The road toll is our fault
Discussion in 'Australian Motorcycles' started by Uncle Bully, Jan 26, 2006.
  1. In G-S's defence, in my previous car (mazda 626), I would be quite
    fatigued after only an hour behind the wheel at 100. At 110 (eg Newell
    Hwy), I would last a couple of hours. I find in my commodore I don't
    get nearly as fatigued as I used to in the Mazda, but I still find that
    about 2 hours at 100 is getting toward my limit. At 110, I can
    comfortably go 4 hours and be less fatigued than I would have been from
    2 hours at 100. It's just something about driving at 100 - whether it is
    the frequency of road noise, the speed the scenery goes by at, or if it
    is just that it takes more effort to maintain the car at a near constant
    100 than 110, I'm not sure. I also find that at 110, my foot is in a
    more comfortable position, even if it is ever so slightly different to 100.
    Graham Fountain, Jan 28, 2006
    #61
  2. Sounds like candidates for falling asleep to me.
    Rainbow Warrior, Jan 28, 2006
    #62
  3. But then I also suspect sedans cause a lot more road damage too, there's 20
    of them for every 4x4.
    #63
  4. It's a bloody good arguement for legalising 44" balloon like mud tyres on
    4x4's
    #64
  5. Does tyre pressure affect the pressure exerted on the road somehow, 2 tonne
    is 2 tonne, whether it's sitting on 4 tyres at 15psi or 55psi. Contact patch
    size changes but does that really matter when you compare frictional wear to
    point contact wear?
    I run 55psi on my 255/85's but mates run 30psi in thei 285/65's
    Our Triton work ute, 185/75's must destroy the road by being at 40psi?
    #65
  6. Or course a 2 tonne vehicle will always exert 2 tonne on the road,
    irrespective of tyre pressure. However tyre pressure alters the area in
    contact with the ground. 2000lb car with 20psi tyres has 100sq-in of
    tyre area on the ground. Inflate the tyres to 40psi and it drops to
    50sq-in that is in contact with the ground. Close enough anyway. Other
    factors such as sidewall strength and tread pattern will alter this
    slightly. If you don't believe me, watch what happens when you inflate
    or deflate your tyres - at high pressure, they lift and less touches the
    road, at low pressure they are all squishy and more is touching the road.
    Someone posted that 4WD's do more road damage, and someone else said
    they couldn't because of their greater surface area on the road. Yes
    they have a greater surface area, but that surface area is exerting
    greater pressure. Clearly however there is more to the equation than
    just the pressure exerted on the road. If that was all there is to it,
    then my pushbike with it's 90psi tyres would be leaving chewed up
    bitumen everywhere I go. Road damage is really a function of total
    weight, speed, and shearing forces (acceleration, braking, cornering,
    friction caused by the not-perfect rolling action of tyres etc), not
    just PSI.
    If you still don't believe me that pressure on the road matches tyre
    pressure, try this simple test. Put your finger on the road, and have
    someone run over it in a falcadore with low tyres. Then have someone run
    over it on a pushbike. The pushbike will hurt a hell of a lot more. If
    you don't want to go to those extremes, experiment with a garden hose on
    concrete. You'll find that the water flow drops much more with your
    pushbike than with one tyre of a car on it. You could even try inflating
    a tyre while it is parked on the hose and watch what happens to the
    water flow.
    They exert more pressure per square inch, but that alone is not likely
    to cause road damage.
    #66
  7. "I live in Cairns, and the roads here are certainly not good, get out of the
    city and you will find corrugations in the bitumen, pot holes and generally
    narrow bad roads, out west it is worse. Many of the roads out there have
    only single car bitumen, and when there is a car coming the other way or you
    want to pass, it is onto the dirt on the side of the road.
    Riding a motorcycle you get jarred from the bad roads all the time.
    In parts where there should be no problems, and the limit is 100 Kmh there
    is no way you can do that sort of speed because of the conditions of the
    road.
    A few months ago I went up onto Cape York (The Tip) in a 4 wheel drive. The
    trip had 800 Km of dirt road to get up there from Cairns.
    Of that there was 160 Km of horror stretch, where you were reduced to first
    and second gear driving for long periods. There were washaways both across
    the road and running down the road, some of these were sharp trenches 300 mm
    deep, hit one that run across the road at any sort of speed and you could
    rip out your suspension. It took over 4 hours to negotiate that 160 Km of
    road, did I mention that in some parts there were trees down blocking 3/4 of
    the road?
    The locals tell us that the grader has not been up there for 2 years !!!
    Where does all our fuel tax go Mr Howard?
    Every time I hear about the road toll, it is always drivers (and riders) at
    fault, never our lousy road system.
    How many Governments have promised to "Fix" the Hume Hwy, and the Pacific
    Hwy, and yet we still have death stretches on them.
    Anyone noticed what a fine smooth road there is running between Canberra and
    Sydney?
    RamRodOz Sword of Baal, Jan 28, 2006
    #67
  8. So now I'm really confused does my 2 tonne 4x4 do more road adamage at 20
    psi or 50psi?
    Personally I don't think it matters SFA and I don't think a 2 tonne 4x4
    causes more damage than a 2 tonne Falcodore or 4x 500kg Festiva's.
