There's a lot I don't know about GPS
Discussion in 'Australian Motorcycles' started by Minx, May 21, 2009.
  1. In aus.motorcycles on Mon, 25 May 2009 07:34:39 +1000
    Done. I've been wondering what to do with mine, but you had best
    decide if it's suitable for the porpoise first.
    Whatcha up to this evening?
    Zebee
    Zebee Johnstone, May 24, 2009
    #41
  2. In aus.motorcycles on Sun, 24 May 2009 22:17:28 +0000 (UTC)
    Oh, it's a 4150. Ain't young...
    Zebee
    #42
  3. Minx
    CrazyCam Guest
    Dunno.... I have no idea of what an iPaq looks like.
    My interest was that Jim Kelly talked of one with the iGo software.
    For reasons best know to the gods, iGo is reputed to have the best
    available mapping/routing for Greece, so I thought, if it came with the
    software and licence or whatever for the software, it might be worth the
    fiddling about.
    regards,
    CrazyCam
    CrazyCam, May 24, 2009
    #43
  4. Minx
    Jim Kelly Guest
    Had a closer look and it seems to be an old version of Nav-nGo. A
    browse on the web makes it sound like the 'advanced' mode has
    been knobbled by hp (so that their support people didn't have to
    answer any hard questions I suppose) and that's why it is so
    frustrating to use (plus not having a manual).
    I saw a tip that iGO v8 is considered good in Europe too. Most
    gadgets seem to be region specific though and if alternate
    software is available - it is expensive and out-of-date
    (because Aus models are already so before we get them!
    No sign of the Zumo 660 at www.garmin.com.au but it is discussed
    in UK and USA).
    The iPaq 312 has been a shit of a thing to get charged up but I
    eventually (by a process of elimination) worked out which USB
    cable had come with it. Use that one and it charges in no time.
    Same with the AC and 12v adapters.
    5v is not 5v.
    Enough to make me start labeling all my chargers and cables!!
    Some tiny difference sends a signal to the charger that it is ok
    to work fast. Trouble is when that signal is not present, the
    trickle charge modes supply less than the iPaq 312 needs to
    receive the charge!!!
    Luckily I had had an ASUS phone that had the same problems . . .
    so knew what to look for before I threw it at a wall!
    Also, the resolution is 800x480 pixels - even better than I had
    thought . . .
    Cheers,
    Jim Kelly
    software.
    best
    with the
    worth the
    fiddling about.
    regards,
    CrazyCam
    Jim Kelly, May 25, 2009
    #44
  5. There's more upmarket ways of doing this, but I did mine on the cheap.
    Bought a $190 Mio C220. I store it in the window of the tankbag, so I
    can see it. The Mio has a 3.5 mm audio socket. I plug my earmold ear
    pieces into that, and have audio pumped straight into the ears. Most of
    the time, I run off audio mode. Occasionally, I find that looking at the
    screen helps a bit.
    One day I'll get around to mounting the stuff on the bars so I can get
    visuals without having to crane the neck down to see the map window on
    the tankbag. RamMount make some good fittings to attach a variety of
    devices to the bars/headstem.
    I don't pay a subscription. You CAN buy map updates for them, but I
    haven't bothered yet.
    Will probably replace the unit in a couple of years.
    The upmarket way is to get a unit that is hardwired into the bike (does
    power and pumps sound through a Autocomm type sound sytem). These units
    are typically waterproof, and designed to be operated with gloved hands.
    Peter Cremasco, May 27, 2009
    #45
  6. Probably a great idea, aren't the update maps almost as costly as buying a
    new unit every few years?
    George W Frost, May 27, 2009
    #46
