Tips for buying a Honda CT110 "postie bike" please
Discussion in 'Australian Motorcycles' started by David, Sep 24, 2007.
  1. David
    CrazyCam Guest
    JL wrote:
    The system cares. If you want a full bike licence in NSW you have to
    pass the MOST.
    Aye, try any of those on the hairpin going down to Berowra Waters Ferry!
    The tactic of getting a bike which is easier to pass the MOST on, is a
    valid one.
    But, you have to understand the entire MOST.
    A postie will allow a U-turn much more easily than lots of bigger bikes,
    but, there is still the quick stopping business, which also has to be
    passed. With its fairly small brakes, a postie isn't the ideal for that
    bit of the test.
    Oh, and you aren't allowed to change bikes in the course of the MOST. ;-)
    The Z50 would allow even a learner to do figure of eights in the U-turn
    box, but would, like the postie, be a problem with the stopping
    business, since it's hard not to lock up the front end.
    The OP, or rather, his wife, wants a quick fix and, realistically, there
    isn't one. She'd still have to spend the time and effort to learn to
    ride the postie properly. And, a decent postie bike has long since moved
    out of the two-cases of beer priced range.
    Please explain about this orientation business?
    The MOST is a straight forward competency based test.
    Dunno about that either.
    regards,
    CrazyCam
    CrazyCam, Sep 27, 2007
  2. In aus.motorcycles on Thu, 27 Sep 2007 07:14:25 +0800
    I do a U turn in about the same space as the Most requires when I
    leave the garage.
    I don't have to, but I figure being able to can't hurt.
    It's a right pain on the Norge, dead easy on the other Guzzis.
    Zebee
    - doing her bit for Theo's Law.
    Zebee Johnstone, Sep 27, 2007
  3. David
    Theo Bekkers Guest
    I have this little roundabout at the house end of the driveway, about 40
    metres in circumference.
    I am not really familiar with the most but did a few skills courses at the
    National Safety Council in Mt Lawley before they converted it to parking
    space for ECU. My unlimited motorcycle test consisted of riding around the
    block on a 125 Vespa, sans helmet.
    Theo
    Theo Bekkers, Sep 27, 2007
  4. David
    CrazyCam Guest
    Zebee Johnstone wrote:
    Do you think there is a real physical/mechanical difference, or is it
    something to do with a new, virgin, 26 grand motorcycle?
    regards,
    CrazyCam
  5. David
    JL Guest
    Yebbut, take it in the context, that was the point of getting a postie
    - 'cos then passing that bit of the test is dead easy.
    Y'know it's interesting, you've got me stumped, I wouldn't compare the
    Galston Gorge Hairpins with the feetup U turn at all - most of the
    hairpins are cambered and I do them at about 10 times the speed I'd do
    a feet up U turn, and they don't seem as tight as the MOST test box
    anyway. You start at the far left and chuck it down hard on the apex -
    I treat them as a normal corner I don't try and ride them like a feet
    up U turn - leaning the wrong way and riding the brake like a trials
    bike
    Yeah that's a fairly valid point, and you'd certainly know better than
    I would but given the advantages across a number of parts of the test
    (cone weave etc as well as u turn) would have thought it was still
    better than a bigger bike
    <shrug> Like I said you know that test far better than me but I would
    still think it's a pretty fair work around if you have a weakness in
    one area.
    The level of the skills required is far higher than the car test
    requires. The L's course opens with quite a stern lecture which about
    safety which seems very intended to scare the pants off the boys :)
    <shrug>That's my experience YMMV.
    JL
    JL, Sep 27, 2007
  6. David
    CrazyCam Guest
    JL wrote:
    Compare, if you will:-
    going to an auction, with no auction experience.
    buying an untried postie bike.
    getting it home.
    getting it to pass a Blue Slip test.
    then wife has to get used to riding it, and a postie feels very
    different from a GS500.
    do (and hopefully) pass MOST
    sell postie.
    or
    wifey goes to a proper riding instructor and gets taught how to do the
    U-turn properly on her own bike....maybe an hour.
    (It is a perfectly teachable technique. The current size of the box is
    such that, once they have been taught how to do it, they smile and don't
    see it as a problem.)
    Current U-turn box size means that leaning wrong way is only required in
    extreme cases.
    If you arrive at the hairpin on the inside, with a car coming down the
    outside (wider) track, you are bloody nearly doing a U-turn.
    A lot of it is confidence. If the wife in question isn't prepared to
    spend a wee bit of time, one way or the other, then I dunno how she is
    I agree, if the person is likely to do the appropriate practice on the
    alternate bike. It seems somewhat wasteful, but it ain't my time/money.
    I dunno what they charge, but both StayUpright and HART do a pre-MOST
    course, and then allow folk to use their bikes (as in what they did the
    course on) for the real MOST.
    However, the GS500 isn't a serious handicap to doing the MOST, and it
    makes more sense to me that she learns to ride what she'll really be riding.
    Yup! But is that a problem of the bike test or the car test?
    I know which one I'd change if I had the power. :)
    ....and the knicker off the girls.
    Does the name Ali remind you of anything? :)
    regards,
    CrazyCam
  7. David
    bikerbetty Guest
    You think 50kgs is "only a little more" than the 250s weigh? Holy dooley,
    that's only a little less than what I weigh! I suppose it's all relative -
    but when I changed from the GPX to the GS I had to haul around almost a
    whole extra "bettyweight"! (and geez, didn't I notice it!)
    betty
    bikerbetty, Sep 27, 2007
  8. In aus.motorcycles on Thu, 27 Sep 2007 16:22:35 +1000
    Higher CofG.
