Thoughts about chatter
Discussion in 'Motorcycle Racing' started by Julian Bond, Aug 25, 2004.
  1. Julian Bond
    Julian Bond Guest
    For years now the teams have been talking about "controlled flex" in
    frame design. Now a new Michelin has appeared that appears to cause
    chatter from either the front or rear or both.
    As an engineer I never liked the idea of controlled flex. It just feels
    wrong. Mechanical chassis design feels like it ought to be about
    stiffness to weight ratios and wheel movement should be about suspension
    spring rates and damping with every effort to separate the two.
    I wonder if what has happened is that the natural frequency of slip of
    the new tyres has now coincided with the natural frequency of vibration
    of the frame-swingarm with insufficient damping in the tyre
    construction. This would be independent of suspension changes which
    might explain why it's almost impossible to cure by tweaking spring and
    damper rates. And the solution may be to stop messing with controlled
    flex and to build stronger/stiffer frames with higher natural resonant
    frequencies.
    It might also explain why the Yamaha is less affected by chatter but
    appears to be more snappy at the sliding limit. This would make sense if
    their frame-swingarm were stiffer than the Hondas.
    Just a theory. Maybe there's nothing in it.
  2. Julian Bond
    Wayne Guest
    You may already know that when the bike is leaned over and hits a bump
    the wheel travel will have some component that is vertical to the road
    surface. So until a 3D (or at least 2D) suspension is developed, flex
    in the chassis or suspension is all that's available. I agree that it's
    an ugly solution.
    And a very interesting one. Another solution would be to build weaker
    frames with a lower resonant freq and do a better job of providing the
    teams with the ability to control the chassis flex and damping.
    Paraphrasing some famous mathematician/physicist, if you correctly state
    the problem, the solution is readily apparent. A lot of solutions fall
    out of your statement of the problem.
    Wayne, Aug 25, 2004
  3. Julian Bond
    Julian Bond Guest
    It's not at all clear that this is what's going on. Try imagining a
    motorcycle travelling in a straight line traversing a 45 deg slope. Now
    put a bump in the road surface. Perhaps as a ridge at 90 deg to the
    direction of travel. To what extent does the M/C move sideways? Now
    imagine the same thing with an infinitely stiff chassis and wheels but
    with soft perfectly damped suspension. Now try and plot the sideways
    forces on the (rotating) wheels.
    I'm not at all convinced that sideways flexibility of the contact
    patches is needed to keep the normal force of the tyres constant against
    the road.
    But then received wisdom is that M/C rotate around the contact patch
    during turn in and I don't agree with that either.
    Whatever, I feel sure that there's a connection between tyre grip
    characteristics, tyre flexibility and chassis stiffness/flexibility.
  4. Julian Bond
    Chris Cavin Guest
    Theoretically, given an infinitely stiff chassis with zero friction, the
    suspension will deflect in the plane of the suspension no matter what angle
    the motorcycle is leaning. I'll agree there. Also, wouldn't the force
    transmitted to the suspension increase to infinity as the motorcycle
    approached a 90 degree lean angle?
    Since we DON'T have an infinietly stiff chassis and no friction, though, one
    must plan for the sideways deflection of the chassis. There will always be a
    vertical component of force acting through the contact patch at an angle to
    the chassis which will cause a sideways deflection no matter how stiff the
    chassis. You could make a chassis so stiff as to make it essentially
    immovable for the purposes of road racing, but then you'd have to deal with
    the fact that stiction in the forks due to side loading will greatly reduce
    the response of the suspension's ability to convert out-of-plane forces to
    in-plane forces.
    -Chris-
    Chris Cavin, Aug 25, 2004
  5. I thought that the 16.5" wheels gave mor damping in the tyre when leaned
    over and that the higher side walls gave room for more flex of the contact
    patch, giving a larger contact area, and more flex in bumps where the old
    17" had a contact very close to the rim.
