There's always one. Wireless network fun anybody?
Discussion in 'UK Motorcycles' started by Mungo \Two Sheds\ Toadfoot, Apr 18, 2008.
  1. As of today Sky are taking my money instead of Pipex. This afternoon I
    noticed a lack of broadband and went to replace the old router with the
    shiny new one.
    The main PC is wired into the router so it worked immediately, the laptop
    had a wireless look around, found the new connection, asked for the WAP-SPK
    key, got it, and is happy.
    Daughter's PC though... I put a new wireless PCI card in it and it seems
    happy but the wireless network connection icon has a red cross through it
    and doesn't even look for a network. Right-clicking it brings up "View
    available connections" but there aren't any and the box is greyed out. Using
    the Network Setup Wizard brings up a box which says "Connections listed
    below are disconnected, plug the cunts in" or something similar. One of the
    connections is, of course, the wireless card.
    The PCI card came with a bit of software that supposedly searches for
    networks and indeed it does - I've given it the SSID and network key, it
    finds and names the router, says things to it, then ignores it and goes off
    to search for others. Endlessly. It says the signal's poor even though the
    router is but 15' away.
    Hair = pulled out.
    Help.
  2. And... all running XP Home or Pro.
    And II... when I ran the wireless wizard it asked for a WEP key but I
    couldn't see any way of telling it that it's a WAP key so it kept rejecting
    it. Can't remember what I did after that coz it started to drive me insane.
  3. Yes. The laptop accepted it immediately but daughter's PC kept arguing that
    it was the wrong number of characters - it was expecting a WEP key for some
    reason. I think that was when I ran the wireless card's software, where
    there was a box for the WAP key Sky gave me.
  4. Mungo \Two Sheds\ Toadfoot
    Chris Dugan Guest
    that
    Sounds a lot like the wireless drivers/card don't support anything but WEP,
    what card & software is it running?
    Can you manually enter the connection settings rather than running through
    the setup wizard?
    Chris Dugan, Apr 18, 2008
  5. It supports WPA/WPA2, IEEE802.1X, TKIP, AES (not WAP, like what I keep
    bloody typing!)
    I've been going round in circles for so long now I'm not entirely sure what
    I've tried. I'll have another play later. Or tomorrow perhaps.
  6. Oh FFS.
    <Mumbled> Bought PC, PC was restored to original, SP1... *ESS PEE ONE??*
    Got SP2 on it now. Still keeps losing the network and won't connect to it
    but I feel we made progress.
    Cunting computers. Now I don't know if the wireless card is just shite or
    there's something ELSE I haven't noticed.
  7. It finds the network... sometimes. When it does It asks for the key and
    tries to connect but says it's waiting for the network and never actually
    connects. It is mostly pissing me off.
  8. Mungo \Two Sheds\ Toadfoot
    muddy cat Guest
    Access list?
    muddy cat, Apr 18, 2008
  9. Mungo \Two Sheds\ Toadfoot
    Any special characters in the WAP key that may be in a different
    location on a US keyboard? Not that something like that would've ever
    happened to me, oh no...
    Timo Geusch, Apr 18, 2008
  10. Heh! No, just capitals and it can be unmasked anyway.
  11. Will be checked, ta.
  12. Mungo \Two Sheds\ Toadfoot
    Pete Fisher Guest
    In communiqué <fuanp5$93q$>, "Mungo \"Two
    I can only guess it might be a clash between wireless zero configuration
    and the card's own utility.
    Now it is on SP2 have a look at this:
    http://support.microsoft.com/kb/870702
    | Pete Fisher at Home: |
    Pete Fisher, Apr 18, 2008
  13. I think I've discovered the problem - a shite wireless card. I used the
    restore CD to get it back to pre-wireless network wizard state, added SP2
    straight away and everything was a lot easier. Problem is, I have to show
    the wireless card's aerial to the router before it will connect, i.e. point
    it at it - "There it is, you ****! Over there!!". If I shut the door it says
    "'Ere, it's all gone dark! Where did the router go??". It's bollocks. It
    will be replaced. What's the opinion of USB wireless jobbies?
    Mungo \Two Sheds\ Toadfoot, Apr 19, 2008
  14. Dunno. SP2 helped a great deal though!
  15. Thanks, Nige.
  16. <Light dawns> Of course! Doesn't have to actually be plugged into the pc,
    does it? Much better idea. I just assumed (yes, I know) that a wireless card
    was a wireless card. Cheers, Rob.
  17. Mungo \Two Sheds\ Toadfoot
    Ben Guest
    If you're going to run a wire from the PC, you could just continue it
    all the way to the router :)
    On a more serious note, check the wireless card is broadcasting at
    full strength. It'll be in the hardware properties somewhere.
    My wife's Dell laptop always thinks it's being helpful in dropping to
    broadcast strength in order to save power. In reality it just means
    it drops the connection all the time.
    And don't forget there could be a lot of metal in the wall/door
    between the laptop and the router. It may not be the fault of the
    hardware, but the building.
    Ben, Apr 19, 2008
  18. Heh! Could do but I didn't intend to run it that far and even if it needed
    to be closer it would be very easy to run a USB extension up into the loft,
    over a bit, and leave the adapter sitting in the loft right above the
    router.
    I'll certainly have a look but it was fluctuating between 2 and 56Mbps and
    dropped off completely if my daughter just stood directly between it and the
    router!
    I'm sure it should be able to manage one standard door in 15 feet of open
    space, but point taken.
  19. Indeed. I only got as 'advanced' as CB twiggery though, and that was just
    silly. It's ok for Merkins to say ten-four good buddy but in Fannit it
    sounded wierd. I used to ask people what it meant and they'd say "...yes",
    to which I'd reply "Well just fuckin' say yes then!".
    Anyway, even the little tiny hairyhole on this wireless card shouldn't find
    a few yards of open space too much of a challenge.
    I've come to accept that very few things work first time for me so
    consequently I nearly died of excitement this morning when I got a REFUND
    cheque from BT because I've finished with their services and had paid too
    much. Didn't even know I was due one and it turned up! That does *not*
    happen.
    On the downside I also got a script rejection letter from (another) tv
    company. What do they know?