    Different arm position
    greater turning circle.
    The Norge has more weight up high than the T or GT. It also has fewer
    degrees of movement in the bars. I'm also more "in" than "on top", the
    ergonomics are different.
    Makes it a great bike for high speed, less good at really tight tight
    turns.
    Having dropped it once doing that turn, I'm now very scared of doing
    it and am slowly learning to do it again.
    I'm pondering a lowering kit, see if that helps the confidence level.
    Zebee
  9. David
    David Guest
    Yes, I have, She won't.
    I agree
    No, always on weekends. but we aren't far from Beecroft. Why?
    David, Sep 27, 2007
  10. David
    David Guest
    Sound advice.
    David, Sep 27, 2007
  11. David
    David Guest
    Geez, I thought it was only about 20kgs, but I quick look shows a CB250
    at 135'ish kg, a GPX250 at 138kg, while the GS500 is 180 kgs.
    It just seems light to me compared to my 285kg K1200GT I suppose. :)
    David, Sep 27, 2007
  12. David
    David Guest
    I tried the u-turn with my K1200GT ans had trouble.
    I worked out the problem when I found I couldn't make the u-turn even
    wheeling the bike with full lock.
    David
    David, Sep 27, 2007
  13. David
    David Guest
    I agree 100%, and have suggested she do some one-on-one time with the
    pro riding instructors rather than learning my bad habits.
    We will be "looking into it".
    David, Sep 27, 2007
  14. David
    CrazyCam Guest
    I live in Beecroft, at the end of a dead-end street, with a big turning
    circle.
    I also have time, during the week, and have, in the past, had quite a
    few learners round to prepare for their MOST.
    I was tempted to make an offer which my wife would later make me regret.
    (SWMBO became increasingly unhappy about me teaching folk without all
    the appropriate insurances.)
    regards,
    CrazyCam
  15. David
    CrazyCam Guest
    David wrote:
    That doesn't mean that it can't be done.
    A few years ago, the turn box was smaller, and a GPX250 couldn't be
    walked round on full lock. Lots of learners still managed to pass the test.
    I watched a bloke do the U-turn, in the old, smaller box, on a Leadwing,
    but, to be fair, he was the chief riding instructor of NSW at the time.
    regards,
    CrazyCam
  16. David
    Theo Bekkers Guest
    I don't remember your street being that boring or bogan.
    Theo
    Theo Bekkers, Sep 28, 2007
  17. David
    JL Guest
    OK, I get your point :) Reservations withdrawn
    Mmm ? Have they made it bigger ? I can remember laying out a U turn
    box for Ally to practise in and then trying the TRX in it and finding
    it a bit hard; and that's a bike that wasn't particularly heavy and
    which I was VERY comfortable throwing around (far more so than any
    I've had since. I could only get it around comfortably by doing the
    trials style trick.
    I suppose so, but I'd still do it with a lot more momentum than I
    would a feet up U turn - which means I s'pose it's a head issue for me
    more than anything - which I guess is as much about that focus on
    "must not go outside the lines" as opposed to the turn actually being
    hard. I dunno I'm a lot more comfortable leaning hard when I'm moving
    a bit than when I'm doing 10Kph. I don't think there's a corner on
    Galston I'd do slower than 45 on the KR1, (haven't taken the Raptor
    down there yet) that'd be the lefthanders, the rights can be done a
    lot quicker provided no one is on the other side of the road.
    ....snip lots of good advice
    You and me both !! I've long argued the car test should emulate the
    bike, even represented that opinion to the Aust Council on Road Safety
    (fat lot of good that did)
    Yeah indeed, to the point where each time the latest girly has done
    the L's course I have to convince her that it is actually possible to
    survive riding a motorcycle. I think it's at the right level for
    testosterone charged 18yr olds (which do indeed make up the majority
    of the attendees) but it can be a bit OTT for the somewhat less
    agressive members of the fairer sex.
    Oh indeed, but she didn't start that way- she came out of that first
    day of the course seriously thinking about not going back - that
    speech was very effective in scaring her...
    JL
    JL, Sep 28, 2007
  18. David
    JL Guest
    I suggest you contact Crazy Cam if you're on Sydney's North Shore -
    he's assisted at least one(1) of my ex's to get past their P's and a
    lot of other people from here as well.
    Better yet he works for beers :)
    JL
    (1) Scratching my head now, I can't recall Cam how many of my ex's
    HAVE you tutored ?
    JL, Sep 28, 2007
  19. In aus.motorcycles on Thu, 27 Sep 2007 16:36:58 -0700
    The RTA do provide women only courses, the more demand, the more
    courses.
    I think it would be interesting to see how many currently licenced
    riders could pass the MOST.
    I don't think I could do it on the Norge[1] but I expect I'd have
    found it dead easy on the T.
    Zebee
    [1] obligatory Norge reference. They track us on these things you
    know.
    Zebee Johnstone, Sep 28, 2007
  20. David
    JL Guest
    I definitely would have passed it on the TRX at the time I had it as I
    practised it with Ally, however I definitely couldn't have passed it
    on the Bandit (there's no way I could have got it through the U turn
    or cone weave - maybe Cam's head instructor could but I'm pretty sure
    I couldn't have). Definitely could on the KR1 (although the poor
    turning circle and having to keep the revs over 6grand would make it a
    royal pain in the arse. Raptor maybe, dunno, probably. Then again my
    skillsets are down through the fact I've barely ridden in the last
    18-20 months
    JL
    JL, Sep 28, 2007
