The truck is dead, long live the truck
Discussion in 'Australian Motorcycles' started by BT Humble, Apr 16, 2006.
  1. BT Humble
    OK, I finished loading the truck in Canberra this morning, then when I
    went to start it to head back to Melbourne...no go.
    Pulled out the plugs, noted the substantial oiliness on #3 and #4.
    Hmm.
    All of the joins in the cooling system were leaking coolant, just from
    cranking it over on the starter - didn't think that the water pump had
    *that* much pressure...
    The haemorrhage from the sump had also increased enough to drop the oil
    level from the lower mark on the dipstick to "no reading" in under
    150km. Bummer.
    The air bubbles coming from the radiator were the final proof of an
    ex-head-gasket.
    However since the motor was worn-out when I bought it, and I've done
    90,000km in it since, I can't complain *too* hard. I unpacked the
    truck, pushed it into the backyard, and booked a cheap flight home.
    Can anyone recommend a suitable garage in Canberra who can source and
    install a reconditioned 2-litre petrol motor in an Econovan within the
    next 3 weeks? I'm valuing reliable, speedy service more highly than
    price.
  2. BT Humble
    DG Guest
    I've had joy with Braddon Mechanical Repairs on Lonsdale street. It's a
    little hole in the wall between a phone shop and the Discount Tyre Service
    shop. Just up a bit from TJ's Tyres.
    Anyway, I've not had any major work done there but what I have had done was
    timely and satisfactory. It's run by an older bloke and he has 1 or 2 other
    workers there. He must do OK as the garage is never empty.
    25 Lonsdale St Braddon ACT 2612
    ph: (02) 6248 8060 Engine Reconditioning
    DG, Apr 16, 2006
  3. BT Humble
    gingle Guest
    Bloody hell, It must be catching :(
    Last week I had to put a reco in my Econovan. Had done 270thou when it
    finally let go.
    As an idea of price it was $3600 for the motor (Melb) & it was all done
    including new clutch + bits in a week.
    Greg
    gingle, Apr 16, 2006
  4. BT Humble
    HandleBarz Guest
    You should have imported a good used engine from a wrecker in NZ.
    It would have cost you NZ$600 to 800 plus about $250 freight.
    HandleBarz, Apr 16, 2006
  5. Then what happens if its fucked and you want warranty?
    Biggus La Great., Apr 17, 2006
  6. BT Humble
    HandleBarz Guest
    They do give a 30 day warranty. You need to get a friend in New Zealand
    to look at it first and hear it run before buying it. There might be
    fishooks
    if it wasn't as good as it seemed, but you'd need to take that into
    consideration.
    The prices are good compared with a recon in ozz. Probably better to buy
    from the larger well known wreckers here. By the way I'm not in that
    business
    and don't give a stuff whether or not you buy an engine, it just seemed
    obvious
    to me that you guys could save money on a used engine. Don't they have
    wreckers
    or used engine importers in Ozz?
    HandleBarz, Apr 17, 2006
  7. BT Humble
    gingle Guest
    You can get used engines no prob, but you have no idea of it's history.
    Reco gives you 6mths or 25k warrenty & you know what your getting.
    As BT said; reliable speedy service is whats needed!
    For piece of mind the reco was the better option.
    Any local ford dealer should be able to point you in the right
    direction.
    Greg
    gingle, Apr 17, 2006
  8. BT Humble
    I'd prefer to recondition my own engine, but unfortunately time and
    relative location of me/it won't allow that.
    I have a cousin in Canberra who works for a dealer (as a mechanic)
    during the week and a wrecker on weekends, so I'll be asking his advice
    too.
    By the way, $3600 seems a little steep - is yours a newish model or a
    diesel or something?
    BT Humble, Apr 17, 2006
  9. BT Humble
    J5 Guest
    yep true , but then again an import for $600-$800 from a reputable
    importer could be a far better option cost wise
    I wouldnt talk to any ford dealer , dumb fuckers are worse than talking
    to a brick wall
    yep he will prob have the best idea
    reco motors dont come cheap, round a couple of grand
    then labour to R+R , new clutch , oils, plugs,hoses etc and easy comes up
    to $3600
    J5, Apr 17, 2006
  10. When we had our old Subaru fitted (1.8OHC L series) with a recon engine and
    new clutch a few years ago it was $3500
    Al
    Alan Pennykid, Apr 17, 2006
  11. Shoehorn a 454 into it mate!
    Pisshead Pete, Apr 17, 2006
  12. BT Humble
    That'd be good in the winter!
    Sadly true - 6.5km/l is the best I've ever gotten out of it.
  13. BT Humble
    gingle Guest
    Thats not good! The worst i've ever had is 7.6km/l & an av of 8. Seen 9
    on the odd ocassion but only after tappets have been done.
    I stopped running it on gas years ago, motor couldn't take it.
  14. BT Humble
    I've got the LWB truck, not the van. It weighs ~1800kg when it's
    empty.
    And if I HADN'T been running it on LPG, the motor would have reached
    this state long ago. ;-)
  15. BT Humble
    $3080, and they'll arrange the tow from Gordon (~30km) for an extra
    $60.
    He seemed pleased that he'd been recommended by someone, although he
    didn't know who "DG" was. ;-)
    BT Humble, Apr 18, 2006
  16. BT Humble
    Gary Woodman Guest
    Promotive, Park St Belconnen, great bunch.
    Gary
    Gary Woodman, Apr 18, 2006
  17. Eight GPX motors? (With open pipes of course)
    Postman Pat
    Pat Heslewood, Apr 20, 2006
  18. BT Humble
    Hmm, a 16 cylinder 2-litre motor. don't they use them in some kind of
    racing car? ;-)
    BT Humble, Apr 20, 2006
  19. Is a 1.5 litre V-16 near enough?
    http://www.billzilla.org/BRM-loudpass.mp3
    Al
    Alan Pennykid, Apr 21, 2006
  20. BT Humble
    BT Humble, Apr 21, 2006
