Thunderace clutch bite point - can I adjust it?
Discussion in 'UK Motorcycles' started by Rosco, Oct 20, 2006.
  1. Rosco
    Rosco Guest
    Hi All!
    I've just become the proud owner of a '97 Thunderace and want to know
    whether I can adjust the bite point on the clutch lever. At the moment
    it bites when the lever is more or less fully released which I dont
    like.
    I'm hoping that this isnt indicative of a problem.
    Thanks in advance
    GR
    '04 ZX636
    '97 Thunderace
    Beer must be good ..... beer is made from water,
    water is good for you therefore so is beer!
    Rosco, Oct 20, 2006
  2. Rosco
    Vass Guest
    should be a large knurled dial next to the lever ?
    Vass
    '02 YZF-R1
    www.doubleyolk.co.uk
    www.haylinglegends.co.uk (WIP)
    Vass, Oct 20, 2006
  3. Rosco
    probably not on the 'Ace clutch
    Hog, Oct 20, 2006
  4. Rosco
    Rosco Guest
    Thanks for the replies.
    The knob is to adjust the reach of the lever, but I was hoping there
    would be some adjustment on the bite point.
    Bugger
    Rosco, Oct 20, 2006
  5. Rosco
    Mike Barnard Guest
    I just sold my '96. The lever has a knob which adjusts the bite. Push
    the lever away from the bar to release a pin from inside the knob,
    turn it and try out the four positions until you find one you like.
    Also, if it's got old fluid in it, [1] change it. And to finish off
    the job set the clutch adjuster.
    Want a manual? An electronic one is available from
    www.thunderin.co.uk.
    The above should sort it out. Enjoy a gooood bike.
    Mike Barnard, Oct 20, 2006
  6. Rosco
    Rosco Guest
    Cheers Mike, where would I find the clutch adjuster?
    Rosco, Oct 20, 2006
  7. Rosco
    The 'Ace has a hydraulic clutch, right? It is unusual for any
    adjustment to be provided for hydraulic clutch actuation mechanisms,
    unlike cable where there is always provision for taking up the slack
    as the cable wears and stretches. The span adjustment is the only
    one, and you're lucky to have that.
    What you could do is check the fluid level and that there's no leaks
    anywhere. Bleed the thing, or better, change the fluid - that might
    help. Failing that, it may be a warning that a new clutch will be
    needed soon.
    There's always the bodger's way round - make up a pushrod that puts
    the bite point where you want it.
    Pip, Oct 20, 2006
  8. Rosco
    That's a span adjuster Mike, not a clutch bite point adjuster.
    That's a good start.
    Pip, Oct 20, 2006
  9. Rosco
    Relative to the 'bar, perhaps - but not relative to the effective
    travel of the lever, certainly not in the same way as a cable clutch
    adjuster will.
    Pip, Oct 20, 2006
  10. Rosco
    It will still bite at the end of the travel, close to the lever
    release point regardless of the position of the span adjuster. This
    is what the OP didn't like and wants to change, so it won't do him any
    good.
    Tell you what, let's wait till he comes back and changes it and see if
    he likes the difference.
    Pip, Oct 20, 2006
  11. Rosco
    You misconstrue my use of the word 'perhaps'.
    Pip, Oct 20, 2006
  12. Rosco
    Pip, Oct 20, 2006
  13. Damn you for bringing logic and reason onto UKRM! How could you!
    Next you'll be being nice to people.
    Phil
    Phil Launchbury, Oct 20, 2006
  14. Rosco
    Harry Guest
    It also changes the BITE position.
    Harry, Oct 20, 2006
  15. Rosco
    Harry Guest
    Sheesh, The clutch span adjuster also changes the bite position.
    Harry, Oct 20, 2006
  16. Rosco
    Rosco Guest
    Whilst I take your point, which is why I suggested we wait and see
    Indeed so Pip, I have already changed the lever adjustment and (as
    expected) this made no difference other than how far I have to reach to
    grab the lever.
    She's in for a service next weekend, so I'll get the mechanics to have
    a look and do the necessary.
    Rosco, Oct 20, 2006
  17. Rosco
    Harry Guest
    Agreed, apart from the word "perhaps"
    Harry, Oct 20, 2006
  18. Rosco
    Domenec Guest
    I can assert that even a very little rock found by the road can do that
    job on an 'ace.
    Next, I changed clutch fluid.
    Domenec, Oct 20, 2006
  19. Rosco
    Domenec Guest
    Shall your descendants be blessed until the 7th generation...
  20. Rosco
    <rootles in bookmarks>
    Here's another: manuals, data and microfiches:
    http://users.firenet.uk.com/taz2661/a/index.htm
    You can never have too many of these tagged, as they seem to come and
    go like will o' the whisps.
    Pip, Oct 20, 2006
