% more air pressure, they'd be much too
    skittery feeling and the ride would suffer horribly. When you lean the
    bike over that far, you're running in the slip angle mode more than the
    camber thrust mode. At one g of lateral cornering force, for every
    hundred feet you go forward, you're trying to accelerate 25 feet toward
    the geometric center of the corner's radius. The tire is always
    slipping a bit toward the outside of the corner as you try to turn the
    bike at those high angles, that's why it's called running at a "slip
    angle".
    Tires that are intended to corner at high angles like that don't have
    very much water channel grooving and the tread blocks are very wide to
    reduce distortion. They don't cup or scallop, the tread just gets worn
    and melted off the carcass...
    As you corner at a slip angle, tiny bits of dead, used-up rubber are
    continually being ripped off the surface of the tread, exposing fresh
    rubber that grips again. The tire gets very hot and the oil that
    extends the dynamic range of elasticity of the tire rises to the
    surface. The tire turns blue. Racers say that the tire feels greasy.
    But they like to satrt out with much *less* pressure than is
    recommended for street riding, in order to make the tire get hot and
    start "working" quickly...
    krusty kritter, May 2, 2005
  7. Paul Harris
    Paul Harris Guest
    Thanks Krusty, and others, for replying. As I suspected, a variety of
    opinions. My own opinion is that the numbers stamped on the tire are,
    in fact, meant to be maximums, and the appropriate pressure will be
    something relating to the size, weight of bike and rider, temperature,
    and riding style.
    Today I picked numbers very close to the ones you've suggested above
    for my first major ride, I used 37 psi front and 43 psi rear, and found
    that the bike tracked and handled well. I'll go on experimenting for a
    while, I guess.
    Whew! Much interesting stuff deleted here. When I have a chance I'll
    read it through and see if I can come to my own conclusions. I like the
    idea of developing some sort of formula.
    I check my pressures daily when on a trip, and also try to compensate
    for temperature variations, if they are extreme, which they can be in
    the mountains sometimes (something like 1 lb pressure per 10 degrees
    fahrenheit, if memory serves).
    I've read about how racers do it. Well, I'm not racer, though I do
    gonzo that big bike along sometimes. I think racers also change tires
    every two or three races.
    PH
    Paul Harris, May 2, 2005
  8. Paul Harris
    B. Peg Guest
    Good stuff there krusty. I've learned that my spirited riding in the
    canyons has raised my tire's temps and also leads to their early demise in
    3000 miles. The sidewall flexure seems to make the tire hotter than the
    normal contact patch area does. I've raised the pressure around 6 pounds
    higher than the manufacturer recommends and they run slightly cooler and I
    don't bottom out and do rim strikes crossing driveways and gutters. Love
    those low profile tires for rim strikes with gutters and railroad crossings!
    One of these days I'm going to take my infrared remote reading temp gauge
    and go and measure the tire temps at the end of the canyon and see what's
    going on. I also play with the 10% rule mentioned and it gets me very
    close.
    B~
    B. Peg, May 2, 2005
  9. Paul Harris
    Ron Seiden Guest
    In addition to all this highly scientific stuff, you can also (*not*
    "instead of") look at how the tires are wearing (even if just the dirty area
    from a short ride). Tires are very good at showing too high or too low
    pressure in the way they wear, and this is something that automatically
    figures in your riding style...
    Ron Seiden, Feb 22, 2006
