Thermostats 'n cooling stuff...
Discussion in 'Australian Motorcycles' started by Doug Cox, Feb 19, 2004.
  1. Doug Cox
    Doug Cox Guest
    Been trying to diagnose a cooling problem with the Pig. Had a new thermostat
    fitted and now it overheats within 10-20kms.
    After a week of battling with bleeding the cooling system, I've pulled out
    the new thermostat and dropped it in a saucepan of boiling water. Nothing
    happened. It also seems that it's not sealing where it's meant to.
    Seems to me that there's constant but restricted flow.
    About how much movement should I expect in the thermostat and about what
    temperature should it start opening?...
    Doug Cox.
    Work to ride, Ride to work...
  2. Doug Cox
    Doug Cox Guest
    Scratch all that last message. Thermostat's working...
  3. Doug Cox
    Centurion Guest
    If thermostat is working (yeh, saw your other post) then maybe it's the head
    gasket? My dad once had a car that had a blown head gasket and was pumping
    nice hot gas into the cooling water. Result was it over-heated within 20km
    of the point of origin. The fact it happened in the middle of summer on
    one of our Gold Coast expeditions[1] made it extra fun :p
    James
    ZZR250==>ZX9R
    [1] Most people go on 'holidays' - but my parents tried to make them
    'educational' and an 'experience to cherrish and remember' hence we never
    actually had "holidays" as kids....it was usually school in a different
    location. Except our week with the grandparents - my grandfather "taught"
    me how to drink scotch straight-up when I was 11!
    Centurion, Feb 23, 2004
  4. Doug Cox
    Doug Cox Guest
    Gawd, if I had two bob for every time someone suggested that...No bubbles in
    the coolant, runs sweetly, no white exhaust smoke. Ran fine before valve job
    from previously trusted mech.
    I don't work on it often because I've got the shits with it and the garage
    is too hot during the day, and infested with mozzies during the night. Add
    to that the time it takes to cool down after a run and the fact that I
    prefer to aneasthetise myself with my drug of choice before operating and
    progress is steady if a little slow...
    As it turns out, I've since found two probs. The thermostat, although
    working, wasn't fitted correctly. Hence the constant but restricted flow.
    The heat gun the mech used to open the thermostat while filling the system
    with coolant, melted and warped the plastic filler neck just enough to break
    the seal with the radiator cap.
    Dunno if it's fixed yet though. Just got off work and the mozzies are moving
    in...
    Doug Cox.
    Doug Cox, Feb 24, 2004