    Anyway, interesting idea, although I don't believe in a frame as stiff as
    possible. But a frame with a frame with rather dead material, giving som
    flex but minimal return spring action. (sorry for my bad description but you
    get the idea) I also think Suzuki tried a very stiff frame in the '80ies?
    Totally unridable.
    As mentioned in other posts, you will allways have the grafity causing a
    force right down and stickyness in the suspension that need some kind of
    suspension help.
    Well at least a frame with a different resonant frequency and even better
    with an alloy that make the flex "softer".
    /MBE
    Morten Becker-Eriksen, Aug 25, 2004
  6. Julian Bond
    Doug Eleveld Guest
    I'm and eng (electrical) too and agree that the idea of tuned flex
    'feels'
    wrong. You might be right that the problems with chatter are related
    to
    the newer tire designs.
    I have been playing with an idea in my mind to solve this problem.
    Can you give me your opinion on it?
    Imagine a swingarm that allows a small abount rotation (maybe 5 to 10
    degrees)
    in an axis along the length of the swingarm. The top of the rear
    wheel would
    be able to move left-right a bit and the bottom of the wheel (the
    contact patch) would move the other way. The rotational movement
    would have a fairly
    high spring rate and be well damped. This decouples the road bumps
    from the chassis when the bike is on its side and the normal
    suspension is less effective. This decoupling would greatly reduce
    and interaction between road bumps and chassis flex. If chatter is
    the result of the natural frequencies of these two things interacting
    this system should stop chatter completely.
    As a side effect when going around a corner and hanging off, the real
    wheel would have the tendency to lean less than the rest of the bike
    and might increase the contact patch, increasing traction and the
    possibility to lean a bit more.
    I imagine that the rear end of a bike like this would feel very
    'loose' on the back end. Riders arent used to suspension moving in
    this direction. So the damping and spring rates should probably be
    fairly high. I really have no idea if the rotation would make things
    difficult for the chain since it would lose a bit of alignment when
    the suspension rotates.
    What do you think?
    Doug Eleveld
    Doug Eleveld, Aug 25, 2004
  7. Julian Bond
    Julian Bond Guest
    Heron Suzuki did quite a lot of experimenting then with things like rim
    brakes. One of their prototypes used bonded aluminium sheet on expanded
    ally inner. I think what happened was that it didn't work with the tyres
    and suspension of the time and didn't feel "right" to the rider. It was
    also awkward to work on with the engines of the time making things like
    spark plugs hard to get at. That point about what the rider "thought" is
    significant. I think you'll find that modern frames and swingarms are
    stiffer now than that bike was then. And tyres give much more grip while
    we're using quite a bit less rake and trail than then.
    Somebody said there are no M/C engineers, only experienced M/C
    mechanics. And M/C development tends to go surprisingly slowly as
    everyone concentrates on last year plus 5%. If you look back on race M/C
    development it's amazing it took them all so long to get at least some
    stiffness into frames, only to then switch to aluminium with out
    changing the layout. It then took another 5 years to discover that ally
    designs need big box sections. This is all 1st year engineering stuff or
    high school physics.
    Controlled flex frames have now become gospel whether it's actually true
    or not. Now that tyres, wheels, brakes and suspension have moved on
    maybe it's time to challenge that.
    But then Ducati 999s go faster if you remove a bolt on frame member that
    didn't add much stiffness anyway. Go figure.
  8. Julian Bond
    Chris Cavin Guest
    Interesting. Can you elaborate?
    -Chris-
  9. Julian Bond
    Julian Bond Guest
    It's a piece about 12" long that sits horizontally just below the rear
    of the tank on each side. Part of Ducati's cunning plan with the 999R
    homologation special last year was to add a bolted in extra frame
    member that adds another triangle. Apparently the factory riders go
    faster with it removed because "there's more flex in the frame, giving
    more feedback". I guess they know what they're doing but it sounds like
    a load of old bollocks to me.