    These are roads designed to handle 30-60? tonne Semi trailers.
    #68
  9. Actually, I'd be inclined to think it'd do more damage at 20psi - only
    because at such a low pressure the tyre would have more rolling friction
    and would be producing greater shear forces on the road. Realistically
    though, it's gonna be bugger all. In a light vehicle, unless you do
    stupid things like burnouts, you are unlikely to do significant damage
    to the road surface.
    Personally, I think you are right. The weight difference between
    Festivas, Falcadores & 4x4's is still pretty minimal compared to Semi
    Trailers. The much higher weight of a loaded truck (even if the PSI
    exerted is less than a pushbike) causes far greater damage.
    Additionally, the use of dual and triple axle designs causes
    considerable stresses on the road surface when these vehicles are
    turning. I've actually seen bitumen being torn up beneath the wheels of
    a truck doing a tight turn. Obviously the bitumen must have been in poor
    condition to begin with, but in a tight turn the wheels are being pushed
    sideways across the bitumen, instead of rolling.
    #69
  10. And yet we have those here claiming domestic 4WD's are destorying all the
    roads , LOL.
    #70
  11. Uncle Bully
    Kev Guest
    Nooo
    never
    12- 14 hours a day isn't long is it?
    spent 4 years doing loads that take at least 7 hours and up to 14
    hours:-Brisbane-Wandoan-Brisbane, 12 hours:-Brisbane-Miles-Brisbane,
    Brisbane-Jandowie-Brisbane, 7 hours:- Brisbane-Dalby_Brisbane,
    Brisbane-Maryborough-Brisbane, Brisbane-Brookstead-Brisbane,
    Brisbane-Millmerrin-Brisbane
    DOH
    Kev
    Kev, Jan 28, 2006
    #71
  12. but again if you have trouble driving at 100 without falling asleep then
    That was kinda my point :)
    The Red Krawler, Jan 28, 2006
    #72
  13. How many accidents are caused by people falling asleep at the wheel?
    If you're driving a truck, weighing in at a dickbag of tonnes, then you dont
    have much choice BUT stick to 100kph, do you. Damn limiters. Unless of
    course you were bypassing yours, which is illegal and naughty ;) Feeling
    bitter at all the cars that over took you and got the trip done half an hour
    faster? :p
    #73
  14. Uncle Bully
    Kev Guest
    I get paid by the hour
    not in my best interest to bypass the limiter
    Like I said
    I can drive all day long at 100 and not get tired or drowsy
    (unless I haven't had anough sleep before I start work)
    And not just in the truck either
    I've done plenty of long distance drives in my cars and still manage to
    stay alert at 100kph
    Kev
    Kev, Jan 28, 2006
    #74
  15. Uncle Bully
    G-S Guest
    I can't take both hands off the wheel... and even if I did I might not
    see that emu when I was so distracted :)
    G-S
    G-S, Jan 28, 2006
    #75
  16. Uncle Bully
    G-S Guest
    At some speed point that happens... but it isn't 120 to 130... it would
    be somewhere around 140 to 150.
    I have a 15 minute work commute :)
    G-S
    G-S, Jan 28, 2006
    #76
  17. Uncle Bully
    G-S Guest
    There is a difference between people 'claiming' it and people for whom it is
    actually true, and I haven't seen anyone here claiming they were safer
    at 250!
    Now I know you don't know me from a bar of soap, but I would never claim
    250 (or even 150) was safer on our roads than 100... and I haven't made
    such an unreasonable claim.
    I was speaking only about my experiences, and I have never tried to
    claim that other people won't experience different physiological
    responses, in fact I went out of my way to mention that fact.
    G-S
    G-S, Jan 28, 2006
    #77
  18. Uncle Bully
    G-S Guest
    Stopping distance isn't what we were discussing though.
    I freely admit stopping distances at higher speeds are longer.
    The question is does the increasing risk of falling asleep at 100
    outweight the other risks or not... and honestly I don't know the answer
    to that.
    As is obvious by this thread _not_ everyone can do it. You shouldn't
    assume that because you can do something that everyone can... that is a
    simple mistake many often make.
    People are differnt and they have different skills, skill levels and
    responses to stimuli which leads logically to a differing safe speed for
    each person.
    The problem with the blanket speed limit is that it assumes that people
    are not different when in fact they are.
    G-S
    G-S, Jan 28, 2006
    #78
  19. That may be your's, but what you have to realise is for the average driver
    (soccer mum, city driver, 45yo) it may be a lot less.
    For me 110 is fine, 130 may seem fine for the first hours, with some fast
    music going, but then I have to have a break.
    Well an extra 20kph isn't going to make much difference to you, much as the
    50kph zones in stead have 60 have made bugger all difference to my 5 minute
    commute.
    #79
  20. No, but there are people who because their car can do so, use it as an
    excuse to do so, imagine what speeds the average 19yo male would be driving
    at in their performance cars, given Toby's stupid arbitrary blanket
    derestricted limits.
    Sorta like some idiot bikes in traffic using the "if I move fast enough,
    they won't hit me" theory.
    #80
