Throttle and Clutch Cables
Discussion in 'Classic Motorbikes' started by sweller, Jan 11, 2009.
  1. sweller
    You would have thought so, it's not exactly a rare bike, but that's not
    my experience locally.
    Google mojo shows clutch patterns but not throttle. Venhill said they'd
    need an old one to copy but that came at a price.
    I have quite few old bikes and the universal kit is an ideal solution.
    The Guzzi has spare cables, greased up and in sealed bags, stashed down
    the side of the battery.
    sweller, Jan 12, 2009
  2. sweller
    Beav Guest
    I got pattern cables for my VN 750. Clutch, choke and throttle, plus
    stainless brake lines and all for less than Kwak wanted for a clutch cable,
    so I'm with you there.
    I had all mine made up by a company in Rochdale and the cables are stainless
    steel and pre lubricated. I've no idea what the name of the company is
    though, even though I can drive/ride there without getting lost:)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 12, 2009
  3. sweller
    Beav Guest
    I know a bloke who changes his chain and sprox and keeps the old ones "just
    in case". I asked him "In case of what, in case you decide to put shagged
    parts back ON the bike"?
    He seemed to think I was delerious or something.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 12, 2009
  4. sweller
    Rich B Guest
    Beav typed:
    In case of breakage, I imagine. Better an old worn one than a broken new
    one. I've done this with parts that have a bit of life left in them, and
    it's saved me on a Bank Holiday afternoon more than once. It depends on
    your definition of 'shagged', I suppose - I tend to replace things before
    they break, so bits are usually worn but serviceable (ish). I wouldn't keep
    anything broken or worn out.
    <checks garage, looks at sky and whistles>
    Rich B
    1971 S2a
    1995 XT600E
    2003 ST1300 Pan European
    Oh, and a Ford
    Take out the obvious to email me.
    Rich B, Jan 12, 2009
  5. sweller
    Beav Guest
    But half a dozen? He throws **** all away even when it's totally useless.
    If you saw any of his sprockets, you'd wonder how the bike made it up the
    street.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 12, 2009
  6. <Shuffles nervously>
    I do something similar. I know Champ does, too.
    The Older Gentleman, Jan 12, 2009
  7. sweller
    You devil you. I'm tempted to x-post this to the fleabay terrorists so
    spacker can use it as ammunition later.
    Andy Bonwick, Jan 12, 2009
  8. sweller
    Rusty_Hinge Guest
    The message <>
    Some sprockets (most?) are reversible, so the unworn driveside is almost
    like new.
    <thinks>
    Drive in reverse?
    You've been looking in *MY* garage...
    Rusty_Hinge, Jan 12, 2009
  9. You don't want all the attachment bolts of your sidecar loosened in
    Germany, do you?
    Mind you, he's such a nutter it would be quite amusing.
  10. sweller
    Why would you want to hurt Platy?
    He's too thick to check the original post so he'd almost certainly
    take it and run.
  11. sweller
    Bollocks do I!
    Mind you, I might have done years ago, when I was impoverished.
    Champ, Jan 12, 2009
  12. Go on, then. I dare you....
  13. sweller
    crn Guest
    I always replace all cables when I get a new-to-me SOB, the old ones are
    of dubious parentage but they are usually good enough to keep as spares.
    Its a bit like the half-shagged spare wheel in the boot of a car, good
    enough to get you home.
    crn, Jan 12, 2009
  14. sweller
    x-posted because he didn't even try to deny it.
  15. sweller
    Never dare a fool...
    You're going on holiday aren't you?
  16. sweller
    Christ. You haven't really got the hang of running shite old bikes on a
    shoestring.
  17. sweller
    Not really. When worn, the teeth on a sprocket are hooked in the
    direction of the load, and usually worn across their whole length.
    Reversing them is a quick way to **** whatever chain you run against
    them.
    Champ, Jan 12, 2009
  18. sweller
    What about if the replacement component is slightly too short to fit over
    the new sprockets?
    platypus, Jan 12, 2009
  19. sweller
    crn Guest
    Cables are cheap, so are other essential items like brake shoes.
    Why would I want to run a nice old machine into the ground ?.
    Classic bikes deserve some respect, unless you are talking about some
    truly horrid winter hack.
    Properly fettled a 40 year old Bantam should be good for another 40 years
    of weekend pootling before retiring to be a show queen.
    One broken front brake cable could turn it into a total wreck and more
    importantly cause pain.
    At my age bones are fragile and take forever to mend.
    crn, Jan 12, 2009
  20. sweller
    Rusty_Hinge Guest
    IME shoestrings tend to break when used instead of cables, even on SOBs.
    Rusty_Hinge, Jan 13, 2009
