Thermostat removal
Discussion in 'Motorbike Technical Discussion' started by britbike900, Oct 16, 2007.
  1. britbike900
    britbike900 Guest
    I have a Triumph T-Bird that runs hotter than I would like it to. I
    was considering removing the thermostat to see if I can get increased
    cooling system flow to help alleviate the issue. I have done this with
    cars and compressors and have never had an issue, in fact, it has
    worked well, but I have never done it on a motorcycle. I have read
    about some KTM's (recent EXC's?) that can benefit from this procedure.
    Has anybody ever done this on their bike? If so, what were the
    results?
    Thanks!
  2. How hot, and what temperature would you like it to run at?
    I'd recommend you leave it alone.
    The Older Gentleman, Oct 16, 2007
  3. I had an '01 Thunderbird and the temperature warning light would often come
    on if stopped in traffic on a hot day. About the same time the fan would
    come on, cool things down, and then the light would go out. I did some
    research and found that this was normal behavior for this bike. The warning
    light and fan, while triggered by separate sensors, were both designed to
    come on at the same temperature. If this is what you're experiencing, I
    wouldn't worry about it.
    Martin
    Martin Walker, Oct 16, 2007
  4. britbike900
    britbike900 Guest
    Yes, I have read about that issue on Triumphrat.net and I cured the
    annoying warning light by removing said offending bulb. :)
    There is surely a lot of good information in these responses. I was
    just curious to see if anybody here had done this (T-stat removal) on
    a bike and what the results were. I have often thought about doing it
    to my DRZ-S, but that bike makes a lot of short trips, so I figured
    that I'd leave it in.
    The cooling system on the T-Bird seems to work just fiine, it just
    seems a bit marginal in size.
    Anyway, I bought some water wetter type stuff to try. I'm sure that
    there are lots of opinions on this stuff....
    Thanks for all of the responses!
    britbike900, Oct 17, 2007
  5. Rads and suchlike are more efficient now, as are engine designs.
    Of course the rads and paraphernalia are smaller - that's the way it
    goes. Engines are smaller. Bikes are smaller.
    <Thinks>
    Brakes are bigger :)
    As the OP says, it works fine. So don't **** with it.
    The Older Gentleman, Oct 17, 2007
