Thread repair suggestions
Discussion in 'Motorbike Technical Discussion' started by Mike W., Oct 7, 2008.
  1. Mike W.
    Mike W. Guest
    I'm about to button up one of my KZP's valve covers. It's amazing how
    vulnerable the threads up there are. On this bike, it's my first time in it
    ever though I've been in/out of the other numerous times. I had to do, I
    think 5 helicoil jobs on compromised threads and fortunately those were all
    at the outboard parts of the valve cover where I could easily get at them
    from above with a drill.
    Unfortunately, there is one that, while not in total failure, just looks
    like crap. It's positioned such that the backbone of the bike does not let
    a conventional drill fit.
    Question #1: Any suggestions I should be aware of for drilling out the hole
    in this application?
    I'm considering just stripping the crap out of that hole with a bolt (it's
    not hard!) and putting the helicoil insert into that hole. Is there
    anything less primitive?
    Question #2: I've heard a time or two about a thread repair system called
    Timeserts. Can anyone give me their third-party comparison of the two
    solutions? Thanks.
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
    71 KG 100 (Hodaka-powered)
  2. Neil T. Dantam, Oct 7, 2008
  3. Mike W.
    lugnut Guest
    I don't know which one your are working on with yours but, if the hole is not
    exactly under the frame tube but can be seen when looking straight at it from
    above, you may be able to use a bit extension bar. It is like a socket
    extension and holds the bit with a pair of allen set screws. I got one at Home
    Depot some years ago. Use that to drill it to the correct size. The tap may
    have the correct size for a ratcheting wrench like the ones used on battery side
    terminals.
    Lugnut
    lugnut, Oct 7, 2008
  4. Mike W.
    lugnut Guest
    Didn't leave you a url to see one
    http://www.amazon.com/s/ref=nb_ss_hi?url=node=552806&field-keywords=bit+extension&x=0&y=0
    Lugnut
    lugnut, Oct 7, 2008
  5. Mike W.
    Kevin Guest
    just get the epoxy thread repair. it is fine for a low stress job like
    that. KB
    Kevin, Oct 7, 2008
  6. If you don't pull the head you'll be dropping shavings into
    the engine. More importantly, you need to worry about the
    little hunk of hardened steel that you break off the helicoil
    after it's in place. Also, on a long stud, it's real easy to cock
    the drill slightly and wind up with a stud where the far end
    is cocked enough to not line up quite right with the hole.
    There's a thread restore compound (made by J.B. Weld
    I think) meant to work on low stress threads. Like J.B.
    Weld, it's a hardening putty. Don't know if this would
    work on your problem or not.
    I've substituted allthread threaded rod in a longer length
    for a pulled valve cover stud. On one cover, I found there
    was still good thread past where the original stud threaded
    in. On the other side, since the hole went through to
    an empty space, I was able to use a locknut to hold
    the threaded rod.
    Timesert is another thread repair similar to helicoil
    but bulkier, using a solid threaded cylinder instead
    of a thread coil. Usually, they tell you to try a helicoil
    and use a timesert if the helicoil fails.
    Rob Kleinschmidt, Oct 7, 2008
  7. Mike W.
    paul c Guest
    Just my opinion but I think a helicoil or timesert is overkill for a
    valve cover. If it is just one of a half-dozen or more fasteners that
    only have to counteract oil and atmosphere pressure why not just seal up
    the bolt-hole with alum weld or somesuch and forget about it (unless
    it's a show-bike, which I guess it wouldn't be if it's full of heli-coils!).
    paul c, Oct 7, 2008
  8. Mike W.
    paul c Guest
    whereas if the diaphragm cover of a cv carb has had one of its typically
    four screw holes mangled, it makes sense (at least to me) to tap up to
    the next size thread. (now, when I look at twenty-year old bikes or
    older for friends who are thinking of buying them for a grand or so, one
    of the first things i look at is the screws on the carb tops and bottoms
    - if they look like they've never been touched, I tell friends to
    examine the rest of the bike, because this test tells me that there's at
    least a chance that a hacker hasn't been wanton with the mechanicals!).
    when it comes to cover fasteners of various sorts and a friend hands me
    a chipped Phillips head, I tell him to throw that screwdriver out and
    get me a good one. If it doesn't budge with my (weak) wrist turning it,
    I go immediately to the impact driver. If no luck then, I take at least
    a few hours off to reconsider the situation! Just my two cents, I'm on
    a budget, both bucks and years.
    paul c, Oct 7, 2008
  9. Mike W.
    Mike W. Guest
    Gentlemen,
    MANY thanks for the excellent suggestions. I'm embarrassed I didn't
    consider a bit extension on my own and was unaware of putty-type thread
    repair. I know there's not a lot of torque on these bolts but the ability
    of them to strip during routine maintenance is still legendary! Now I have
    some better weapons in the arsenal. Again, thanks!
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
    Mike W., Oct 8, 2008
