Throttle hesitation '83 VT750 Shadow
Discussion in 'Motorbike Technical Discussion' started by J. S. Pack, Jul 15, 2004.
  1. J. S. Pack
    J. S. Pack Guest
    Got this annoying throttle hesitation problem on my old VT750. It happens
    frequently when the engine's warm (not when cold) and has been idling a
    minute or so, as at a stoplight, or after I've shut off the motor for a
    brief time and restarted.
    I turn the throttle and it just pretty much sticks until it gets to a
    2,500-3000rpm threshold then suddenly roars into life. It means I have to
    be extra careful w/ the clutch, obviously, and I have to be sure I've
    gotten up to the threshold before I can jump out into a busy street.
    Anybody have an idea what could be causing this?
  2. J. S. Pack
    mike Guest
    I have a related problem. My 83 Honda VT500 Shadow runs just fine at
    low speed. After a few minutes at 55 MPH on the freeway, it acts like it's
    running out of gas. But If I open the throttle way up, it sputters
    back to life. If I open up the carb drain plugs I get what should be
    plenty of fuel flow to run the bike.
    Ideas?
    Thanks, mike
    Return address is VALID.
    Bunch of stuff For Sale and Wanted at the link below.
    Compaq Aero floppy,ram,battery.
    FT-212RH 2-meter 45W transceiver.
    Toshiba & Compaq LiIon Batteries, Test Equipment
    30pS pulser, Tektronix Concept Books, spot welding head...
    http://www.geocities.com/SiliconValley/Monitor/4710/
    mike, Jul 15, 2004
  3. J. S. Pack
    mike Guest
    That's why I opened the bowl drain plugs in the carbs. That should
    include effects of all the above??? yes? I rigged up some plastic
    tubing from the bowl drain and ran it up the side of the carb so I could
    see the fuel level. Seems ok in the garage, but I never figured out
    how to look at the fuel level at freeway speeds. I'm too young to die ;-)
    Yes, I've tried this. Results are inconclusive. By the time I hold the
    clutch with one hand, remove the key, open the tank, close the tank, put
    the key back, restart the engine, all while dodging traffic at 55MPH,
    the symptom is gone. I'll do some more experiments tonight on the freeway.
    OK, I'll try pulling the idle jets. Can an idle jet have that much
    effect at freeway speeds?
    Yeah but...if the thing runs fine for several miles before choking up,
    wouldn't that eliminate the air leak possibility?
    Remember it runs fine all day below 40 MPH.
    I'll try running it in a lower gear to simulate higher freeway speeds.
    Wondering if the ignition system is overheating and cutting out at
    higher speed??
    Sure acts like gas starvation tho...
    This thing has 83,000 miles of stopandgo garage sale travel on it.
    Guess I should be glad it ran this long.
    I have almost a whole other bike I can use to swap parts if I could
    figger out what to swap...yeah, I know, swap the engine...
    mike
    mike, Jul 16, 2004
  4. Hmmm, wonder if that explains the morning stall on my Vespa
    GT200 (I need to really dig into the engine compartment -- find out
    which of two carburetors I have)... Was trying to avoid coming to a full
    stop at a light, and when the light went green, my wobbly "hit the
    throttle" resulted in a stall... Suspect I was at the transition from
    engine braking and coast (centrifugal clutch), and didn't have enough
    "push" to keep running when the carb suddenly changed state.
    Dennis Lee Bieber, Jul 16, 2004
  5. Chrysler products used a "dual ballast resistor". A low
    resistance circuit for the starter position, and a "normal" resistance
    for run mode. Never saw a spec for the coil voltage, but did have the
    start position half blow once. Was quite annoying -- engine would crank
    properly, but not start... Then when you let go of the key, you'd get
    one cylinder firing (my experience with that car was that I only needed
    two cylinders to get it started -- even in the dead of a MI winter with
    straight 30W oil! Chrysler reduction gear starters could pull a freight
    <blink><blink> That sounds backwards... At least for Chrysler
    systems -- the dual ballast resistor reduced resistance while cranking,
    meaning a higher voltage to the coil (well, same voltage as would be
    seen without a starter motor draining things).
  6. J. S. Pack
    mike Guest
    The plot thickens. My vacuum cylinders are floppy.
    I hooked up all manner of tubes and clamps
    so I could capture the fuel level while
    cruising at 55. I did catch the level being
    low, but couldn't repeat it. And the fuel
    level didn't come back up when I stopped.
    Maybe I should not have tried to do this at midnight.
    Results were inconclusive, but sufficient for me to
    decide to pull off the carbs and clean up everything.
    I also discovered that one of the exhaust pipes was
    plugged up, but replacing that didn't help.
    New problem.
    When I push on the vacuum cylinder of the carbs
    on the doner bike, I feel two forces. There's a
    spring. There's also a velocity dependent force
    of the piston accompanied by the sound of air
    rushing out some orifice or other.
    When I do the same thing on the bad bike,
    the vacuum cylinders have the spring force ok, but
    the bottom half of the excursion has no piston force.
    The last half of the excursion does have the piston
    force and the sound of air rushing.
    This can't be good...
    Both carbs behave the same.
    Last time I had 'em apart, there was some cracking of the
    diaphragm. Maybe I've developed a hole. Seems odd that
    both carbs behave the same. I'd expect them to fail
    one at a time.
    Looks like I'm swapping carbs.
    But the things are so darn expensive that I'd like
    to understand what's going on and fix it. Resale
    value like they are is zero...
    mike
    HP200LX 10MB + MODEM + LEATHER CASE
    Sony Digital Camera
    mike, Jul 21, 2004
