This afternoon's efforts:
Discussion in 'UK Motorcycles' started by sweller, May 30, 2005.
  1. sweller
    Why would a German machine have Cyrillic script on it?
  2. sweller
    Bear says...
    And me. Statto now has a bike that goes round corners better than it
    did, thanks to a new set of steering head bearings and new fork oil.
    I've just got back home after a nice tip to the local pub bike meet on
    the Gixer.
    Lozzo, May 30, 2005
  3. Reparations?
    The Older Gentleman, May 30, 2005
  4. sweller
    Ginge Guest
    Grrr. I wish it had rained.
    Ginge, May 30, 2005
  5. sweller
    raden Guest
    raden, May 31, 2005
  6. Does seem to have been a lots for such a nice day, I was out but
    playing on boats rather than bikes. Then up at 5.30 to wash the gear
    before going to work - deep joy.
    Boots Blakeley, May 31, 2005
  7. sweller
    They just wear out. They all do.
    There's several firms in the UK that re-furb car turbos, and they have
    been known to do turbos from bikes. The main problem is that they are
    so small, can can be difficult to obtain/make parts for. I recall
    that the IHI turbo used on the 750 was the smallest in the world at
    the time, with a max speed of 250,000 rpm.
    Champ, Jun 1, 2005
  8. sweller
    heh. Impressively broken.
    The vanes on the inlet impeller are pretty badly marked, imo. I'm
    sure they weren't that bad when I had it. If I didn't know better I'd
    say it'd been run extensively without an air filter, but I'm sure Will
    didn't do that. What does the impeller on the other (leaky) turbo
    unit look like?
    Champ, Jun 1, 2005
  9. sweller
    When I find it (it's in a 'safe' place) I'll let you know. I'm pretty
    sure they're ok.
    Is it easy to get them repaired? I may have to speak to Mr. Bonwick.
    sweller, Jun 1, 2005
  10. sweller
    zymurgy Guest
    zymurgy, Jun 1, 2005
  11. sweller
    sweller, Jun 2, 2005
  12. If you're keeping the turbo, you will probably want to keep the standard
    head.[1] I assume that was undamaged.
    The other thing I'd recommend is finding a tougher head gasket, which
    with the Wiseco bore might be tricky. Big-bore kit + turbo = farewell,
    gasket.
    Otherwise - it sounds like an absolute hoot :))
    [1] Straight Z650, IIRC. Champ will be along in a minute to confirm or
    correct.
    The Older Gentleman, Jun 2, 2005
  13. sweller
    Both heads are standard and, AFAICT, undamaged. The 'current' one has a
    known history and has all it's exhaust studs intact.
    It's a turbo specific conversion and according to the Wiseco website,
    which still lists the kit as available, a modified OEM gasket is used.
    Modified in what way, they don't say.
    ATM, I'm more concerned as to what caused the lubrication failure at
    number 2 big end bearing. I'm hoping all will be revealed when the cases
    are split.
  14. sweller
    Coo!
    How far in advance do I need to book?
    Champ, Jun 2, 2005
  15. sweller
    On Thu, 2 Jun 2005 07:49:34 +0100,
    <dons anorak>
    Basically, yes, but a couple of slight difference. The z650 and z750
    had the tacho driven off a worm gear from the exhaust cam, whereas the
    later GPz750 and the turbo variant had an electronic tacho driven from
    the ignition system. Also, the turbo has a cylinder head temperature
    sensor screwed into the back of it (between cylinders 1 and 2).
    Oh, and turbo heads were black (like the rest of the engine), while
    all the z650s were in plain alloy, iirc.
    So, a head *could* be used from any of them, but you might have to
    **** about with the tacho drive and the temp sensor.
    <removes anorak>
    Champ, Jun 2, 2005
  16. sweller
    It does? I can't remember disconnecting it.
  17. sweller
    Bugger.
    Champ, Jun 2, 2005
  18. sweller
    Yep. Just a single bullet connector. You prolly pulled it out when
    you removed the bank of injectors, without really considering it.
    Champ, Jun 2, 2005
  19. sweller
    Lady Nina Guest
    Is this before or after the rimming?
    Lady Nina, Jun 2, 2005
  20. sweller
    After is more traditional, isn't it?
    Champ, Jun 2, 2005
