The plot thickens.....
Discussion in 'Australian Motorcycles' started by moike, Oct 21, 2005.
  1. moike
    moike Guest
    For those who came in late, my bike overheated at the GP on subday, and
    suddenly started maling loud rattling and chuffing noises.
    RACV recovered it to BM Ringwood.
    Had a call this evening from Chris at Ringwood BM.
    They tried turning the motor over by hand, and it went smoothly,
    He queried how long I had ben having problems and who had set the
    valves, since both valves on the right cylinder appear to have about 2.5
    mm clearance, while the left are OK, if just a tad tight. Apart from
    the right hand throttle cables being a bit loose, there doesn't appear
    to be anything wrong with the bike. (They haven't lifted the heads off
    yet, just made an initial investigation.)
    The thing is, this problem came on very suddenly - within a single
    revolution of the motor.
    So what is it that can go suddenly wrong that will give a loud rattling
    noise (and a chuff chuff) and make *both* exhaust the and inlet valves
    open up by so much on one side only.
    I can't imagine both cam followers collapsing together, or two out of
    the four cam lobes. Pushrods move nicely. and the rocker gear seems to
    be fine - just out of whack.
    The bike was idling nicely right up until it made it's sudden change.
    The day before it had been pulling strongly and smoothly as I negotiated
    some of the more interesting hills of south Gippsland two up at a
    <cough> brisk pace. I know it was running smoothly.
    Ideas?
    Moike
    moike, Oct 21, 2005
  2. moike
    Boxer Guest
    Both push rods collapse?
    Boxer
    Boxer, Oct 21, 2005
  3. In aus.motorcycles on Sat, 22 Oct 2005 00:37:09 +1000
    When it happened to me, it was one valve only, and it was a pushrod
    collapsing at the cam end.
    Seems unlikely that both would go at the same time, but it's not
    impossible.
    Zebee
    Zebee Johnstone, Oct 21, 2005
  4. moike
    sharkey Guest
    One stud pulling could increase the load on the one next to it, and
    that could pull too?
    Can't think of anything else they share, except the camshaft!
    Ask on the Airheads list ...
    -----sharks
    sharkey, Oct 22, 2005
  5. moike
    Birdman Guest
    Its called Character....
    Birdman, Oct 22, 2005
  6. moike
    Nev.. Guest
    It's a super-bike and as such has super-powers.
    Nev..
    '03 ZX12R
    Nev.., Oct 22, 2005
  7. moike
    Rod Guest
    If it's doing it on both cylinders and started at the same time then it has
    to be one thing that drives/affects the two cylinders. Maybe the cham
    chain(s) have jumped one tooth? I'm not too familiar with the valve
    actuation on those bikes. They have a small chain off the crank to camshaft
    and then pushrods up into the head?
    Rod, Oct 22, 2005
  8. moike
    I think it's actually called "longevity".
    Hondas are getting it now too; I hear some VFRs are actually doing
    30-40,000 before breaking down....
    Knobdoodle, Oct 22, 2005
  9. moike
    John Guest
    Why don't you go and getfugged! (tm)
    mine got 29k out of the regulator before i replaced it.
    Johno
    Beer? bandage?
    John, Oct 22, 2005
  10. John said....
    Oi. I got 230 km out of mine before I had to replace the petrol in the
    tank.
    Martin Taylor, Oct 22, 2005
  11. moike
    Smee R1100s Guest
    Buy johno only rides to his letterbox and back.
    Smee R1100s, Oct 23, 2005
  12. moike
    Have the barrel/head retaining studs pulled out of the block? That
    happened to me with a VW beetle motor a few years ago, but it also
    caused a massive oil leak (which you haven't mentioned, so I assume
    wasn't happening?)
    BT Humble, Oct 23, 2005
  13. Good thought that is BT cause it does happen to airhead boxers, usually only
    one stud is prone to it though, not all four.
    Al
    Alan Pennykid, Oct 23, 2005
  14. moike
    Moike Guest
    Yeah. Thought about that, and eliminated it for the same reason. The
    bike is apparently running, but seems "really out of tune" according to
    the normally knowledgable mechanic (a specialist in old boxers).
    It was running *really* well the day before on a 'spirited' two-up run
    through the hills, and was still running quite nicely right up until it
    suddenly started sounding ill. ("Suddenly" - as in within a revolution.)
    My best guess at the moment is that a cam follower has let go, and
    somehow caused another to give up in sympathy - pergaps due to a
    bouncing fragment - but I don't know enough about the precise
    arrangement of that part of the bike to know whether that's possible.
    Oh well, I'll just have to wait and see what monday brings....
    Moike
    Moike, Oct 23, 2005
  15. moike
    sharkey Guest
    Thought about that, and looked in the Book of Lies, but I can't
    see how it'd manage it. Better get the spanners out!
    -----sharks
    sharkey, Oct 23, 2005
  16. moike
    stuart t Guest
    Book of lies Sharks? Would that mean that you're not a big fan of BM
    manuals?
    Stu
    stuart t, Oct 24, 2005
  17. moike
    JL Guest
    It's UKRM'ism that's been bought to ausmoto - The "haynes book of lies"
    referring to the dubious accuracy of the Haynes aftermarket workshop manuals
    JL
    JL, Oct 24, 2005
  18. In aus.motorcycles on Mon, 24 Oct 2005 13:07:36 +1000
    I dunno, we were calling them that long before I found usenet...
    I suppose because they've been "differently accurate" for a long time.
    Zebee
    Zebee Johnstone, Oct 24, 2005
  19. moike
    JL Guest
    Oh, ok, well it's the oldest reference I've heard of as "book of lies".
    Pre my getting on the internet(1995) the most common phrases I'd heard
    regarding it were variants of "useless piece of crap" "not even good for
    toilet paper" and "why the **** did I waste my money on this bloody thing"
    Maybe I wasn't talking to sufficiently arty enough home mechanics
    JL
    JL, Oct 24, 2005
  20. moike
    sharkey Guest
    Hmmm, I've always found them pretty good, despite the name :).
    The 'lies' are generally omissions ... No worse than the factory
    workshop manuals in that regard, anyway.
    -----sharks
    sharkey, Oct 24, 2005
