Tip on Installing Piston Rings
Discussion in 'Motorbike Technical Discussion' started by Nomen Nescio, Oct 11, 2005.
  1. Nomen Nescio
    Nomen Nescio Guest
    Do Not Use a Piston Ring Expander! They are good for removing, not
    installing. They will over stretch the rings.
    General: Check the gaps by inserting rings at 90 degrees to the bore, then
    rotating and use the piston to centralize the rings. When installing,
    position the gaps at 120 degree intervals. Observe the orientation. "Top"
    faces the combustion chamber. Start with the lowest (oil control) ring
    first. If its a three piece type, just spiral on the pieces. If its a
    solid cast iron type, install as you would a compression ring. When done,
    oil with SAE 30 before installing piston into bore. See below.
    Now down to the nitty-gritty. No installation tools are used. Apply
    antiseize around the circumference of the piston head where it joins the
    skirt. The rings will slide over this edge as you will see. Now, take the
    first ring you will install and place the open ends in the groove it is to
    be installed in. Hold the ends in place in the ring's groove with the left
    fingers. With the right hand, apply pressure to the ring opposite the ends
    and literally drag it over the piston until it snaps into its groove.
    That's it! Repeat for the other rings, finishing with the top compression
    ring.
    You will note the ring is ascew when you begin and as it is dragged over
    the head of the piston, it begins to line up with its designated groove
    until it drops in the goove. It is easier done than said.
    Try this method with the old rings to get the feel. You will wonder why
    its so easy now and before its been so hard to do without the worry of
    breaking or stretching the rings out of shape. I have never seen this
    method described in textbooks but it should be.
    Krusty, don't knock this post until you have tried this.
  2. Nomen Nescio
    the fly Guest
    Helluva good way to break a bunch of rings, and probably cut
    your fingers to ribbons.
    the fly, Oct 11, 2005
  3. I guess you've never installed piston rings either. Carry on.
    krusty kritter, Oct 11, 2005
  4. Don't quit your present job to pursue a career as a mechanic. You won't make
    it.
    pierce
    R. Pierce Butler, Oct 11, 2005
  5. The responses to his erroneous postings are relatively few and thanks to
    krusty they are usually informative. I have picked up some useful info from
    krusty.
    pierce
  6. Nomen Nescio
    monk Guest
    I agree completely, Krusty does seem to be a wealth of knowledge.
    monk, Oct 12, 2005
  7. Nomen Nescio
    monk Guest
    In case anyone missed my latin translation on one of Nomen Nescio's
    earlier posts, Nomen - Name Nescio - Ignorant
    Nomen Nescio - Ignorance Himself
    monk, Oct 12, 2005
