Tire Fitment
Discussion in 'Motorbike Technical Discussion' started by Bubb, Jan 24, 2009.
  1. Bubb
    Bubb Guest
    I have a completely stock Rebel 250 of 1987 vintage that specifies a
    130/90/15 rear tire. I have the opportunity to buy a new 140/90/15 tire at a
    very good price. Since I don't understand the numbering system for tires, I
    have no idea if this tire would hit the frame/fender or cause other problems
    I may not be aware of. Advice in this matter would be greatly appreciated.
    Thanks in advance for any help in this matter.
    Tom
    Bubb, Jan 24, 2009
  2. Bubb
    Jack Hunt Guest
    The first number is the tread width in mm. The second number is the ratio of the
    sidewall height to tread width. The last number is of course the rim diameter
    in inches.
    Your new tire will be roughly 5mm wider on each side than your present tire.
    Different manufacturers tires will vary slightly in width even though both will
    have identical numbers. Measure the clearance you have now. If it's greater
    than 5mm on each side, go for it with caution. See below.
    Remember that the sidewall height is also a little greater on the new tire, so
    check the radial clearance also. I once went from a 130 width to 150 width and
    it didn't rub on the sides, but the clearance between the center of the tread
    and the pivot point of the swingarm was pretty close. At highway speed the
    diameter of the tire grew and the swingarm tore large chunks from the center of
    the tread, ruining the tire.
    Jack Hunt, Jan 24, 2009
  3. Bubb
    Bubb Guest
    Jack,
    Thanks for the education on tire sizing and the benefit of your experience.
    Hope I can return the favor someday!!
    Tom
    Bubb, Jan 24, 2009
  4. Bubb
    . Guest
    Lots of riders ask about changing sprockets to get more fuel economy
    by running the engine at lower RPM, but they rarely ask about changing
    the rear tire diameter to get the same effect.
    1 millimeter = 0.0394 inches.
    The larger diameter 140mm tire will stand 24.93 inches tall, the
    smaller diameter 130mm tire stands 24.22 inches tall.
    The extra height of 0.355 inches would be noticeable in the steering,
    since raising the rear of the bike as the same effect as lowering the
    front.
    And, the larger tire has a rolling circumference of about 3% larger
    and that would reduce engine RPM by 3%.
    Just for the sake of illustration, that's like installing a rear
    sprocket with about 1.5 teeth less.
    Don't fret, a sprocket with 1.5 teeth less has never been made...
    ., Jan 24, 2009
