Things Which I Have Come To Expect To Find
Discussion in 'Australian Motorcycles' started by sharkey, Jul 4, 2004.
  1. sharkey
    sharkey Guest
    There are things which I have come to expect to find in the
    sump of a motorcycle: mostly oil, but traces of water,
    traces of fuel, tiny shavings of metal are not entirely
    unheard of.
    Not whole ball bearings though.
    With the luxury of a workshop full of shiny things, I remove the
    clutch which defeated me in the sands of Wintersun.
    And find this:
    <http://zoic.org/sharkey/tmp/fubar.jpg>
    -----sharks
  2. sharkey
    ...and you made it home?!!?
    Knobdoodle, Jul 4, 2004
  3. sharkey
    Mike.S Guest
    i'm sorry, just what the hell part of the engine is that?
    *blink* it's well and truely knackered
    Mike.S
    Mike.S, Jul 4, 2004
  4. sharkey
    sharkey Guest
    Against incredible odds, it actually runs like that.
    The dry-sump engine kept the ball-bearings out of the works,
    and the cases didn't quite wear through.
    On the other hand, it went about 600km like that, and the
    oil pump ain't feeling too flash. I suspect it's fucked.
    ALL TOGETHER NOW:
    YOU'RE GOING TO HAVE TO SPLIT THE CASES!
    -----sharks (how much was the XJ again?)
  5. sharkey
    sharkey Guest
    Output shaft from the gearbox. This is a pic of the innards
    through the clutch cover, with the clutch removed.
    <http://zoic.org/sharkey/tmp/fubar2.jpg>
    In the middle is the gearbox input shaft (the thing running
    up the middle is the clutch push-rod), the gear on
    the right is on the crankshaft, the gear at the bottom drives
    the oil pump. The bearingless shaft is on the left.
    At the very top right you can see the coils of my BRAND NEW
    SHOCK ABSORBER! I'm NOT ANGRY, REALLY!
    -----sharks
  6. sharkey
    conehead Guest
    Looks ok to me. That'll be $200 please.
    conehead, Jul 4, 2004
  7. sharkey
    Biggus Guest
    your machine is broken dude.
    Biggus, Jul 4, 2004
  8. I'll trailer the z13 down weekend after next!
    Hammo
    Hamish Alker-Jones, Jul 4, 2004
  9. I still cant see the Leprechaun!
    Hammo
    PS Bugger! Was it BT?
  10. sharkey
    Goaty Guest
    Goaty, Jul 4, 2004
  11. sharkey
    Goaty Guest
    More than I did!
    Cheers
    Goaty
    Goaty, Jul 4, 2004
  12. sharkey
    Mike.S Guest
    cheers for the explenation there, i get how it goes together now.
    Did you remove the outer race? or did it just implode along with the race and the
    bearings?[1]
    [1] I noticed some *lovely* destruction of the inner bearing race there, all sortsa heat related
    surface fuxoring going on .
    Mike.S
    Mike.S, Jul 4, 2004
  13. sharkey
    Goaty Guest
    What is it about oil pumps this year?
    Cheers
    Goaty
    Goaty, Jul 4, 2004
  14. sharkey
    So what's the plan now - are you going to resuscitate your CX, or try
    to hunt down one of the 3 remaining XLV750 engines in Australia?
    (I still reckon you could fit a Transalp motor in there!)
    BT Humble, Jul 5, 2004
  15. sharkey
    sharkey Guest
    Its a tricky one, I'm not sure yet. I stuck a postie in the
    boot of the car this morning though, just to see if it'd
    fit ...
    Maybe I'll buy a fucking BMW.
    -----sharks
    sharkey, Jul 5, 2004
  16. sharkey
    sharkey Guest
    (top left, BTW. The red bits)
    Nope, didn't remove anything yet. The outer race is the steel
    collar you can see in the black aluminium casing. The round,
    brown, torn up thing is a big flat washer. The inner race does
    not look good at all! The bearing was quite a chunky little
    bugger, only 7 balls. I wonder what happened to it?
    Sadly, the cases really do need to come apart to get to that
    bearing and to remove all the aluminium that that torn washer
    machined off the inside of the case ...
    -----sharks
  17. sharkey
    X-No-archive: yes
    Just the Postie or his bike too?
    Clem
    (I reckon I could fit three Postman-Pats in my boot!)
    Knobdoodle, Jul 5, 2004
  18. sharkey
    sharkey Guest
    Little red bike, big yellow pants, the whole lot.
    I already had a couple in there to stop the cargo
    sliding about. And if you break down in the middle of
    the night, you can use their legs as reflective
    warning devices.
    -----shrarks without a bicycle
  19. Your feet stink.
    Postman Pat
    Pat Heslewood, Jul 10, 2004
