Time for a new PVR
Discussion in 'UK Motorcycles' started by Fr Jack, Feb 16, 2010.
  1. Fr Jack
    boots Guest
    Put some insulting tape on top of the amalgamating, it's (usually) not
    UV proof.
    boots, Feb 17, 2010
  2. Fr Jack
    Fr Jack Guest
    It is, when you're a TFC.
    Fr Jack, Feb 18, 2010
  3. Fr Jack
    Cab Guest
    Kit ordered already and in the post. Now I've got to decide what PC to
    put it into. A rebuild of my PVR may be in order to make sure it's up
    to spec on the HD part.
    Cab, Feb 18, 2010
  4. Fr Jack
    Well, it's early days but it does seem better. Has crashed once, mind.
    Ta for that.
    Pip Luscher, Feb 18, 2010
  5. Fr Jack
    Fr Jack Guest
    When your region starts the analogue switch off, it will get flaky for
    a while, as they make you re-tune a couple of times, but once the
    crackly band goes off, the signal power is raised10x, so it's not
    working as hard to grab a signal and cope with the faulty stream, just
    prune out the crap, each time. The biggest problem is the machine
    keeps reading the data channels, slowing thing down, that's why
    binning them helps.
    BTW, Humax boxes require a full reset, when they tell you to re-tune.
  6. The upgrade treadmill strikes again.
    Same here - I've been out of the upgrade loop for a couple of years and
    am finding out what's what with current CPUs /MBs /memory.
    If I get this box up to snuff and have it as an HD processer, I can use
    another PC networked to it as my HTPC, directly driving the projectors.
    Grimly Curmudgeon, Feb 18, 2010
  7. Fr Jack
    Higgins Guest
    Before you hit the buy button, take a look at the Vu+ Duo. It's the same
    chipset as the Dreambox and is getting some pretty good early reports.
    Spec is close to the 8000 but the price is closer to the 800.
    Higgins, Feb 19, 2010
