throttle problems
Discussion in 'Motorcycle Technical Discussion' started by t, Jun 18, 2005.
  1. t
    t Guest
    Hey gang,
    working on my '83 Honda VT 750C Shadow, I had problems with the fuel
    acting like it was not flowing about half way thru the throttle in all
    gears. I've changed the fuel filter, air filter, and some of the fuel
    line. I also broke down the carbs and cleaned them, although they
    didn't look bad. However, now I can't even make it a quarter way thru
    the throttle without it giving out. I'm going to check the throttle
    cables, make sure they are set properly, the fuel pump and recheck the
    carbs. Any other ideas what might be the source?
    t, Jun 18, 2005
  2. t
    t Guest
    BTW, I would roll the throttle til it hit 4000 rpm, then it would choke
    out. now, i can't get it above 1300 before it tanks. it dies like it is
    choking, almost an instant cut-off.
    t, Jun 19, 2005
  3. If you can ride your Honda with the "choke" on and it quits every time
    you turn the "choke" off, your problem is probably plugged up idle
    jets.
    Constant vacuum carbs run on the idle jets up to 1/2 or 3/4 throttle,
    and if the idle jets and ports are plugged, the motorbike just won't
    accelerate...
    Constant vacuum carburetors don't usually have a real choke plate, they
    have a tiny little bypass carburetor built into the side of the each
    main carb, and when you turn the "choke" on, you're opening up a rather
    large jet in the float bowl.
    The main carb can suck gas right out of the float bowl through this
    large jet, so the engine will start and run. But. as the engine heats
    up, you have less and less control of the engine speed since the
    mixture becomes far too rich when you're running on this bogus
    "choke"...
    I've explained how to clean them about a bazillion times. You can
    google up "kaybearjr@aol +idle jet" or "spectraltarsier@aol +idle jet"
    to see how to clean the carbs out and readjust them...
    krusty kritter, Jun 19, 2005
  4. t
    t Guest
    I haven't needed the choke to start it since I put in the new battery.
    I dismantled the carbs and cleaned all the jets, even the choke intakes.
    I followed the fuel line up past the fuel pump, which seems to be
    working fine. I didn't actually measure output, just kind of eyeballed
    the output into a jar. I did find the line from the three way split was
    kinked. The hose I replaced was a very hard type of line, whereas the
    replacement line was too flexible, and kinked when bent at a 90 degree
    angle. So apparently the rear cylinder was starving. However, this
    doesn't explain why it was having problems before all this. There was a
    slight cut in the old line, but I don't know if that was prior to or
    after taking it off. I'm going to get a 90 degree elbow and see if that
    will eliminate part of the variables, then look to see if there are any
    more.
    t, Jun 19, 2005
  5. I didn't say anything about STARTING your Honda...
    What I said was, " If you can RIDE your Honda with the "choke" on and
    it quits every time you turn the "choke" off, your problem is probably
    plugged up idle jets."
    Try riding with the choke on and see if it doesn't run with more
    throttle until it gets hot, and then the RPM is uncontrollable. That
    indicates plugged up idle jets and idle ports and plugged up idle
    mixture screws...
    If the fuel pump will supply 12 ounces of gasoline in a minute, the
    pump is OK...
    If you have fuel supply problems to the carbs, the engine will suddenly
    start running on only one cylinder. But it will take a while for that
    to happen, you might have to ride for miles and miles...
    I bought a set of used racing carbs from a friend and he had been using
    thick walled automotive fuel hose. When the hose was connected to the
    petcock it was slightly kinked, retricting fuel flow...
    My friend had the same motorcycle that I did, but he never had the
    problems I ran into. He was drag racing the motorbike and drag racing
    requires full throttle running for short distances. I was riding out on
    the open road, using lots of throttle for a mile at a time, and I was
    having fuel starvation problems. The engine would start running on 3
    cylinders, and then on 2 cylinders...
    The fuel starvation problem got so bad from the hose kinking I couldn't
    ride over the hills to get home, so I started taking the gas tank off.
    I had the rear bolts of the gas tank out and lifted up the gas tank and
    the engine started and ran. So I finally realized it was just a kinked
    hose after about a month of wondering what the hell was wrong. I stuck
    a beer can under the gas tank and rode home and then I cut the fuel
    hose half an inch shorter so it wouldn't kink anymore...
  6. t
    t Guest
    my mistake about misreading your comments on the choke, i'll give it a
    try. we looked at the fuel pump again, and it runs great, so it is
    something after that.
    t, Jun 19, 2005
