This evening's efforts...
Discussion in 'UK Motorcycles' started by sweller, Jul 8, 2005.
  1. sweller
    The engine's back in and the primer's been laid, although it's still
    reacting and looks like shit.
    I'm away for the weekend and only have two evenings free before Chimay.
    <fx: Countdown music>
    http://www.sweller.dynalias.org/guzziprogress/
  2. sweller
    Martin Guest
    This one:
    http://www.sweller.dynalias.org/guzziprogress/photos/photo2.html
    Reminds me of the school master from "The Wall" cartoon
    http://www.allfloyd.com/images/the_wall/wall_from_rinrhall.jpg
    Martin:
    VTR1000 Firestorm
    Martin, Jul 8, 2005
  3. sweller
    Martin Guest
    re-assembly is the reverse of this process
    Martin:
    VTR1000 Firestorm
    Martin, Jul 8, 2005
  4. sweller
    mups Guest
    sweller says...
    Somehow I get the feeling that what would take most of us about 3 weeks
    to achieve you will no doubt manage in 2 evenings.
    Or you could always take the 7R.
    mups, Jul 9, 2005
  5. sweller
    zymurgy Guest
    Heh, I know how you feel, i've been frantically SOB fettling for the
    last 2 days (and the last 2 weekends)
    So been out tonight after building 1 good fork leg out of the knackered
    one on the running bike and the spare forks & seals the seller gave me.
    .... to find someone had snapped off one of the mudguard bolts into a
    blind hole into the fork bottom.
    Bastard !!!!
    Cue lots of swearing [1], plus gas and heat. Won't budge, so i've left
    it soaking to tackle it again tomorrow.
    Cheers
    Paul.
    [1] Clearly 'cos I should have checked the condition a bit more
    carefully before i rebuilt it :)
    zymurgy, Jul 9, 2005
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    If you need to borrow a LH drill bit, then figure out a size[1] and I
    can bung one in the post to you (unless you're close enough to Hitchin
    to collect it?). That'll shift the fucker.
    [1] Go about 3 - 4mm smaller then the minor diameter of the thread
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Wicked Uncle Nigel, Jul 9, 2005
  7. sweller
    zymurgy Guest
    Cool, thanks for the offer. All my LH drill bits are 6mm or more, this
    bugger is about 4 to 5 mm diameter.
    It should come out, I managed to get quite a bit of penetrating oil
    past it tonight (whilst the lug was hot), the fall back plan is to go
    back to the old leg as it's only the fork tube that needed changing
    really.
    Will see tomorrow whether it's faster to get the sheared bolt out than
    to faff around swapping all the bits over. ;)
    ... Again .. !
    P.
  8. Blimey.
    All I have to do is get a new rear tyre on the CB750.
    The Older Gentleman, Jul 9, 2005
  9. sweller
    Has been considered but It's a bit of a non runner.
    I want to get the front end up in the air without putting any weight or
    load on the forks or yokes.
    ....neither do I want to take the exhaust off. It's all a bit tricky but
    I've been too busy to do anything to it yet.
    sweller, Jul 9, 2005
  10. sweller
    Steph Guest
    <snip>
    I know it's not the best of bikes, but you can borrow the GSX for the
    Chimay trip if you want? I'll not be using it that weekend so it's
    available if you need it.
    Steph, Jul 10, 2005
  11. sweller
    Many thanks for the offer but I will triumph in the face of adversity.
    If not I may have the use of:
    (a) Snorky.
    (b) a Honda CX650 Eurosport.
    Talk about an incentive to get the fucker fixed....
    sweller, Jul 10, 2005
  12. sweller
    Salad Dodger Guest
    That's okay, so do we.
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..75939.../...19198.../..30340.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR Clues: 24 Pts: 400 Miles: 1589
    Salad Dodger, Jul 10, 2005
  13. sweller
    zymurgy Guest
    AAAAAAARGHHHHH. You *sodding* *fucking* *bastard*.
    Paul.
    zymurgy, Jul 10, 2005
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    Right, what address would you like it posting to? ;^)
    Wicked Uncle Nigel, Jul 10, 2005
  15. sweller
    zymurgy Guest
    No, no probs, it's had the kitchen sink thrown at it.
    Plus gas, heat, dremeled a slot in the stub, it's chewed up 3 bits and
    1 screwdriver. It's been drilled right through with a 2.5 mm bit but
    then it snapped off [1] the 3 mm on the way through. I was just
    drifting through the broken piece (the hole isn't completely blind)
    when the drift broke off too.
    Bollocks, i'll use the spare leg ;-)
    This really needs a drill press and some patience now, but it's in
    short supply ;-)
    Cheers,
    Paul.
    [1] The HSS drills I got recently [i've just found] are really brittle
    [2], not at all like the HSS steel drills I used to get in my youth.
    [3]
    [2] i.e a decent drill bit was cracking through the broken piece at a
    rate of knots, but then I got worried about this one breaking off too.
    [3] Back to the engineering supplier then, not Screwfix ..
