Those Bicycle Speedos and Drilling Stainless Steel
Discussion in 'UK Motorcycles' started by Donegal Paul, Jan 23, 2004.
  1. Clean and lube the speedo cable. It's running dry and winding up then
    releasing; it will break shortly.
    If it's not that, it's just a shit speedo.
    As far as drilling stainless goes, you can grind your drill bits to a
    more appropriate angle, but that's a pain in the arse. Buy a couple of
    Titanium coated bits and drill slowly with the proper lube for
    stainless.. umm... kerosene, I think.
    Bonwick can probably tell you more accurately.
    Wait a minute; how thick is this stainless? If it's only stainless
    sheet, ordinary jobbers drills will do. Just make sure they're sharp and
    cut slow with lube.
    GS 850 x2 / SE 6a
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Jan 23, 2004
  2. Donegal Paul
    Salad Dodger Guest
    heh.
    The one on the KH500 does that when stationary.
    | ___ Salad Dodger
    |_\_____/_| ..62661../..14297.../..3157./.19406
    \|^|/ ANORAK#17
    Salad Dodger, Jan 23, 2004
  3. Donegal Paul
    Donegal Paul Guest
    "Grimly Curmudgeon" said to, "Donegal Paul"
    Dont worry im pretty sure i know why its doing it, its the internal mech in
    the front wheel.
    Ah, sir now knows that "They all do that, sir" does actually apply in this
    case.
    Basically, the mech is all metal, the speedo has a ring on the inside hub,
    which the original one wore out (it *was* 40+ years old)
    so i got a new one, however, as they arent made anymore it had to be a nylon
    one, which has already worn out :-(
    However, there is a dealer that is now remaking them, so ill be getting out
    my new debit card in the morning :)
    Its only 3mm thick, 4mm at most. I think I need more lube [1]
    [1] Que Quips ;-)
  4. Donegal Paul
    curium Guest
    but officer, it doesn't work on all surfaces.
    curium, Jan 24, 2004
  5. Donegal Paul
    Feel free to speed as much as you like on sheet ice.
    Mebbe wheelies would affect it ...
    Pip, Jan 24, 2004
  6. a KH500 !!! ohh legendary...a flexi flier, fulliautomatix once had a
    KH250...much fun!!
    i have an old makita drill i use for metal, it turns very slow compared to
    the modern stuff...marvellous, look out for old low geared drills at
    clearance sales and the like
    has no hammer function tho...so i have 'slow drill' and 'fast drill' for
    appropriate jobs
    and 'battery drill' will also drill SS sheet
    fulliautomatix, Jan 24, 2004
  7. Donegal Paul
    Cable required/s greasing
    sweller, Jan 24, 2004
  8. Donegal Paul
    The Class 59 railway locos had a radar based speed pickup (they utilised
    a wheel creep system for greater tractive effort which would make a
    standard speedo drive useless).
    Occasionally, when stood stationery over a pool of water the speedo would
    flick randomly. The ripples on the puddle confused it. Apparently.
  9. Donegal Paul
    Remember to use special electrical grease, otherwise it'll just **** up
    the works.
    sweller, Jan 26, 2004
  10. Donegal Paul
    Donegal Paul Guest
    I basically have 8 holes to drill, but as its like box section that doubles
    it to 16.
    I have managed to do two 2-3mm holes so far, thats it :-(
    Ive not managed to go get any of those cobalt bits yet
    Donegal Paul, Jan 26, 2004
  11. Donegal Paul
    Ah, the fashion statement of those days!
    Helps them tramline no end.
    Hog, Jan 26, 2004
  12. Donegal Paul
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Donegal Paul
    You're in Bedford, right? I'm just north of Hitchin. Mark them up and
    bring them over here.
    Nigel Eaton, Jan 26, 2004
  13. Donegal Paul
    Donegal Paul Guest
    "Nigel Eaton"said to Donegal Paul
    **** that would be great Nigel if your not too busy mate?
    is the email reply you use here spamtrapped? Its not obvious if it is
    Donegal Paul, Jan 27, 2004
  14. Donegal Paul
    Nigel Eaton Guest
    It isn't.
    Nigel Eaton, Jan 27, 2004
