The Pan is back...
Discussion in 'UK Motorcycles' started by Timo Geusch, May 8, 2004.
  1. Timo Geusch
    Christofire Guest
    <sig left in[1]>
    I noticed when I read the rest of the thread. It could be your end or
    their end, and I've had enough of diagnosing and fixing this type of
    problem at work in the last month.
    [1]I only get trouble with your sig, but as I've not been using Xana
    for that long I don't know where the problem lies.
    Christofire, May 9, 2004
    #41
  2. Timo Geusch
    Mark Olson was seen penning the following ode to ... whatever:
    That's what I'll do this afternoon. Fortunately the rear one on the
    Pan is adjustable (the front one isn't) so I should be able to get
    away with this. One might consider using the rear brake on a Pan
    anyway unless one wants to make a big fuckoff hole in the scenery, BTW.
    Actually I'll sort this out myself now, can't be arsed to chase the
    garage again. I'm just getting annoyed when I see the bloke behind the
    counter write down the instructions to fix a certain problem just to
    hear from the other bloke that he can't find any record of it.
    I mean, if you work on the brakes on somebody else's bike it does
    sound like a good idea to me if you check that *everything* is working
    afterwards.
    But maybe that's just me.
    Timo Geusch, May 9, 2004
    #42
  3. Timo Geusch
    Andy Bonwick was seen penning the following ode to ... whatever:
    That's what's going to happen this afternoon, at least for the rear
    brake.
    Ability actually wasn't the problem here, more a continous annoyance
    that people I was paying a wedge of my hard-earned weren't very good
    at following any instructions. Be it which phone number to call to
    talk to me, or fixing certain things...
    #43
  4. Timo Geusch
    Timo Geusch was seen penning the following ode to ... whatever:
    Right, now I'm fucking livid, I am.
    When this mob put the bike through the MOT the tester advised them
    that the front brakelight switch must be dodgy because it seemed to
    suffer from an intermittent failure. They talked him into a 'pass' as
    the rear one was working and told me I needed a new switch which they
    were supposed to fit, see above.
    They clearly hadn't even bothered to check if the switch was
    furbar'd. A quick check with a multimeter confirmed that it was
    switching as it was supposed to, moving the brake lever produced the
    expected 'clicks' so the fault couldn't be the switch. Turns out that
    one of the connectors on the cable must've been caught in something
    and was slightly bent. And not connected to the fucking switch. A bit
    of contact cleaner removed all the dirt that had accumulated in the
    connector's rubber boot and a careful shove pushed it back onto the
    switch.
    Of course, it's working perfectly well.
    Oh, and they've removed the fucking tag for the work carpark
    *again*. The first time I collected the bike I thought I'd lost the
    tag and put it somewhere 'safe'. From which it has
    disappeared. Arse. That'll be some more grovelling tomorrow so they
    actually let me into the carpark.
    Remind me again why I'm paying someone to fix my bike?
    #44
  5. Timo Geusch
    Salad Dodger Guest
    On Sun, 09 May 2004 12:47:35 +0100, Timo Geusch
    The world's turned upside down.
    Because it's yours, and therefore broken.
    | ___ Salad Dodger
    |_\_____/_| ..64741../..15361.../..3157./.19406
    \|^|/ ANORAK#17
    '^' RBR-Visited:14 Pts: 270 Miles:1248
    Salad Dodger, May 9, 2004
    #45
