Things you probably should know, but don't.
Discussion in 'UK Motorcycles' started by Krusty, Sep 2, 2010.
  1. Krusty
    "When seating the tappet shim, be sure to face figure printed surface
    to the tappet" is what it says in the manual. Which has made me realise
    that despite 37 years of spannering, I don't know what a tappet
    actually is, & have never needed to know - until know.
    My instinct says it's whatever the camshaft presses against, so in this
    case it's the buckets, & the numbers on the shims should therefore be
    facing upwards (it's shim-under-bucket).
    I gave up relying on the way things were installed previously as a
    guide years ago, & this is a good example of why - most were facing
    down & a couple up. Although I'm struggling to see why it would make a
    difference in this configuration.
    What say the FOAK?
    Krusty, Sep 2, 2010
  2. Krusty
    Simon Wilson Guest
    The only thing that occurs to me is that it's to prevent the numbering
    rubbing off, but then there's nothing really 'rubbing' against it I
    guess?. I suppose it /could/ be a difference in the surface treatment
    one side to t'other, but I doubt it.
    Simon Wilson, Sep 2, 2010
  3. Something that small will be through hardened (not surface treated).
    Jeremy Robinson, Sep 2, 2010
  4. Krusty
    That sort of matches what I thought. I thought that with a OHV setup
    the cam moves the pushrod which moves the rocker arm, which is
    connected to a tappet[1] which moves the valve.
    On a OHC, there's the cam lobe acting directly on the bucket as you say.
    According to Wiki(pedia!):
    "Properly speaking, a tappet is only that part of a rocker arm which
    makes contact with an intake or exhaust valve stem above the cylinder
    head of an internal combustion engine"
    [1] As in the things that "taps".
    CT, Sep 2, 2010
  5. CT escribió:
    http://tinyurl.com/68etaf
    Paul Carmichael, Sep 2, 2010
  6. Krusty
    Beav Guest
    It because the rocker arm (when they use them) taps the top of the poppet
    valve, so the arm is the "tappet" Or "tap-it". Probably, but no fucking
    guarantee that what I just typed makes any sense or is in any way true. I'm
    sticking with it though.
    Beav, Sep 2, 2010
  7. Krusty
    M.Badger Guest
    That was going to be my reply, including the "tap-it" bit as that's where it
    taps it, thus setting the "bit where it taps it" clearances. At least that
    is how it was explained to me all those years ago.
    I'll stick with it too.
    M.Badger, Sep 2, 2010
  8. Krusty
    I was sorta asking both really. Is does seem obvious that they go a
    specific way to protect the stamps, but not why that's necessary with
    shim-under-bucket where the shims are sandwiched between two lumps that
    only move up & down.
    The only reason I can think of is that the stamped face goes against
    whichever object it's most likely to stick to, so the other side gets
    the hammering when things are loose. All the shims were stuck to the
    buckets in this case, so when I eventually find a dealer who isn't a
    complete waste of fucking space[1] & get the shims I need, I'll stick
    'em in stamped side up.
    The only time I've thought of a tappet as an object is the hydraulic
    tappets in most car engines. Other than that, it's just a generic term
    for whatever you adjust or change to set the valve clearances in my
    mind.
    [1] Cagiva dealer has no shims. Other local dealer said they had on the
    phone, but when I went in they'd sorted me some big shims as used in
    Triumphs rather than the little ones I asked for. George Whites were as
    usual a complete waste of time.
    Krusty, Sep 2, 2010
  9. Krusty
    It does make sense, & is probably where the term originally came from,
    but it's obviously not true when talking about engines without rocker
    arms.
    Krusty, Sep 2, 2010
  10. Krusty
    <snip>
    Yeah, unfortunately they're all the makes covered by George Whites,
    which means a trip to the other side of town with no guarantee they'll
    have any.
    Krusty, Sep 2, 2010
  11. Krusty
    Yersh. I called them this morning & they spent five minutes checking
    the computer for the first size & said "we've got eight of those", then
    another five minutes on the second size resulted in "they're special
    order only". Trying to get them to just check what they've got in the
    workshop seemed to confuse them.
    Krusty, Sep 2, 2010
  12. Krusty
    One word - work.
    Krusty, Sep 2, 2010
  13. Krusty
    Only another 20 years to go before I can jack it in & concentrate on
    being poor for a few years before dying.
    Krusty, Sep 2, 2010
  14. Krusty
    Beav Guest
    Although the valves are still tapped. Adjustment is totally different, but
    the top of he valve still gets a tap every time i opens.
    Beav, Sep 2, 2010
  15. Krusty
    Beav Guest
    I can't think of any other explanation as the term describes the action
    perfectly.
    I should bloody well hope so.
    Beav, Sep 2, 2010
  16. Krusty
    davethedave Guest
    As is -Citizen- -Sm- Mr Auvache.
    davethedave, Sep 2, 2010
  17. Krusty
    Only when I'm having a shit week. Normally I'm a right little ray of
    sunshine.
    Krusty, Sep 2, 2010
  18. Krusty
    Thankfully work came to an end, so I took your advice & tracked some
    down. All back together now & running sweet as a nut. I'll double check
    the TPS & synch tomorrow, then it's dyno time. My guess is 112bhp.
    Krusty, Sep 2, 2010
  19. Krusty
    zymurgy Guest
    But they don't, the bucket rotates, otherwise you get the cams digging
    into one part of the bucket. Certainly on Alfas, that have a split
    cam, one lobe was fractionally higher than the other to make sure the
    bucket rotated. It didn't work though, and the boxer cam buckets wore
    like bastards. But they were pioneers in this respect. [1]
    AOL. Tappets comes from the OHV days, where the rocker arm was
    adjusted against the valve, The tapping was what you could hear when
    you rocked the rocker arm. Sadly, all that's long gone with OHC and
    hydraulic 'tappets'
    Paul.
    [1] Visionary design, or Alfa unreliability, take your pick ..
    zymurgy, Sep 2, 2010
  20. Krusty
    zymurgy Guest
    Your're right. I took the bike home today at lunchtime. Lovely it was,
    sun shining, bike running on song and tyres sticking on corners ....
    Then I went back to work :(
    Paul.