    You can see it in two of the bikes here
    http://www.twistgrip.co.za/ducati_999r_fila.htm
  10. Julian Bond
    pablo Guest
    Engineering is always a compromise...
    That said, there is another solution: tire technology. I'd assume that the
    fatter the tires, the more they can help absorb bumps when the bike's leaned
    over.
    But I agree with everything everybodu has said in this topic, and would not
    be surprised if the suspicion turns out to be accurate. What's next, tunable
    chassis flex where stiffness in critical chassis areas can be dialed in?
    ....pablo
    pablo, Aug 25, 2004
  11. Along with a poor chassis design, chatter may be a misunderstood fluid
    dynamics problem within the forks.
    Jiann-Ming Su, Aug 26, 2004
  12. This is certainly the case where the problem is not well understood...
    Those would be the design parameters that the factory and suspension
    engineers haven't quite figured out. Hence, chatter continue to exist.
  13. Julian Bond
    Wayne Guest
    forces on the (rotating) wheels.[/QUOTE]
    You're right it doesn't move sideways. The wheel must travel further in
    it's single dimension of travel to absorb the full bump height as
    measured normal to the road surface, or sqrt(2) x the bump height in the
    45 deg example.
    Wayne, Aug 26, 2004
  14. That's racing. You don't have to be perfect, just better than your
    competition. You'd be surprised at how little "engineering" goes on in
    racing. The space agencies use teams of engineers with PhDs. Most race
    teams may not even have formally trained engineer, and maybe guys with
    undergrad degrees. I can tell you that there is A LOT of math and
    physics that engineers with only an undergraduate education are missing.
    Vehicle dynamics simply cannot be solved using a simple three degree of
    freedom model. Newtonian mechanics is just not the best way to solve
    complicated dynamics problems, but that's what undergraduate engineers
    are taught.
    I was arguing with a guy on Slashdot who claimed to have done data work
    on Schumacher's Benetton team. He said they don't even use the data
    collected to help design the following year's car. The modelling
    package powerful enough to do vehicle modelling sat dormant on their
    PCs (http://tinyurl.com/68r4b). So the statement that there's no
    motorcycle engineers really applies to all of racing. The "real
    engineering" is being done at research facilities (govt, corporate,
    universities). You may actually find better engineering work from some
    random amatuer racer than you will on a full blown race team.
  15. Julian Bond
    Tim Lowe Guest
    Isn't that why Colin Edwards was testing with a 16in front in Dec-Jan? The
    smaller front wheel needs a tire with a taller profile to keep the same
    rolling circumference. His theory (from his website forums) was that they'd
    be able to mitigate some of the chatter by letting that taller sidewall soak
    up some bumps when leaned over. There were some other problems though that
    made it a bad choice and thus he went back to the stock 17in wheel. In
    fact, at the beginning of the season they had grafted on his superbike forks
    and wheel at first but it wasn't any better in testing.
    --Tim
    Tim Lowe, Aug 26, 2004
  16. Edwards has been using the 16.5" since his superbike days. He has
    mentioned that he was developing the GP tire being used now a few years
    ago in superbike.
  17. Julian Bond
    Andrew Guest
    Edwards had been complaining of chatter and an unsteerable bike for ages.
    He recently got some new goodies, his team made some other adjustments and
    suddenly he is taking podiums. Interesting.
    Andrew, Sep 1, 2004
  18. Followed by the team telling him he had to run a tire he didn't like
    in the Brno race.
    Jiann-Ming Su, Sep 2, 2004
  19. Julian Bond
    Andrew Guest
    Yup, they've been treating him like the red headed stepchild for the whole
    season.
    Andrew, Sep 2, 2004
  20. Julian Bond
    Me Guest
    Is Edwards the new Max Biaggi? Remember Max always bitching that he didn't
    get the best equipment, thus "explaining" his lame performances? Just ride
    the bike Colin, like Sete is doing........
    Fred
    Me, Sep 3, 2004
